Old 05-07-2009, 03:40 PM   #1081
Originally Posted by ccrcraceway View Post
i prefer the 2 piece mount, chassis has a bit more flex . i found with one piece mount i now and then strip gears . but with the 2 peice mount i have only strip one gear in almost 8 months and that too i think it was cos of driving on a dirty track .
I installed an aluminum bar (manufactured by myself) instead of the plastic one that joins the rear bulkhead to the radio tray over the clutch and I had never had any spurs damaged since 2005. I run almost once a month in a dirty or cleaned surfaces including national events.
mortech is offline   Reply With Quote
Old 05-10-2009, 06:45 PM   #1082
Arushmen's Avatar
Default ????
Hi, I just have changed my cars for a new v-one rrr wc.
I have read some issues about the clutch
Will be really necessary spend 100$ more in a sirio clutch? or the stock will work as well?
Do you have some tips?
Thanks in advance
Arushmen is offline   Reply With Quote
Old 05-10-2009, 06:54 PM   #1083
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Thanks in advance
You do not need to get the sirio clutch. What kind of engine do have?
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 05-11-2009, 07:01 AM   #1084
Arushmen's Avatar
Thanks.
I Have a Novarrosi 123.
Old 05-11-2009, 11:21 AM   #1085
jeff1's Avatar
Im looking for some good aluminum pignon. What brands are decent? I used the Kyosho in past and they wear so fast so I went to steel. Yet I want to go with aluminum to save weight
thanks
jeff1 is offline   Reply With Quote
Old 05-11-2009, 11:24 AM   #1086
Thanks.
I am assuming from your answer that you have a Novarossi Plus 12-3?
You should be good with the stock clutch. Worst case is you may want to lighten you flyweights. You can experiment with the weights a bit. They are pretty inexpensive if you screw them up. For that engine I would start with all the stock clutch parts (stock spring and grey clutch shoe). Compress your spring until about 1.3mm of thread shows. Set your gap to .4mm. I would start with the endplay at just enough to make sure nothing binds. Make sure your engine is properly tuned and start with that setup. If you need more snap, you can try adding .1mm endplay. You can also try lightening the flyweights. You can of course tighten the spring some more but I wouldn't go past 1.7mm or you may start to run into coil bind.
Old 05-11-2009, 09:08 PM   #1087
beers4evo's Avatar
hey guys, whats the part numbers for the front diff ?
I believe the front diff uses the same bevel gears as the rear diff but with different housing?
but could you please post me the right parts to get?
thanks.
Kyosho RRR Evo2 WC / O.S Engines / Twister Tyres / Futaba / Sanwa / Tornado
- im taking you down, im taking you to funky town!
beers4evo is offline   Reply With Quote
Old 05-11-2009, 11:41 PM   #1088
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
thanks.
Hi Mate,
The front/rear housing comes together in a set.
They use the same bevel gears, but use different outdrives (VZ218 are the outdrives used for the front Diff)
You also need to use the older servo ackerman arms (they come standard in the EVO2 kit)
Also, you need to use ball ends on the ackerman to prevent it rubbing with the diff.
To be honest, it took some time for me to get the diff into my EVO2, and working fine.
I only got to test it once at Moorebank with 100k oil, but I must say the car did feel much easier to drive, and I am sure with a few minor tweaks and an adjustment to my driving style (going from solid to diff) the car would be quicker.
Check this topic a few pages back, someone posted the parts required.
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 05-12-2009, 12:14 AM   #1089
Everything Novarossi said is correct. To add a bit more to it though. The front diff housing probably came with your kit as well. Both halves come in the Diff pulley set (part number VZ 204) It uses the same bevel gears, diff gears, gaskets, pins etc as the rear diff. Only difference between the front and rear diff is the housing, and the outdrives. Also, the front diff uses the same screw-on pulley that would go onto a one-way or a spool. Just make sure you don't use both sides of the pulley or the whole thing will be too wide to fit into the bulkheads. Also as Novarossi said, use the older ackerman plates or you will have issues with the diff and ackerman plate rubbing on each other.
Old 05-12-2009, 01:57 PM   #1090
blount's Avatar
Has anybody tried or currently running the 24th pullley overdrive? What are some advantages and disadvantages with that set-up, besides better tire wear?
blount is offline   Reply With Quote
Old 05-12-2009, 09:07 PM   #1091
mcsquish's Avatar
I'm running the 24 tooth pulley and from what I can tell (which may be incorrect so others chime in) there is less steering middle-out but more going in. I have also been told it should be easier on tires, but I haven't noticed it. Last year I ran a little faster lap times with the 24, but I am hoping when I can start racing again I will try running back-to-back and see. Just my $.02
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
Old 05-12-2009, 10:09 PM   #1092
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Well I've tried both 24t pulley with 1mm split and 23t pulley 2mm split and the car was faster with 23t pulley 2mm split and 384 middle belt....you also have to take into consideration what middle belt your using 384 or 387 so you might want to test it out for yourself to see what is faster to you.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 05-13-2009, 06:59 AM   #1093
blount's Avatar
I've only ran this set-up once. It was with the 384 belt in toledo. I ran it with the tire having a 2mm split. After 30 min main the tires came off the track with a 1mm split. I will test this weekend at 301 and see how the handles and lap times.
Old 05-13-2009, 09:27 AM   #1094
Questions??
I was wondering does anybody run the 387 middle belt are u running a solid or diff because tire wear is different when u run a solid I notice with a diff tire wear is about even after about 30min of running..
Old 05-13-2009, 09:58 AM   #1095
blount's Avatar
I was running the solid. Did you notice anything different with the way the car handled?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
