Old 04-23-2009, 11:10 AM   #1006
blount's Avatar
Originally Posted by r3nos View Post
My bad blount . A simple google search revealed that the 2D clutch is the same as the 4D but with only 2 weights, like you said
Try it out! What motor do you have? What type of track?
blount is offline   Reply With Quote
Old 04-23-2009, 01:00 PM   #1007
MrSlow's Avatar
Default durability?
i am a novice driver and looking to get into 200mm touring. the RRR is popular but i keep hearing it is not durable. because i am still a bit of a basher is this the wrong car?
thanks / j
MrSlow is offline   Reply With Quote
Old 04-23-2009, 01:03 PM   #1008
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
thanks / j
It is just as durable or more durable than any of the other 200mm racers out there. (Serpent, Mugen, Xray)
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 04-23-2009, 01:18 PM   #1009
YmeBP's Avatar
Trader Rating: 32 (100%+)
thanks / j
Ruhro shaggy, i just bought one too and i'm not that great a gas driver yet either.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 04-23-2009, 02:31 PM   #1010
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
thanks / j
It's not the toughest car( that's definitely the Mugen), but it is the fastest car out the box. If you have parts support then you shouldn't worry. The weakest part of the car are the rear hubs. If you tap the boards a lot they will crack where you screw in the upper camber link.
Racing4Evo is offline   Reply With Quote
Old 04-23-2009, 02:49 PM   #1011
olkleaf's Avatar
Default rear hub
the rear hub is the only part i have broken (not realy broken but it cracked). im going to buy a longer screw and see if that helps. im hopeing that a longer screw will keep the hub from cracking.
im going to try a 3x23 screw what you guys think?
olkleaf is offline   Reply With Quote
Old 04-23-2009, 03:17 PM   #1012
Going with a longer screw helped me, I only need to change when its really bend.
I will try steel cups over the hub that I manufactured but 3R has aluminum ones that must work to the rear hub least longer.
mortech is offline   Reply With Quote
Old 04-23-2009, 03:30 PM   #1013
RC-ProSpeed's Avatar
going back to the clutch topic, how often do you guys change the clutch spring...
RCRNV (www.rcrnv.com) / *Keep On-Road alive!*
- Nitro Touring - Kyosho EVO 2 WC
- Electric - TC6 (Out of the Box! No upgrades needed)
- F1 - F103RM (Out of the Box! No upgrades needed)
RC-ProSpeed is offline   Reply With Quote
Old 04-23-2009, 05:15 PM   #1014
NITROmmm's Avatar
Thumbs up
yes aluminium colaar or washer over the screw mount on the rear upright does help prevent cracking. Worked for me.
He who laughs last, thinks slowest!
RC HOBBYZONE
JSPECSTICKERS
NITROmmm is offline   Reply With Quote
Old 04-23-2009, 05:18 PM   #1015
NITROmmm's Avatar
Questions??
Originally Posted by Scott Fisher View Post
I like that clutch with 4 weights and a grey shoe the best.
Hey Scott, Any mods to the shoes,like making the holes bigger for less weight ?
RC HOBBYZONE
JSPECSTICKERS
Old 04-23-2009, 05:37 PM   #1016
THeGame's Avatar
Send a message via AIM to THeGame
I ran the Kyosho for the first time this weekend at 301 raceway and all I can say is DAM!!!!! This car is BUTTER!!! It was easy to drive and carries a lot of corner speed.... VERY HAPPY
Team Gravity Rc - G's R/C Raceway and Hobbies - Waldorf RC - TheTrack
THeGame is offline   Reply With Quote
Old 04-23-2009, 06:11 PM   #1017
blount's Avatar
Can you post some pic's of that? Would like see what your talking about.
Old 04-23-2009, 06:16 PM   #1018
blount's Avatar
That's a good question. I keep a new spare and after a couple of races I will measure the used spring and compare with a new spring with digital caliper. If there's a bid difference I will switch it out.
Old 04-23-2009, 08:55 PM   #1019
I leave the 4 clutch shoes just the way they come out of the bag.
Regarding the clutch spring, I hardly ever change mine as I always seem to have all the punch I need. Changing it never hurts and I should probalby measure it every once in a while... but I don't.
Regarding the rear hubs.... Use a longer screw. I broke a few hubs when I got the car. It was suggested to by another RRR driver to use a longer screw and since then I haven't broken that top piece again (which is almost two years now)
Old 04-23-2009, 09:17 PM   #1020
THeGame's Avatar
does anyone know the part number for the Alu middle shaft mount.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
