Old 04-22-2009, 11:34 AM   #991
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by blount View Post
I also found that if you run the rear belt to loose it will wear out the 21T rear pulley faster. And those can be hard to find at times
If you run the older RRR 2sp shaft and pulleys then the belt will last longer. You also have less rotating weight. The older system uses a plastic brake pulley that is driven by a pin. Also uses a pin-driven cam to drive the brake disc. The down side to this system is that the pulley wears more quickly and the rear belt is more difficult to change. Obviously another downside is that you have to spend some money to change over the car. The pulleys probably came with the car but you need a 2sp shaft, a few more 2x11 pins and a brake disc.
FYI: Yblsow's lightweight 2 speed shaft has the flat spots for the aluminum pulley/current system and has the holes for the pins used on the older RRR cars.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 04-22-2009, 12:42 PM   #992
blount's Avatar
Scott, is that what your using, the old style? It's not really that big of an issue, just something I found out while racing for the last 6 months. Do you think it's a MUST to have the light-weight 2 speed shaft? Will it make that much difference?
blount is offline   Reply With Quote
Old 04-22-2009, 03:30 PM   #993
RC-ProSpeed's Avatar
Blount,
You did a great a race last weekend, if I'm not mistaken most of the top spot were taken by Kyosho, I hope I can place mine in the mix next race, the engine is almost ready...
RCRNV (www.rcrnv.com) / *Keep On-Road alive!*
- Nitro Touring - Kyosho EVO 2 WC
- Electric - TC6 (Out of the Box! No upgrades needed)
- F1 - F103RM (Out of the Box! No upgrades needed)
RC-ProSpeed is offline   Reply With Quote
Old 04-22-2009, 04:23 PM   #994
blount's Avatar
Originally Posted by RC-ProSpeed View Post
Blount,
Thanks, but I'm far from where I want to be. I will really have to step it up for this Sunday.
Old 04-22-2009, 05:07 PM   #995
I run the older style on my car. None of this is a must. I did it for two reasons. It saves a bit of rotating weight that is also up kinda high in the car and the rear belt lasts longer. You don't have to use a lightweight shaft, you can certainly run a stock Kyosho 2sp shaft but once again the hopup shaft will save some rotating weight that is up high in the car. Also I know he will have titanium shafts availabe for the Kyosho any day now and they last a long time. Its not the kind of part that you have to replace every few races.
If you use the Kyosho 2sp shaft you have to order one from the older RRR car that has holes for pins instead of the flat spot. I just mentioned the YBSLOW shaft because not only does he sponsor me but it works with either setup.... the newer or the older system.
Old 04-22-2009, 06:52 PM   #996
blount's Avatar
Which titanium shafts are referring to?
Old 04-22-2009, 08:07 PM   #997
I am referring to the YBSLOW titanium 2sp shaft. He should have those as well as front layshafts at the end of next week.
Old 04-22-2009, 09:23 PM   #998
blount's Avatar
Ok, thanks!
Old 04-22-2009, 09:25 PM   #999
What clutch do you guys likes the most, I'm currently using the one it came with the car (2D), any pro's/con's with this clutch?
Old 04-22-2009, 10:57 PM   #1000
I like that clutch with 4 weights and a grey shoe the best.
Old 04-23-2009, 09:13 AM   #1001
blount's Avatar
I was running the 3D for about 6 months. Not to bad. I was told the 4D is better with just using only 2 shoes. Right now I'm running the sirio power clutch. Big difference in acceleration out the hole. Should of switched sooner!
Old 04-23-2009, 09:18 AM   #1002
So the 2D and 4D is the same, the different is just on the number of weights you use?
Hope that's the case, that way I just need to find 2 more weights and give it a try...
Old 04-23-2009, 09:42 AM   #1003
No they are not the same the 4D clutch is the one used on the evolva which has 4 metal posts on the flywheel, the 3D has 3 and although i haven't seen a 2D i guess it has 2 posts.
Each one has different size and number of weights.
Kyosho RRR Evo WC | Sirio XXX | Sanwa M11 | Kawahara tyres
r3nos is offline   Reply With Quote
Old 04-23-2009, 10:00 AM   #1004
blount's Avatar
From my understanding there is no 2D. Just 3D and 4D. Some run the 4D with just 2-shoes.
Old 04-23-2009, 10:21 AM   #1005
My bad blount . A simple google search revealed that the 2D clutch is the same as the 4D but with only 2 weights, like you said
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
