Old 03-15-2009, 11:35 PM   #901
rcabj's Avatar
Default solid vs front diff
guys, i am now using the front diff. going to try a front solid later on . i am expecting some changes to the car ??
1. exiting corners better
2. corner entry wider
3. more front tyre wear
4. more stress to the belts
anyone can add few more or correct me.. thanks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 03-18-2009, 01:28 PM   #902
RC-ProSpeed's Avatar
Hey guys,
Need som advise here, The kit should arrive to my house on Friday, but I'm reading the manual instructions alredy to speed up the process of putting it together,
What settings most of you recommend for the belt tension (Front and Rear)
Loose of Tight?
Also what setting would be the best for the suspension Bush B, I guess this is where you adjust the position for the upper hing pin at front and the lower pin at rear.
Any feedback would be helpful
RC-ProSpeed is offline   Reply With Quote
Old 03-18-2009, 01:34 PM   #903
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by RC-ProSpeed View Post
Hey guys,
Loose of Tight?
Regarding belt tension, run them loose.
Regarding the suspension, that really depends on the track and what you are trying to get the car to do for you.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-18-2009, 01:41 PM   #904
How loose, the first setting?
For the suspension, I was just trying to see if anyone recommend a good starting point, I'll be racing at 301 raceway...
Thank you,
Old 03-18-2009, 02:24 PM   #905
Thank you,
I run the front and rear belts as loose as I can.
Old 03-18-2009, 03:17 PM   #906
mckrooz's Avatar
Send a message via AIM to mckrooz
What are the characteristics of the different hinge pin positions?
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 03-19-2009, 02:01 AM   #907
MikaR's Avatar
What is the reason for this? I have a new car and now I wonder if I should do the same. I think I adjusted belts to "medium" tension when I built the car, not sure though. It could be also the "loosest" setting since the car is new.
I just bought the Evo 2 rear shock stay to my Evo 1. Also the alum brake lever which is nice, not sure if really needed.
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 03-19-2009, 05:36 AM   #908
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Running them loose gives the greatest drivetrain efficiency. After a few club days when the belts have loosened up and stretched, I move them up to medium.
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 03-19-2009, 12:19 PM   #909
What he said regarding drive train efficiency.
Old 03-19-2009, 02:04 PM   #910
I just switch to Kyosho, so there's a few stuff that I need to get familiar with
Can someone tell me the effect difference between the following parts:
Diaphragm Black
HC Diaphragm Black
HC Diaphragm White
Also on different colors for the Clutch Shoe
which one is harder, softer
Thank you
Old 03-19-2009, 04:07 PM   #911
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Changing the height of your hinge pin will change the roll centers on the car. The car feels pretty neutral with the standard lower hinge pin settings. Since I changed out the front 1-way for a spool I lowered the upper arm so that I will get more camber gain in the corners and essentially have more steering (trying to get it back to the steering a 1-way would have had)
I've found that with the lower arm heights you really get different feels on different tracks, so you really just have to play with them to find out what you like, it's generally a pretty subtle change.
Old 03-23-2009, 02:24 AM   #912
MikaR's Avatar
Anyone has tried VRC (virtual RC) ? I haven't been able to run my WCE yet, but it surely handles well on the screen How does it compare to real racing, you know?
Old 03-24-2009, 01:40 PM   #913
breez1090's Avatar
i play vrc almost everyday its helps me pace myself n ever since ive been playing my driving skills have been getting better but theres still nothing like the real thing
Dwayne Island breeze II
Xray NT1 Xray T3
360 2.0
breez1090 is offline   Reply With Quote
Old 03-24-2009, 01:58 PM   #914
MikaR's Avatar
Cool to hear it is close
Old 03-24-2009, 06:34 PM   #915
mcsquish's Avatar
Not sure if others have asked this already, but my searching has come up with zip. I'm looking of some Capricorn parts for my RRR and Muran Modified doesn't have them listed (I have sent them an email but on reply yet). I have also searched brooklynhobbies.com, serpentamerica.com, and parmapse.com. Who else in the states has Capricorn parts?
Thanks!
You do not need a parachute to skydive. You only need a parachute to skydive twice.
Never argue with an idiot, they'll just drag you down to their level and beat you with experience.
Dirt Burners Racing - R.I.P. BB / Kolors by Kropy / CEFX / One Eighth Racers
mcsquish is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
