Old 07-23-2008, 11:42 AM   #76
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by barg View Post
Im a bit over half way through building mine.
Front and rear ends are done. Just setting up the radio tray now.
My first impressions are:
New Plastic. Seems stronger/stiffer.
New Gearbox. Hot. A lot better fit than the old one.
New 2nd Gear with Steel inside instead of Alu. Hopefully helps with the stripping issue.
New adjustable servo saver.
Longer rear arms/driveshafts.
Thicker rear shock tower.
Chassis milled out near clutch bell. Should allow clutch bell removal without having to loosen the engine.
I cant wait to get it onto the track.
It will be making its track debut in Qld at the State championships.
Barg:
I have a question for you since I have not had a car in my hands as of yet:
Are you sure that the rear arms are longer? I was told they are the same as the previous car. Do you have an old one you can compare to be certain it is different?
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-23-2008, 01:58 PM   #77
GMartinez's Avatar
Trader Rating: 85 (100%+)
I was told the same also if you don't have the arms post the item# from the manual
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 07-23-2008, 02:23 PM   #78
GEO
GEO's Avatar
Send a message via MSN to GEO
Originally Posted by fatboy View Post
Hope the conversion kit will be out as i just got my RRR WC last month
Come in my possition who the EVO 2 comes to Greece at 2 months......And if i want the conversion kit..i must wait 3 or 4 months...
I am not so lucky because my V one RRR EVO has play in many races here in Greece and i need a new car...
What if I will wait ....
GEO is offline   Reply With Quote
Old 07-23-2008, 03:25 PM   #79
I thought the same thing regarding the part number, but if the plastic is different (this would be the first I am hearing about new plastic) it may have a new part number.
Old 07-23-2008, 04:44 PM   #80
barg's Avatar
Send a message via Yahoo to barg
Originally Posted by Scott Fisher View Post
Barg:
Hmmmm now you ask the question I think you might be right. I will check tonight as I am at work now.
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 07-23-2008, 07:49 PM   #81
ATOMIC's Avatar
The part # for the rear arm in the EVO 2 kit is VZ210B , it is the same arm as the previous arms from the WC kits just a different plastic. They arms have been at Kyosho America for about a year now.
ATOMIC is offline   Reply With Quote
Old 07-23-2008, 07:50 PM   #82
Arahawak's Avatar
Trader Rating: 32 (100%+)
Barg:
Have not seen the car yet, but theory wise, if the chassis is narrower, the arms should be longer..
What i heard is that the EVO 2 is total new car instead of just upgrades where you can get conversion kits.. well you can never be too sure with them Japanese designers..
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 07-23-2008, 08:04 PM   #83
ATOMIC's Avatar
The Chassis is narrow not where the bulheads mount but in the center between bulkheads. No geometry changes with the car. I will try and answer questions about the car as they come up.
Old 07-23-2008, 08:34 PM   #84
Arahawak's Avatar
So basically it is the same car as the EVO? How about the roll-out, any changes to that?
The narrower chassis would allow more flex, thus improve grip right? So what will it lose?
Any questions, i notice that the 1st pinion is sharpen on the edges compare to other cars like the Mugens and the Snakes. Why is this so? will it make better meshing or will that make a difference in the roll out?
Sorry for so many questions, just trying to learn.
Old 07-23-2008, 09:36 PM   #85
ATOMIC's Avatar
No roll-out changes
The car does have a bit more flex but I would say it is more of an eqaul flex front to rear.
The sharper point is for a smoother , more free mesh and will make no diff in roll-out
I will post the new parts with part #'s in the next day or 2.
Old 07-23-2008, 09:52 PM   #86
Riketsu's Avatar
Send a message via AIM to Riketsu
Thanks ATOMIC for clearing up these issues...
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 07-23-2008, 10:11 PM   #87
Arahawak's Avatar
Originally Posted by shesha View Post
"Kyosho have released information about their latest Kyosho V-One RRR 1/10th scale 200mm, the Evo 2. Designed to be a refinement rather than an all new design, the designers have worked on performance, stability and ease of maintenance. The main chassis plate is completely new with a narrower front end, while the radio plate has been stiffened up to improve drivability. The car also features the 2 speed gearbox from the Evolva M3, a new thicker revised rear shock tower and the rear of the car also sports longer arms to allow the use of 0-offset wheels."
The above information was posted on redrc.net from Kysoho.com however when I checked kyosho.com did not spot any information on the above written article.
Now i am confuse RedRC reported longer rear arms. but the part numbers are the same.
I guess i have to wait for somebody with the EVO and EVO 2 to post pictures of the arms.
Old 07-23-2008, 10:24 PM   #88
Riketsu's Avatar
Remember... RedRC reports what they are told to report... In order words, people write reports then send em to RedRC for them to post it... (or thats how i think this thing works)
Old 07-23-2008, 10:36 PM   #89
barg's Avatar
So does that mean that the current front spool wont fit on the new car?
www.nswrcrcc.com
Old 07-24-2008, 12:20 AM   #90
Just the opposite. From what Kyosho told me the chassis is narrower in the areas where the radio tray sits. The areas of the chassis at the front and back, where the bulkheads mount, the chassis is the same width. I am almost sure that the current spool will fit. I was actually told that all the plastic is the same.
Ron will hopefully confirm, but I was told the differences are:
New chassis
New radio tray
It comes with the 2D clutch
Uses the M3 servo saver, so you have inserts to more easily adjust ackerman
M3 2 speed
New 2nd gear that has a steel ring instead of aluminum
Car will use 0 offset wheels
Regarding the new offset of the wheels, I was not able to get the answer on how they do that..... Unscrew the pillow balls? Different wheel hexes? Will we need a longer camber link? Longer dogbones? Maybe Ron can shed some light on that.
Most or all of that has been mentioned, but that is what Kyosho America told me on Monday.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
