Old 03-05-2009, 02:21 PM   #826
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Ok, cool. Still waiting on a callback just hoping I can get some help, still gotta find setups on my cars as well... I'm bringing a table and EZ up, will I need anything else? Extension cord?
Old 03-05-2009, 02:34 PM   #827
mckrooz's Avatar
Send a message via AIM to mckrooz
I'm planning on being there tomorrow. Need to work out some clutch issues and get a final tuning on the motor. Hope to try out a front diff too.
mckrooz is offline   Reply With Quote
Old 03-05-2009, 05:00 PM   #828
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Definitely bring extension cord(s) as I know power is somewhat limited there. They don't run a lot of electric at this track.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-05-2009, 05:11 PM   #829
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Your going to like that diff action..
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 03-05-2009, 06:25 PM   #830
Got the extension cord, 50/50 on a pit man, but hopefully who I have in mind can come because I know he can tune an engine
Old 03-05-2009, 06:37 PM   #831
Thumbs up
Shouldn't be no problem Randy, Like Scott said there will be plenty of help at the track...Just make sure you go to the track tomorrow to get setup, track time and Test & Tune..
Old 03-05-2009, 06:57 PM   #832
shesha's Avatar
Send a message via MSN to shesha
Would someone be kind enough to confirm when someone refers to 0.6 shim it means the total number of shims together equals 0.6 or the total clearance from the TDC ?
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 03-05-2009, 11:02 PM   #833
NitroWD's Avatar
0.6 shim = shim thickness of 0.6mm
unless i'm wrong.
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 03-06-2009, 02:10 AM   #834
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by Scott Fisher View Post
The normal plastic spares will be good although getting some extra hinge pins isn't a bad idea. The stock clutch is also good, but I had heard can be a bit tough to setup so I run it as a 4 weight with the grey shoe. I think Walter usually runs a 3 shoe. I am assuming you are going to the race at Crystal Park. There will be a few Kyosho team drivers (myself, Walter D. and Mike P.) at the race as well as plenty of other drivers there that are very knowledgeable about the car. If you need help don't hesitate to ask one of us.
Yes, I still run the 3D clutch...
Ok cool, thanks. I put a spool in the front of the car since it looks like there will be a few parts on the track where hard braking would be beneficial, other than that though everything is pretty much the kit setup with 42 shore Kyosho tires, so hopefully it's a decent starting point. Will you be at the track for practice tomorrow?
Spool is a must, then everything else stock. On tires I normally run 37 front 40 rear, or 40 front 42 rear; you will like the feeling of softer tires in the front.
I won't be there on Friday, but will be there early on Saturday; just like Scott said, don't hesitate to ask any of us for help.
Walter Diaz
wad is offline   Reply With Quote
Old 03-06-2009, 10:18 AM   #835
Hmm, I only stocked up on 42's. Hopefully I can just make the setup a little more aggressive and get close to the same feel.
I'll be out at the track around noon today to get set up.
Old 03-07-2009, 09:42 AM   #836
Suspended
Hi,
What is the difference between the 2d clutch and the 3d clutch
kyosho player is offline   Reply With Quote
Old 03-07-2009, 11:37 AM   #837
hey guys
sorry if this is in the wrong thread
I have a 2004 evo worlds spec rrr, i was wanting to know if you can change the rear to use 0 offset wheels and if there are any parts needed to do this?
cheers
Elation101 is offline   Reply With Quote
Old 03-07-2009, 01:27 PM   #838
D Man's Avatar
Originally Posted by Elation101 View Post
hey guys
cheers
just back out the (pivot,pillow) ball, use the longer ball cup on one end of the upper link, at least that's what i did with mine, but i actually used the TI mugen upper link set up ball and ball ends..
Team VRC
D Man is offline   Reply With Quote
Old 03-07-2009, 01:28 PM   #839
carkillaii's Avatar
hey guys
cheers
Your going to need part #'s ky-vz081,ky-vs023 <<<< use these if you want to go with dogbones
sorry dont know the uni part #
carkillaii is offline   Reply With Quote
Old 03-07-2009, 02:46 PM   #840
shesha's Avatar
I believe it's VSW007 which has the alu washers, they are basically shorter to compensate the offset difference.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
