Old 02-15-2009, 03:46 PM   #766
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Perfect, thank you!
Old 02-15-2009, 03:51 PM   #767
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by Randy Caster View Post
Does Kyosho have a front spool available? If so a part # would be appreciated, and if not, is there one available from an aftermarket source?
Thanks!
This is a lightweight spool. It won't last as long as the Kyosho part, but weighs significantly less.
http://www.ybslowinc.com/products.php?item_id=18
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-15-2009, 04:55 PM   #768
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Perfect, thank you!
Just keep the outdrives well greased, this extends the life.
Mine is over 10 club days old and looks great.
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 02-15-2009, 04:55 PM   #769
beers4evo's Avatar
do you guys super glue the edges of your carbon fibre parts for strengthening...Apparently a crash with CF can crack easily and super glue what ppl been using?
beers4evo is offline   Reply With Quote
Old 02-15-2009, 05:30 PM   #770
Just to add to that tip, Losi makes grease, I don't know the part # but it was known as "brown grease", extremely sticky stuff that won't fling off like black grease will, basically just apply a little and forget about it.
Old 02-15-2009, 05:33 PM   #771
I do it mainly just for a better finish on the CF edges, you'll want to sand the edges with something around a 300 grit sandpaper to get them smooth, then soak a Q-Tip in some thin Zap glue (pink bottle) and run the Q-Tip along the edges of the CF. One pass will give the best finish, if you keep going over an area the glue will build up there and look crappy.
Old 02-15-2009, 08:27 PM   #772
Hegzworth's Avatar
Sorry to bug ya mate but where would be the best place to look up a good Vone RRR evo2 set up for Moorebank on the web.
Cheers Mate
~STRYKE Radio Control
~Team Orion
~Corally RDX PHI
~KYOSHO Vone RRR
~OS Speed12
~KOPROPO
Hegzworth is offline   Reply With Quote
Old 02-16-2009, 02:34 AM   #773
Michael_T's Avatar
Cheers Mate
Hi Mate,
The stock setup worked well with 40s allround and the locked front diff.
BUT, as you probably know, the track is currently being re-surfaced, and there are some minor changes to it, so next club day in 2 weeks is new to everyone!
Michael.
Old 02-16-2009, 02:39 AM   #774
Hegzworth's Avatar
Hi Mate,
Michael.
thanks mate i really appreciate your time
~Team Orion
~Corally RDX PHI
~KYOSHO Vone RRR
~OS Speed12
~KOPROPO
Old 02-16-2009, 08:28 AM   #775
olkleaf's Avatar
Default 301
does any one here go to 301 raceway? ... it seams that like there is 0 support for the vone at 301. looks to me like every one runs mugen. i'm new to racing but the few times i went last year i liked it. so if some one goes to 301, whats your set up?
here is mine
front... 600 shock oil,1m caster, 2 toe out, #10 ankerman arm, spool
back... 600 shock oil,1 shock position, A upper arm height, 50k diff oil,2 toe in
every thing else is stock, is there any thing i need to adjust?
olkleaf is offline   Reply With Quote
Old 02-16-2009, 09:51 AM   #776
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Go with the base setup in your instruction book, then adjust from there just little at a time, you should be fine....
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 02-16-2009, 03:26 PM   #777
beers4evo's Avatar
when you put the spur gears on are they suppose to spin freely (newly built rrr evo2 kit) ? mine seem to be binding...once i loosen the screw that secures the spurs on the right (looking from the rear) 2nd gear spins fine...
Old 02-16-2009, 04:35 PM   #778
dg8one's Avatar
here is mine
hey oakleaf this year a lot of ppl i know will run kyosho go back 1 or 2 pages you will see my car
Member of the CHEATERS CLUB
TEAM KAMIKAZE(MARYLAND CHAPTER)
TOKWA'T BABOY LTD
dg8one is offline   Reply With Quote
Old 02-16-2009, 04:39 PM   #779
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
if there is no engine installed the second spur should spin free both ways but the first spur should only spin freely in one direction and should activate the one way bearing in the opposite direction engaging your drive train. some times if your 2 speed shaft is not installed properly and the spacing is not correct on ya 2 speed shoe holder, then the collar that spaces the one way bearing and the first gear holder need to be shimmed .if i am understanding ur problem right, i think in your case you need to back off the 2 speed shoe holder on the shaft . see how that goes.
also if you use msn messenger you can get me on [email protected]
cheers
alex
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 02-16-2009, 04:52 PM   #780
olkleaf's Avatar
oh cool! nice car and engine... ill be using a rb R3 so hopefully all goes well. here is a pic of mine .. its not finished in the pic
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
