Old 02-12-2009, 06:24 PM   #751
olkleaf's Avatar
Originally Posted by dvu View Post
I guess I had some trouble with clearance of the stering arm itself. I shaved a little bit off and no problems. Thanks for the info on the receiver box.
Also, Stayed up to 1:00 last night and finally finished the car. I've always had a question on the break though. I know pulling the bar forward pulls the break arm forward which causes the little metal piece to push out against the backside of the break pad and pus them together. When you lay off the break/throttle servo though is there suppose to be something that actually pushes the break arm back?
no .. there is no need for something to push the break lever back
olkleaf is offline   Reply With Quote
Old 02-13-2009, 09:45 AM   #752
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Where can I find setup sheets for the Evo 2? I'm looking for a setup for Crystal Park..
Old 02-14-2009, 05:21 AM   #753
beers4evo's Avatar
Default ball bearings
hey guys,
when building your rrr evo 2, did you guys re-do the fluid in the bearings, or just straight run out of the box should be fine?
Also, how precise where your measurements for e.g the steering servo and rod, suspension arms, rear bulkheads, rear stablizer etc...i used a ruler lol but bought a digital caliper and going to do redo everything to ensure everything is precise.
beers4evo is offline   Reply With Quote
Old 02-14-2009, 06:35 AM   #754
You should redo it, a ruler is not as accurate as a digital caliper.
I also just lightly reoil the bearings before i put them into the new beast.
RROL and LOU`s where only real racers race.
Weapons of choice,NT1 2010 , X-Ray T3 x 2, X-Ray X10 X-Ray all the way baby.
Futaba 4pk,gq tires,jaco tyres,odonnel fuel,T-Power batteries, tekin and nova powered.
Don`t blame the car, when you know you can`t drive.
Sponsor, me , myself and I.
nitro ho is offline   Reply With Quote
Old 02-14-2009, 07:38 AM   #755
HarryN's Avatar
Send a message via AIM to HarryN
Remember, one of the marvels of Human Engineering was done with rulers, protractors, angles, and other simple tools to create the SR-71 Blackbird.
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 02-14-2009, 12:15 PM   #756
Very true harry, very true. But remember this harry, an itch in your pops pant`s made you,lol,lol,lol that was the most simplest of tools
Old 02-14-2009, 02:52 PM   #757
dvu
Hello,
I'm having a hard tiome findign a body long enough for the evo 2 wc. Is it me or is the bumber extra big. Anyway, any body brands you recommend?
Looking for Ferrari or Lamborghini body.
dvu is offline   Reply With Quote
Old 02-14-2009, 04:18 PM   #758
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Hello,
You should be running the smaller of the front plastic bumpers, and don't be afraid to trim the foam bumper to fit a body.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-14-2009, 07:22 PM   #759
dg8one's Avatar
i used the foam bumper from the cyclone TC and fits perfect and i still have the bemper that came w/it nice and new in my parts box
check the pic a page back
Member of the CHEATERS CLUB
TEAM KAMIKAZE(MARYLAND CHAPTER)
TOKWA'T BABOY LTD
dg8one is offline   Reply With Quote
Old 02-14-2009, 08:38 PM   #760
dvu
Thanks for the advice on the bumper.
Got another question on the clutch. I can't figure out what I need to fix. After I start it with the starter box, the first 2-3 throws of the throttle will give me a nice burst of speed (i.e. wheels spinning; and when holding the car in the air I get that nice kick), but after that it seems as though I can't get the car to go fast at all (no more kick with the throttle). It's like something has "slipped." I've tighten things down, have loosened the tension on the spring, place some extra washers so as to narrow the gap between the pad and clutch bell, and still no go. Could it be that the weights are too light, and it's not giving the pads enough push against the clutch bell?
I've done everything I can think of and it's driving me crazy. Any beneit in changing the weights w/ the ones in my HPI R40? Any suggestion would be appreciated.
Thanks, Duc
Old 02-14-2009, 09:32 PM   #761
Thanks, Duc
So you are saying that everytime you start the car from cold it does this, or did it work well a few times and now it never worked right again?
Old 02-14-2009, 09:34 PM   #762
dvu
Essentially everytime I start it from cold. However, I just put the car togther, and have just started working on tuning the engine. Would this happen if the car is running to rich. Is it possible with the first throw or two of the throttle, there's still small amt of fuel in the chamber and so it still "lean" and by the next few throws of the throotle I'm just "flooding" it out?
Old 02-15-2009, 09:17 AM   #763
dvu
Figured it out. I think it was running too rich.
Old 02-15-2009, 03:09 PM   #764
Does Kyosho have a front spool available? If so a part # would be appreciated, and if not, is there one available from an aftermarket source?
Thanks!
Old 02-15-2009, 03:35 PM   #765
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Thumbs up
Thanks!
Front spool#click here KYO wzw220.
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
