Old 01-22-2009, 10:04 AM   #691
Speyederjedi's Avatar
maybe this issue has been discuss a lot of times , but how do u guys usually replace your shock oil ? maybe few different methods out there.[/QUOTE]
rcabj,
When replacing my shock oil, if I'm at the track, I dump out the old oil, spray the shock chamber with Nitro Clean or Carb Cleaner and let it dry out. Then I put in the new oil and get out all the air with my shock pump. If I'm at my shop at home I do the same process except I disassemble each shock and check the shafts, pisons and o-rings just in case anything needs replacement.
Regards,
Speyederjedi
Speyederjedi is offline   Reply With Quote
Old 01-23-2009, 01:05 AM   #692
rcabj's Avatar
Originally Posted by Speyederjedi View Post
rcabj,
Regards,
Speyederjedi
thanks one more thing after completing changing the oil , i notice a few guys pushing the shaft all the way in to make sure there is rebound , normally half way is this crucial or not l
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 01-26-2009, 10:22 AM   #693
olkleaf's Avatar
does the locking block on the front diff work just as good as the spool?
olkleaf is offline   Reply With Quote
Old 01-26-2009, 01:00 PM   #694
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
principal of working is the same . i have used them twice and both time i have striped the block . and its a pain to change them when you dont have much time on ur hand.
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 01-26-2009, 01:18 PM   #695
olkleaf,
Yes, but there are a couple issues with using the block. They strip easy so you need to fill in the hollow spaces with a hard material. I've used JB Weld or the similar type steele putty which you can get at any auto parts store. Now the drawback to that is you are adding more spinning weight. I would say just use the spool. It's less work.
Regards,
Speyederjedi
Old 01-26-2009, 01:26 PM   #696
rcabj,
I do make sure there is rebound and that the shaft can in fact be pushed in all the way and does rebound to the full extension of what the arm allows. If you cannot push the shaft in all the way until it bottoms out then you have too much oil. If you push it in and it does not rebound then you don't have enough oil. The other thing I like is for the rebound to be slow and not immediate. That's just what works for me. Others may have different suggestions.
Regards,
Speyederjedi
Old 01-26-2009, 01:40 PM   #697
olkleaf's Avatar
Thumbs up
olkleaf,
Regards,
Speyederjedi
thanks, i was worried that the locking block wasn't going to be durable enough
Old 01-28-2009, 08:23 PM   #698
rcabj's Avatar
rcabj,
Regards,
Speyederjedi
thanks again for the explanation
i hate it when it comes to refilling the shocks
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 01-28-2009, 08:41 PM   #699
beers4evo's Avatar
hey guys, im looking into getting a touring car for the tracks and rrr evo 2 and xray nt1 are in my mind. Is there a big difference with the special parts in the rrr evo 2 wc edition then just the evo 2 itself? I've seen the specs and I'm just wondering if its worth buying the wc editioin.
beers4evo is offline   Reply With Quote
Old 01-28-2009, 09:20 PM   #700
D Man's Avatar
going with the wc is worth it, i have two friends that bought just the non wc kit when it just came out and they ended up spending about half the cost of the difference. alum hex adaptor,cvd's cause the dogbone would always pop out, and i forgot there were a couple more things that they had issues with.
Team VRC
D Man is offline   Reply With Quote
Old 01-28-2009, 10:05 PM   #701
rcabj's Avatar
yeah , just get the wc u'll be satisfy... the price difference is not that much considering the hop up u'll get.
front and rear uj.
c/fibre front shock tower.
monoblock engine mount.
blade type rear antirol bar.
alu. wheel adaptor.
middle and rear option shaft.
option shock shaft.
alu. pulley adaptor.
it'll cost a fortune just to get this things on to the stock kit
did i left anything else.
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 01-30-2009, 04:23 AM   #702
dg8one's Avatar
hey guys
i wanna cut my body post but i dont want to ct it too short. where do u guys cut your body post? or what hole on the body post you put your body pins (front and rear)
thanks
Member of the CHEATERS CLUB
TEAM KAMIKAZE(MARYLAND CHAPTER)
TOKWA'T BABOY LTD
dg8one is offline   Reply With Quote
Old 01-30-2009, 08:57 AM   #703
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Originally Posted by dg8one View Post
hey guys
thanks
Adjust to your body A rule of thumb leave at least 2 holes above the body and adjust cut right above the 2 hole front & rear so you can lower or raise the body, the should work finethat's I cut my post.....
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 02-03-2009, 08:26 AM   #704
Questions?? Clutch
Hello,
Anybody knows if I can use the centax III clutch of Serpent in my Voneevo 2?
Thanks a lot
rojasl is offline   Reply With Quote
Old 02-04-2009, 04:15 PM   #705
Chaya's Avatar
Default Front Oneway assembly
Hi there,
Im building my kit and was on the Front Oneway already, however, i just found out that the FRONT ONEWAY COLLAR (Key#74) was missing on the parts bag (or did i mislook it) . is it a must to install it??? Is it a plastic or aluminum type or just a washer.
Thanks in advance.
Chaya is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
