Old 01-17-2009, 11:52 PM   #676
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Don't forget Ashford Hobby!!
www.ashfordhobby.com
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 01-20-2009, 08:32 PM   #677
rcabj's Avatar
Default terrible outing story
well last weekend took part in the first round of my country on road race series. due to few commitments , i was unable to go earlier and practice before the race. only arrive early in the morning on race day , had a few runs before race starts and thats it
3 heats given , i ran the first 2 and couldn't clock a good time.
so when the 3rd heat arrive i was determined that i must perform better. but the worst possible thing happen , my pitman couldn't get the motor running. i shouted to him to get it started. after a few attemps it was to no avail. i came down the driver stand and almost threw my transmitter
i can't believe to find out that my plug flamed out
after that while waiting for the finals , to add more to my frustration my transmitter cease to function!!, nothing appeared on the screen when switched on. it was miserable. i left the pit area and went for a walk around the track. when i came back my friend told me he found out what was wrong with the radio. one of the battery casing wires were torn. so we hurried to replace the wires
anyway for consolation i won the lower groups finals just 7 seconds in front of the 2nd car .
Today after some 'post mortem' , i need to make few changes in my setup like changing my 2d clutches system to the sirio power clutch and instead of running the front one way i will drop in the front diff and maintain other setups for next outing.
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 01-20-2009, 09:24 PM   #678
esham's Avatar
I believe we taking about the same local race. It was the same for me on the practise issues. I mess up with the rollcenter setting which cost me on all 3 heats. resolve the problem for the lower final but it was too dark. For me Oneway is still competative on that track.
The mistake: I lowered the front upper arm which give too much traction in front till the rear lost grip. 40 shores all round and max caster angle still doesn't counter the roll center issues. Driving felt like no caster and the car is so responsive on steering.
learning every racing
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 01-20-2009, 11:24 PM   #679
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Questions??
What is the problem with the 2d clutch....?
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 01-21-2009, 02:11 AM   #680
rcabj's Avatar
hi Ivan, i find it lacks a bit on the initial acceleration . but from mid to top it was 'ballistic'. and on that particular track i believe the 3d works better coz i need that extra acceleration punch. do u reckon the 2d should work better?
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 01-21-2009, 02:26 AM   #681
rcabj's Avatar
yes bro ! we r refering to the same race. u were fast during the finals , i can see your car behind me at the same pace as i was. got me worried there
i drop in the front diff for that final, first time with it and luckily i can adapt to its driving style quickly too i do find it easier esp. taking small turns. the rest was nearly the same to the one way beside late braking capability i might stick to it too.
we can compare our setups , mine was :
fr track width 198 ,rear 199
droop 1 and 4
roll centre b front,c rear
shock medium, 50wt oil all round
front blade 30 deg
rear wire stock
i use 37 shore all round for that finals
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 01-21-2009, 09:09 AM   #682
Speyederjedi's Avatar
rcabj,
Do yourself a favor and get the Capricorn or Sirio power clutch set-up. I too was unhaapy with the new 2d set-up for the RRR Evo 2 and went back to the stock 3d set-up. It was better but the car was still to slow out of the turns when compared to my 2 buddies running the Xray NT1. I went and got the Capricorn power clutch set-up and the car is really way quicker off the bottom and stupid fast from mid to top. It made a big difference on my lap times. The proper set-up for that power clutch has been posted on 3hobby.net. Hope this helps you out.
Regards,
Speyederjedi
Speyederjedi is offline   Reply With Quote
Old 01-21-2009, 09:30 AM   #683
Thumbs up
I'm still running my 3d clutch, but I was thinking of getting the 2d clutch down the line, thanks for the feedback...
Old 01-21-2009, 02:55 PM   #684
olkleaf's Avatar
Default suspension shafts
is it common to bend you suspension shafts on this kit? or is it one of those things i shouldn't worry about?
im buying some parts just want to make sure i got everything
i used to run the NTC3 so i am used to keeping like 10 of each part
olkleaf is offline   Reply With Quote
Old 01-21-2009, 03:15 PM   #685
olkleaf,
It doesn't happen often but it does happen. I've bent a few hinge pins along the way. I keep 1 set of each of the hinge pins in my group of spare parts.
Regards,
Speyederjedi
Old 01-21-2009, 03:19 PM   #686
olkleaf's Avatar
Originally Posted by Speyederjedi View Post
olkleaf,
Regards,
Speyederjedi
thank you
Old 01-21-2009, 03:21 PM   #687
thank you
Not a problem.
Old 01-21-2009, 05:59 PM   #688
rcabj's Avatar
Default replacing shock oil
appreciate all the feedbacks guys. thanks a lot.
yea, i made the wrong choice when i use the 2d clutch . hopefully with the power clutch i can go out and show some muscles .
maybe this issue has been discuss a lot of times , but how do u guys usually replace your shock oil ? maybe few different methods out there.
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 01-21-2009, 06:43 PM   #689
esham's Avatar
droop 1 and 4
front blade 30 deg
rear wire stock
Your white body colour safe you there... mine-
Final setup
Trackwidth F199/R200
Droop F0/R4
Rollcenter F"highest", R"center/middle" ( no sure if it a,b,c?)
Shock 50wt all round
Swaybar F 90deg, R 45deg
Tires 40 shore all round
Old 01-21-2009, 09:06 PM   #690
rcabj's Avatar
yup it did if not for sure i would end up inside the drain like PJ and Mamad
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
