Old 01-12-2009, 10:08 PM   #661
shiston's Avatar
Originally Posted by D Man View Post
are the 3racing shocks really better than the kyosho's, sorry if this has been asked before... just got my kyo and heard it from someone
Judging by the 3racing shocks I got for my brothers Tamiya tt01, no way. The Kyosho shocks are fine. If I were to change the shocks on my car I would go for either Tamiya TRFs, 720 or NT1 shocks only.
shiston is offline   Reply With Quote
Old 01-14-2009, 05:34 PM   #662
esham's Avatar
Default Front diff installation problem.
Need help here... I tried install front diff into my Evo2 but the front pulley was rubbing the bulkhead. That make the diff set not free running and bind.!! I also tried to shim them but it doesn't solve the problem .
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 01-15-2009, 01:51 AM   #663
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
hi try these few things to troubleshoot
take of the the front diff undo all pulley and diff screws and do them up again .
secondly take note there should be a lip of plastic just after the pulley where the diff bearing sits . Some time the lip wears of cos of the bearing rubbing on it or if there is dirt in between .This lip is what maintenance the gap btw ur diff housing and the bulkhead. In the case of no lip replace the housing. If all these things seem right there could be a bit of manufacturing defect on the bulk head or the pulley . in that case i would either replace the bulkhead or get a piece of sand paper between the pulley and the bulkhead and rotate the wheel/diff till the binding part sands off .
hope this help
p.s check if the belts tension adjusters are same on both sides
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 01-15-2009, 02:45 AM   #664
esham's Avatar
Thanks ccrcraceway... Will troubleshoot it tonight..
Old 01-15-2009, 01:03 PM   #665
olkleaf's Avatar
Default 3 mm difference
there is a 2 mm difference with the 23tooth pulley.what is the point of the 2 mm difference? does the car handle better? i run my tires about the same diameter.
olkleaf is offline   Reply With Quote
Old 01-15-2009, 07:51 PM   #666
el salvador's Avatar
Default Front Diff Binding
The 27 tooht front diff sprocket when used with a "Gear Diff Housing", can not have the "side lip" that the instruction tells you to CA glue to the sprocket. If you glued this part to the front sprocket it will not work. I realised this when I tried to change from a Oneway diff to a gear diff. Had to get another drive pulley set.
Hope this helps.
el salvador is offline   Reply With Quote
Old 01-15-2009, 09:09 PM   #667
D Man's Avatar
i don't have that problem with mine i switch my pulley from the oneway to the diff and back with no rubbing problem or is it because i have the evo rrr not the evo2
Team VRC
D Man is offline   Reply With Quote
Old 01-15-2009, 10:30 PM   #668
GMartinez's Avatar
Trader Rating: 85 (100%+)
I have the Evo2 WC & have not had an issue with the front diff I would also double check that you have the right eccentrics in place & ensure your belts are aligned correctly on top of what was recommended
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 01-15-2009, 10:33 PM   #669
GMartinez's Avatar
finally overdrive ratio
on tracks that have very low tire wear it is recommended to run the 24t pulley to compensate the over drive with a 1mm tire split
Old 01-16-2009, 03:17 PM   #670
Smile
so in a low tire wear track would you still true the tires to a 2 mm split or 1 mm . and also using a 24 teeth pulley does it mean that there is equal drive front to rear compared to a 23 t pulley.
would like to hear a bit more about it as i dont have a very good understanding about the diver ratios
Old 01-16-2009, 03:33 PM   #671
GMartinez's Avatar
Yes I would if the track calls for it some Kyosho Team drivers went to the 24-tooth pulley with a 1mm tire split since the traction was very high but the wear was very low it calmed the car a bit on steering which was not needed due to the track bite.
I know another driver who runs the the 1mm tire split & uses the 23 tooth pulley & it is more to his liking. trila & error you just have to try it out & see what more has a better feel for you.
Old 01-16-2009, 08:36 PM   #672
sweet thanks
Old 01-17-2009, 11:51 AM   #673
GMartinez's Avatar
sweet thanks
anytime
Old 01-17-2009, 05:40 PM   #674
olkleaf's Avatar
Default thanks
thanks for the help GMartinez. great info
well another question... my LHS wont order parts from kyosho unless i buy over $100 bucks in parts. right now i just need to buy a few of parts.(about $50)
i bought some parts from shop kyosho but i get the feeling Im getting ripped off.
is shop kyosho giving me a good price or is there a another site with better prices?
thanks guys
Old 01-17-2009, 10:01 PM   #675
GMartinez's Avatar
thanks guys
Here are some online stores
www.brooklynhobbies.com
www.kamikazetoysandhobbies.com
www.gasrccar.com
they all carry Kyosho parts
overseas my best experience is with www.rcmushroom.com
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
