Old 11-08-2008, 10:43 PM   #541
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Anyone know where I can find the EVO2 gear ratio chart online?
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 11-09-2008, 03:37 PM   #542
staikosn1's Avatar
Send a message via MSN to staikosn1
Originally Posted by The "Kyo Show" View Post
In my opinion, I would put the one-way in or a spool just to eliminate one possible binding problem. I would definitely loosen all the belts to the loosest setting. The 20,000 oil in the rear should be fine, I use 30,000 most of the time but every track is different. Start with this and see if this helps unless someone else has better advice. My Evo2 is new and I have it pretty dialed. Check your track widths at both ends and make sure the dog bones or CVD's arent binding. If this works then try your front diff again and see if thats the problem. Good Luck!
Thank you kyo i will try this way!!
staikosn1 is offline   Reply With Quote
Old 11-09-2008, 05:59 PM   #543
barg's Avatar
Send a message via Yahoo to barg
Originally Posted by staikosn1 View Post
I have a problem with car.Today was the 1st day in track with that car,and its tooooo tight,i put diff in front 100000 silicone and 20000 in rear diff!! from the beggining all belts were too tigths!! should i try to untight them all,and change diffs oils?? the car in the track was like a wood in the road!! do you understand what i mean???
Take the side belt off and check if the binding is in the front or rear of the car.
Definetly check your dogbones arent binding as a few people have had this problem depending on your wheels. Take out the o-rings if they are.
Let us know what you find and we can help you further.
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 11-10-2008, 08:55 AM   #544
didrace's Avatar
Default Guys i need your help please
Guys i need your help please.......
I recently bought from ebay a v-one rrr but i was told it was the wc evo rrr..the guy was a lier..
I would like if you could please tell me which parts i need to change to make it upto date ...i know i difficult because it is two generation behind..
if you could please give me some idea of how much difference the evo and evo2 will make to my hadling and durability i will appreciate it...
Please give me some answers because i been trying for two days now to get answers and i cant..
Thanks...!!!!
didrace is offline   Reply With Quote
Old 11-11-2008, 09:55 PM   #545
Michael_T's Avatar
Anyone run the 2 degree knuckles in the EVO2 yet?
Opinions?
Old 11-12-2008, 09:22 AM   #546
Speyederjedi's Avatar
Thanks...!!!!
Didrace,
Sorry to hear you got scammed but maybe I can help point you in the right direction. First thing you may want to do is cut out the small cross-member on the front of the chassis. This should give your car more flex in the front and better steering. As far as other parts I would recommend replacing the front dogbones with the CVD's, also try and get the titanium shaft shocks, and aluminum hex hubs. Can't think of much else I would change. Some like the rear blade sway bar, I personally prefer the wire type. You could also get the lightweight (hollow) 2 speed shaft but I prefer the solid one. I have the RRR Evo 2 and it is already basically an Evo 2 WC. The only things I haven't changed out are the WC 2 speed shaft and rear blade sway bar. Hope this helps. Maybe someone else has some other suggestions???
Regards,
Speyederjedi
Speyederjedi is offline   Reply With Quote
Old 11-12-2008, 01:31 PM   #547
didrace's Avatar
Thank god someone has replied to my question and helping me a lot..
Thanks Speyederjedi...
Its been a few days now i was researching what they have changed and i have some questions for some things they have changed because it seems that every year they have to change something to get more money..
Lets start from the v-one rrr version..
ok to convert the rrr to evo they have changed the upper deck and changed the position of the servo from laydown to upright.. and if you see now on the evolva m3 they use the laydown position because some people prefer the laydown position..so the question is why did they changed the upper deck and the servo mounting position? what is the change in perfomce?
also the other thing they have changed is the rear bulckheads and the only reason i can think without looking on the new and old ones is because they use the new 2 speed axle. but on the other hand they could have use they same stuff and just change the brake hub to aluminium..
so again what the point of changing most of the rear end ? why did they do it? what is the difference in perfomnce from the rrr?
another thing they have changed is the shock body and the springs..
ok for the springs i can understand the body shock why?
also the have changed some other stuff like new spur gears and new o rings but again i am thinking if i spent 290 dollars to change most of these parts does it worth it? or is it better to buy the new evo2?
i dont know i am totally confused...
Old 11-12-2008, 02:05 PM   #548
Didrace,
On the question regarding the change to the laydown servo on the upper deck for the RRR EVO. The change was for a lower center of gravity (CG). I didn't care for it because it put the servo horn and linkage out to the side of the kit where it was exposed to getting hit. The kit did come with a small plastice brace to protect the servo but i just didn't like the setup.
I may be wrong on your question about the rear bulkheads but I believe they are the same from the RRR on up to the RRR Evo 2. It's my understanding that the Evo 2 simply has longer rear control arms so you don't have to run 2 degree offset tires. The reason for the lightweight 2 speed shaft is for less rotating mass as that shaft is hollow.
As far as the shocks go, I'm not sure why they went with a different shock body. Maybe someone else can shed some light on the reason for that.
On the new 2 speed setup for the Evo 2, it is from the Evolva M3 and is simply smoother than the the Evo 1 version. As far as the new 2D clutch setup, the verdict is still out. I initially didn't like it but have since added 2 grub screws to each weight and have gotten it to work to my liking. Without the weights it just didn't have enough snap on initial engagement. I have a few motors and on my other Sirio Evo 4 STI I am running the CRF clutch setup from the 07 CRF WASP .12. That setup has a mutch stiffer spring and 3 weights and seems to work quite well with that particular motor. I am thinking of getting the Sirio clutch setup as well.
As far as going out and buying the Evo 2, I guess it just depends on how serious you are about racing and your pocket book. If you're just getting into it you may want to get your feet wet with this RRR and then little by little build it up to the EVO 2. If you have been racing for a while then you may want to get the RRR Evo 2 and use what parts you can off the RRR for spares. Hope this helps.
Regards,
Daniel
Old 11-12-2008, 02:25 PM   #549
Michael_T's Avatar
Nice:
http://www.kyosho.com/eng/products/r...duct_id=104158
Old 11-12-2008, 02:32 PM   #550
didrace's Avatar
Thank god again..Thanks man nice replies..
I have been racing for year and now i am racing with the 720 07 and is not a good car..
it does not want to handle what ever i do to it..the last time i was racing it it was drifting..i mean it on the corners i had to put up the throtlle fot the car to stay in the corner and it was not forgiving..it is a no forgiving car.. i dont know why..
thats why i went with the kyosho..
i bought from the ebay and the guy from ireland was untruthfull.. he lied.. before i bid on it i asked him what car is this and he said it is the v-one rrr evo wc and i was so excited that i bought the wc evo and when i got it i was so dissapointed and as i was checking the differences to convert it to evo i was getting mad..because i was dreaming of that kyosho..
anyway..
and yes the rear bulkheds have changed.. they are called vz something...B but i dont know why..
Old 11-12-2008, 03:22 PM   #551
anyway..
Didrace,
Just hang in there with the kit you bought. With the right setup that car is still very competetive. One of the Kyosho sponsored drivers here in my area is still running that kit over the Evo 2 and is always up in the front.
Are you running a front diff, spool or one-way? I would recommend starting out with the spool or front diff. If you run the front diff go with 100k diff oil or higher. On your rear diff I'd go 20k or 30k diff oil and on the shocks 40 to 60 shock oil. This should be a good starting point. Let me know if there is anything else you have questions on.
Regards,
Speyederjedi
Old 11-12-2008, 03:45 PM   #552
didrace's Avatar
Ok i will stay with this car.. is it better than the 720 07? i need to know at least because i am bored with that car..
it comes with gold and silver springs and a front spool!! the car came assempled from the ireland guys but is not built well , the shocks are not build correctly, the wheelbase is different from one side to the other, the camber is a lot in the back an so on..
what do you think i can buy as a starting point?
http://www.poleposition-pt.com/produ...&sub=1#imagens
here you can see the conversion kit? what do you recomend?
I would like to thank you for all your help and i hope the car works as i wish it does, at least better than the serpent because its been a year now that am trying to get through a correct setup for that serpent and i cant..it seems impossimple for me..
Thanks again!!!
Old 11-12-2008, 04:48 PM   #553
GREGORY!'s Avatar
didrace post some pics here to see the car.
how much do you buy it?do you left at least negative feedback to him?
GREGORY! is offline   Reply With Quote
Old 11-12-2008, 04:55 PM   #554
didrace's Avatar
I bought it for 110 something.. I could not leave a negative feedback because his paypal was not working and i could not send the money through ebay and i sent him the money through postal order..!!!
Old 11-12-2008, 05:00 PM   #555
didrace's Avatar
Default the pic..
pic of car
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
