Old 10-07-2008, 07:56 PM   #391
Suspended
hi guys i was wondering if anyone has a set up for a low traction track thank you
kyosho player is offline   Reply With Quote
Old 10-07-2008, 10:18 PM   #392
CraigM's Avatar
Trader Rating: 34 (100%+)
Have you tried the kit setup? The oils are all very soft and it uses the 2nd lowest RCs front and rear so it's ideal for low-med traction
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-08-2008, 04:44 AM   #393
Suspended
yes i tried the kit set up but the car still spins out thank you
Old 10-08-2008, 07:03 AM   #394
the setup on this car is almost irrelevant except for corner speed because the car is so well engineered that every setup gets you around. if your car constantly spins out, you have something else going on.
when does it spin? if its exiting the corner, back off the clutch. either less gap or less spring pressure. if it spins when you let off the throttle and you have a one way, don't let off the throttle as quickly or expect to be able to brake.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 10-08-2008, 08:06 AM   #395
Where are you located? What track do you run on? Maybe with that information someone on here can lend you some help in person. If you are in the Michigan/Ohio/Indiana area I might be able to help you with your car or let you take mine for a spin to see if you like it. With the winter creeping up on those of us in the north I'm guessing you are from a warmer area.
Andy who? is offline   Reply With Quote
Old 10-08-2008, 09:30 AM   #396
mcsquish's Avatar
Now why would anyone want to take your car for a spin?
It too faassstttt...... Mr. MWS chump. Oops Champ
mcsquish is offline   Reply With Quote
Old 10-08-2008, 10:30 AM   #397
lil-bump's Avatar
Trader Rating: 83 (100%+)
Talking
I agree he should take the car for a spin. Just make sure you bring back in 5 different pieces.
Good job Andy
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 10-08-2008, 11:34 AM   #398
Suspended
Hi and thanks for all the help .my car is so loose entering the corners .I don,t know if it is the track width or what .my set up is front spring -blue shock oil -50 wt
roll center-pin on top
track width- 198
droop-1mm
steering block 1degree
diff-80,000 oil
rear
spring-blue
oil-40 wt
roll center-pin-lowest
track width-198
droop-2mm
diff-20,000 oil
my car is loose off power going into the corner and also coming out of the corner . would going wider in the rear or front help?
thank you
Old 10-08-2008, 11:37 AM   #399
thank you
In general, the wider the front the more stable the car will be. if it's loose with that setup, entering off power and exiting a corner on power.. you have a larger problem. is the track dusty? what shore tires are you running?
Old 10-08-2008, 02:05 PM   #400
Suspended
i am using jaco 38's rear and jaco x-50's front the traction on the track is low
camber
front-1 degree
rear-3 degree
toe
front-o degree
rear-3-degree
thank you
Old 10-08-2008, 02:06 PM   #401
track width- 198
droop-1mm
diff-80,000 oil
rear
spring-blue
oil-40 wt
track width-198
droop-2mm
diff-20,000 oil
thank you
How are you measuring that rear droop? Is that 2mm to the hub?? If you measure to the bottom of the hub you need more like 4mm.
Can you tell us what track you race at?
Old 10-08-2008, 02:24 PM   #402
Suspended
I race on a track in Canada and I measure as the manual says 4 mm to the bottom of the arm
Old 10-08-2008, 02:59 PM   #403
you have really done about all you can do assuming standard maintenance has been done (bearings roll free, tweak is reasonably straight).. try to take shims out of the clutch gap and back off the spring so it will not engage so hard.. other than that you just have to drive it loose because your track just doesn't have enough bite.
you may want to look at rubber tires, they have some treaded designs that work well with dust.
Old 10-09-2008, 11:32 AM   #404
Speyederjedi's Avatar
What are your sway bar settings and do you have any of the softer Kyosho shock springs ( gold, silver or black)? You may want to soften up the suspension to try and get better traction.
Regards,
Speyederjedi
Speyederjedi is offline   Reply With Quote
Old 10-09-2008, 04:00 PM   #405
Suspended
my sway bar settings are
front- flat
rear-flat
it is weird as at my track the x-ray cars has alot of traction
thank you
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
