Old 09-21-2008, 05:29 PM   #346
CraigM's Avatar
Trader Rating: 34 (100%+)
Originally Posted by barg View Post
Some impressive lap times there Michael. Well done. Looks like its time for some Kyhosho domination at Moorebank coming up......
Thanks for the lend of the Spur gears too.
Craig, Make sure you mesh your gears as tight as possible. There should be no gap at all but they should still spin freely. If you do this you shouldnt have any stripping problems.
The 2d Clutch is awesome. Never had any troubles and mine is plenty fast enough.
Im going to try the Sirio cluth at the Nats though. Just havent had the time to try it at moorebank yet.
The mesh was ok to start with but I hit a slower car (the hazard of ending up in the c-final) and the engine moved. I think I'm going to mill out the chassis a bit more around the holes so I can use countersink washers like most other cars, they should bite a bit harder than the button heads. Ric was saying he drills out the engine mounts and taps a 4mm thread into them, thats a nice idea too
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-24-2008, 03:38 AM   #347
iiistyler's Avatar
Send a message via MSN to iiistyler
Ackerman
I have looked at the ackerman on the new evo 2 and B n C look very similar which gives you less initail steering A or C
Thanks in advance
BTW Barg no stock again on the spurs sorry mate
V-ONE-RRR EVO 2
MURNAN MODIFIED 353 09 TUNED FULL CERAMIC STOCK 353 09 TUNED
FUTABA BRUSHLESS BLS551 3PKS + FASST
PROUD MEMBER OF THE MOOREBANK REBEL ALLIANCE
YOU ARE NOW ENTERING KYOSHO COUNTRY BEWARE
iiistyler is offline   Reply With Quote
Old 09-24-2008, 05:20 AM   #348
CraigM's Avatar
Originally Posted by iiistyler View Post
Ackerman
Thanks in advance
The ackerman effect is reduced when the wheels are less angled, so you will find minimal impact on initial steering by changing the plates. I cant remember which letter locates the ball joints the furthest forward but when using a spool you will get the most steering with the arms located in that position, followed by the middle one, followed by the rear.
Easiest way to get more turn-in is to stand your front sway bar up
Old 09-24-2008, 08:14 AM   #349
impalabob64's Avatar
Send a message via AIM to impalabob64
Default chassie motormount screws
Hey guys if you use the screws from the traxxas 4tec the motormount chassie screws will work perfectly ,an you can use a 2.0 or 2.5 to tighten them, i hve been using them without any problems
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 09-24-2008, 02:07 PM   #350
iiistyler's Avatar
Craig Thanks
But I want less initial steering that way I can have my steering throw turned all the way up on full lock I found the car had alot of steering so I was thinking ackerman rather than reducing the steering throw
V-ONE-RRR EVO 2
Old 09-24-2008, 07:59 PM   #351
CraigM's Avatar
Craig Thanks
Try move it back one position, I think that should be C from kit which is B-forward. Like caster it's a very sensitive adjustment so even though the holes are only ~.5mm different you'll feel it on the track
Old 09-24-2008, 08:40 PM   #352
rcabj's Avatar
just got my evo2 last weekend. most probably i'll run it this weekend.
any important tips before i hit the track thanks.
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 09-24-2008, 08:48 PM   #353
don't crash...
Baedarlboo is offline   Reply With Quote
Old 09-25-2008, 03:07 AM   #354
iiistyler's Avatar
Cheers Craig I thought "A" looked a bit extreme
its not like the evo wc te where 10 is less ll middle 12 max (i think)
you comming to the nationals?
V-ONE-RRR EVO 2
Old 09-25-2008, 04:31 AM   #355
CraigM's Avatar
Make sure your brake cam isn't binding in the bulkhead, this happened to me and I missed a heat taking the bulkhead off and sanding the cam down. Otherwise the kit setup is very good, and a .5mm clutch gap seems about right with the 2d.
HTH
Nah man I've got the EP states the following weekend (arrg bathurst!!), I should hopefully be more competitive there than I would be at Brendale
Old 09-25-2008, 05:30 AM   #356
If anyone has the univ swing shafts (47mm) VZW219 - 2ea I would like to buy
zurk20 is offline   Reply With Quote
Old 09-25-2008, 06:19 AM   #357
shiston's Avatar
With the pulleys in the kit setup, is there any front overdrive or something like that so you need to have a couple millimeters difference between front and rear tyre diameters?
shiston is offline   Reply With Quote
Old 09-25-2008, 08:21 AM   #358
Speyederjedi's Avatar
Someone else may be able to confirm this, but off the top of my head I believe the kit comes with 2 front side belt pulleys. A 23t and a 24t. The 24t is your overdrive so you can run shorter fronts. Wish I had the manual in front of me but I think this is correct. Anyone??? Bueller?... Bueller?..... Bueller?....
Regards,
Speyederjedi
Speyederjedi is offline   Reply With Quote
Old 09-25-2008, 01:41 PM   #359
GMartinez's Avatar
Trader Rating: 85 (100%+)
Regards,
Speyederjedi
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 09-25-2008, 01:41 PM   #360
GMartinez's Avatar
Regards,
Speyederjedi
23t belt 2mm split on tire size commonly used when you have mid to high tire wear
24t belt 1mm split on tire size for very low wear
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
