Old 09-18-2008, 02:10 PM   #316
el salvador's Avatar
Default EVO2 Transmissiom Mainshaft Endplay
Originally Posted by Novarossi View Post
How much sideway play do you guys allow on the gearbox?
There is probably 3-4mm movement side to side (not used to this amount of play with the NT1, MTX4R).
Do you guys shim it out, or is this normal on the Kyosho?
See photo.
I have found there is plenty of mainshaft endplay adjustment by simply moveing the 2nd gear shoeholder on its setscrew/slot location on the mainshaft, and tighten the set screw when the desired endplay amount is achieved. A little patience and trial and error is all thats necessary.
I hope this makes sense and helps.
el salvador is offline   Reply With Quote
Old 09-18-2008, 03:56 PM   #317
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Thanks for the tips guys.
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 09-18-2008, 06:59 PM   #318
barg's Avatar
Send a message via Yahoo to barg
See photo.
Nova are you sure you used the right plastic spacer on the pulley side of the gearbox shaft? The kit comes with 2 and you need to use the long one.
I think I put the wrong one on once back in the day.
Ive never seen any kyosho with 3-4mm play in the gearbox shaft. Some of my cars ive actually had to sand the spacer down.
I would check that. Or take a photo of that side of the car for us to take a look at.
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 09-18-2008, 07:12 PM   #319
barg's Avatar
Does anyone know where I can get the new 2nd gears from? 55C and 56C?
www.nswrcrcc.com
Old 09-18-2008, 08:12 PM   #320
rcabj's Avatar
Originally Posted by MikaR View Post
Looking good Novarossi!
I'm just starting to build my evo WCE, this new evo2 looks so smooth!!
the evo2 wc version has come out, when.
where did u get it...
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 09-18-2008, 08:46 PM   #321
Michael_T's Avatar
Thanks Andrew, yep I incorrectly put the smaller spacer on first, but then changed it to the longer one.
What is the difference in gears? I bought about 20 different spur gears (not sure if they are "C"), I can give you them to you on Sunday if you need them before the Nats, and you can replace them later on.
Old 09-18-2008, 09:45 PM   #322
barg's Avatar
Thanks mate. The 55B and 56B are the old ones with the aluminum inside. The 55C and 56C are the new evo2 ones with steel inside.
Ive got heaps of the B gears but if you have the C gears that would be great if I could get some off you.
Cheers mate.
So is the gearbox play ok now with the right spacer?
www.nswrcrcc.com
Old 09-18-2008, 10:06 PM   #323
Michael_T's Avatar
Cheers mate.
Yep, just confirmed I have the following (new in packets):
2 x VZ114-55C 2nd Spur Gear 55T
1 x VZ114-56C 2nd Spur Gear 56T
I take it there the ones your after. You can have all 3 on Sunday, just replace them for me.
I just shimmed up the gearbox to remove the play. Will start it up and test it for the first time tomorrow so lets wait and see....
Old 09-18-2008, 11:05 PM   #324
barg's Avatar
Cheers mate.
That would be awesome.
Your gearbox will be fine. I always run a little play in mine to compensate for heat buildup. If you run it to tight when it heats up it might bind.
www.nswrcrcc.com
Old 09-19-2008, 12:14 AM   #325
CraigM's Avatar
Trader Rating: 34 (100%+)
looks like KM racing have ripped off the capricorn NT1 tank top deck
http://www.redrc.net/2008/09/km-raci...rr-radioplate/
nice
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 09-19-2008, 12:20 AM   #326
dodo's Avatar
Send a message via Yahoo to dodo
nice
what is the advantage of using NT1 tank? i've been wondering for a while....
dodo is offline   Reply With Quote
Old 09-19-2008, 12:45 AM   #327
carkillaii's Avatar
I was told it has a lower cg & a quicker side to side weight transfer
carkillaii is offline   Reply With Quote
Old 09-19-2008, 01:39 AM   #328
Arahawak's Avatar
Trader Rating: 32 (100%+)
nice
At least it was a cheaper alternative.
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 09-19-2008, 02:28 AM   #329
dodo's Avatar
and has anyone tested how much it will improve your laptime? sorry, no offense to anyone but since the laydown servo (which was claimed to lower CG) was changed back to standup servo, i always have the thought that the whole CG issue is a gimmick... i'm talking about the few mm difference in the height of the servo/fuel tank and not the CG issue in general (e.g putting ur engine as low as possible etc).
Old 09-19-2008, 06:17 AM   #330
G87z's Avatar
From the pic's on RED RC it looks like the steering servo would still lay down. Maybe I am missing something. Does anyone have any Pic's showing the difference between the lay down and stand up servo's? I am planning on buying this car for next season so all of this information is of great interest to me.
Thanks!
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
