Kyosho V-ONE RRR EVO 2
#286
Capricorn have some really trick stuff, is there anywhere to buy it other than their site, preferably in USD? by the time I convert our dollar to euros, pay the extortionate prices, and then consider shipping I'm up for a couple hundred bucks on even small items
edit: murnan has some of their gear
Evo2 top deck will have to do for now as well as the non $59 brake disc but the $34 lightweight dogbones are pretty trick for a pair considering Xray sells univerals for something around 35 EACH so I may pick those up.
#288
Haven't had my RRR Evo 2 for too long and was wondering about tire size. I noticed my car seems to handle much better with say a 61mm front and 63 mm rear vs 59mm front and 61mm rear. Is this due to flex in the foam allowing for more traction? With no other changes done the car is quicker with the shorter tires but doesn't seem to handle as well as with the taller tires. While I realize gear ratios come into play with how fast you want to run is there an advantage either way? Shorter or taller? Do any of you have a starting point at which you work from when it comes to tire size? Just needing a few pointers in this dept.
Regards,
Speyederjedi
Regards,
Speyederjedi
#294
Regards,
Speyederjedi
Regards,
Speyederjedi
The taller tires flex more like you said, and can compensate and kind of dull the car a bit which might feel like it has more traction. The foam is a bit softer when it's taller too because the wheel isn't supporting it as much.
#295
The stock setup seems to be for ultra low grip - 35sh tyres, 2nd lowest RCs, thin diff and shock oil, etc. Apart from the tyres, how have people found it? does the car just like to be soft or have you been changing a lot when the grip or speed of the track is med-high?
#297
Novarossi,
What clutch setup is it that you are using? From the photos it's not stock. Kit looks ready to rock. Nice motor and pipe selection. I'm currently running and IDM .12 in my RRR Evo 2 but am anticipating the arrival of my Sirio Evo IV motor and pipe setup. Please let me know how the clutch set up works out. I may be looking to change over from the stock setup. I need a little more punch from my clutch.
Regards,
Speyederjedi
Regards,
Speyederjedi
#298
Looking good Novarossi!
I'm just starting to build my evo WCE, this new evo2 looks so smooth!!
#299
Novarossi,
Regards,
Speyederjedi
Regards,
Speyederjedi
If you don't have enough punch from the IDM engine with the Kyosho clutch, I think you don't have your clutch setup properly. Either that or your engine isn't running right. The IDM engine has sick bottom end power. If you are using the stock EVO 2 clutch, you should have the 2D clutch. Most I know of have been running that with the stock spring and 4 fly weights. I normally have used the grey shoe with that setup and usually have to detune the setup with the IDM engine.
I also have a Sirio EVO 4 STI engine and run it with the power clutch and it is also very punchy, but a bit more linear on its power band.
#300
Hello
I bought a RRR Evo 2, but I want to know which clutch is better 2D or 3D?
I saw in the RRR Evo WC edition has the 3d Clutch.
regrads
regrads
