Old 07-11-2012, 08:27 AM   #2686
Location: Beneath a rock down by the river. Don't have money for van
Why do you miss yours?Still have mine.
( ͡ ͜ʖ ͡) https://www.facebook.com/becomeasetupguru/
30Tooth is offline   Reply With Quote
Old 07-11-2012, 11:40 AM   #2687
rcabj's Avatar
i no longer have it....parted with it few years back. just sharing how i miss and love the car back then and still do, eventhough with newer models emerging still find the car 'attractive' and 'irresistable'
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 07-11-2012, 12:34 PM   #2688
It's still a very good performer for sure,I like the look and it's so reliable.I'm still awaiting some screws for the front R4 diff conversion so can't comment how it performs.
Old 07-11-2012, 06:39 PM   #2689
rcabj's Avatar
gud luck with the conversion...just wonderin what it would be like if there were to redesign the RRR internal ratio including smaller spur gears and maybe alloy bulkheads
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 07-12-2012, 06:16 AM   #2690
The conversion is already done,almost drop-in upgrade and posted a while back in this thread what is needed.Them Edam Spirit is like the RRR and has aluminum bulkheads as option but heard it makes the car too stiff.
Old 07-12-2012, 08:04 PM   #2691
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
I was told a few Weeks back by a very well know world class racer that has ran just about every top performing sedan, i asked him what sedan was his favorite and he shocked me when he said the RRR was best! he said in his position he doesn't have the luxury of running what he feels is best, but whoever offers him the best deal....also we talked about the worlds that Burch won.......shimo out paced all nt1's, caps, serpents....he qual 2nd with a RRR!!
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 07-13-2012, 02:50 PM   #2692
The RRR has many years of development on it's belt,perfecting every single part to maximum reliability and good performance,the geometry is still spot-on and parts are strong and wear really good,price is nice too.I feel the NT1 has nothing more than tiny diffs and low radioplate,it didn't revolutionize touring cars and even Terauchi's MTX4R finished 2nd for what I could see it wasn't as much upgraded as Burch's NT1.
Old 07-13-2012, 08:24 PM   #2693
Bundy_Bear's Avatar
Interesting conversation guys... My favourite R/C cars that I wish I still had would be the original Kyosho V-One R and then the Team Associated Nitro TC3. It must be a part of getting older that you look back in fond memories.
I do have a Shimo, so will the Edam diffs and Universals fit? Also does the X-ray Nt1 radio fit?
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 07-14-2012, 04:40 AM   #2694
Hey Bundy,not 100% sure but my gut feeling says that Edam parts are compatible with the RRR,as for the radio you meant the radio box?Radio boxes are overrated,I've never used a box and if there's too much dust or the possibility of water then I put the Rx inside a balloon but that's the case with a RRR WCE which has the Rx on top of the T/B servo maybe try doing like Shimo and run the Rx between the Rx pack and tuned pipe and voila,protected and balanced.
Old 07-15-2012, 04:14 AM   #2695
Today all parts have arrived including R4 diff cases.
1st:vz403 are the new updated diff cases!RRR oneway pulley fit so doesn't need vz402 pulley set for front diff.
2nd:R4 front diff fits the RRR!it's just a hair too wide that makes installation a bit difficult but a little cursing and voila it's in a new home using RRR eccentrics and bearings using a custom sleeve so it can fit inside RRR's bearings.
3rd:rear diff is slimmer,about a mm each side,no biggie use a shim.
WOOHOOO!!!
Can some one clearly list what parts and part#s are needed to upgrade RRR with R4 diffs (i.e. outer-drives, bearings etc). I've done a search but it's not entirely clear. Also, it still sounds like a custom bearing sleeve is required for the front diff. If so, how do I accomplish this without going to an engineer? Lastly, what diff oils are you running...e.g. I'm running 50K f 5k r...is the general rule to double this for these smaller diffs?
Thanks.
V-one-RR Evo,V-one-RRR (WC hopped-up),2007 Evolva,
Spada 09,MR-02,MR-03
Inferno GT2. Serpent Cobra GT
KF01 - F1, Serpent Viper 977WC, Serpent Natrix 748
1FastVW is offline   Reply With Quote
Old 07-15-2012, 07:26 AM   #2696
Thanks.
Parts list:
ORG045S - o-rings for the outdrives
UM610 - diff bevel gear set
UM613 - diff bevel shaft
VZ419 - front diff outdrives
VZ403 - diff case set
I used the same pulley from the RRR one-way and you need M2.5 x 8mm for tightening the case.Every lathe operator should make one of those rings or you can saw a hollow tube 18 OD x 15 ID x 4 width (all measurements in mm) or a 18x10x4 bearing.
Old 07-15-2012, 11:09 AM   #2697
Parts list:
Thanks....in terms of diff oils are you essentially doubling or using stock r4 diff oil setup? Also are these the new hardened gears and what performance gains have you experienced.
One last thing...what material is being used for the bearing sleeve...aluminum/plastic? Thanks in advance.
Old 07-15-2012, 04:22 PM   #2698
Where I used to run is low traction so 100K should be a starting point.No hardened gears,still the standard ones because when ordered them I only knew about the rear diff exploding and the hard ones were not available.Plastic ones should be ok but aluminum ones are wobble free,should last longer and less chance to warp while you are sawing it.
Old 07-15-2012, 05:53 PM   #2699
Tx.
Old 07-15-2012, 07:01 PM   #2700
Tx.
You're welcome,now go spank those NT1's/C01's
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
