Old 12-30-2011, 10:46 AM   #2656
DRRC's Avatar
Trader Rating: 57 (98%+)
starting to get into 1/10 nitro onroad with my Kyosho V-RRR
where can I get set ups for parking lot racing?
is there a better place for the reciever to be mounted, not a good place bec of the fuel tank?
Team Wife
Mugen Seiki Racing
Mugenracing.com
DRRC is offline   Reply With Quote
Old 01-05-2012, 11:24 AM   #2657
selling my v-one rrr wce
http://www.rctech.net/forum/r-c-item...rp-engine.html
boybawang is offline   Reply With Quote
Old 01-11-2012, 12:32 AM   #2658
Default Kyosho V-One RRR WCE
Hi all,
I have just finished building my new V-One RRR WCE and in the later stages of running in the engine.
Now that I'm getting a little bit of speed I've found that the front wheels aren't braking. When I apply the brakes the car spins around.
Have I done something wrong when building?
Is there something I can change or adjust?
I've noticed that when you roll the car backwards, all 4 wheels brake.
Thanks in a advance.
Wickers1980
Wickers1980 is offline   Reply With Quote
Old 01-11-2012, 12:41 AM   #2659
nikoskar's Avatar
Originally Posted by Wickers1980 View Post
Hi all,
Wickers1980
Front tyres aren't braking when you use front one-way. Change to Differential in order tyres to brake.
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 01-11-2012, 01:47 AM   #2660
Rubio's Avatar
...OR brake only when you are on a straight line
My Baby:
Nt1 '13/ MaxPower 3.5 / Savox Servos / HotRace Tyres / Sanwa Exzes Z
Rubio is offline   Reply With Quote
Old 01-11-2012, 03:29 AM   #2661
Thanks for the reply.
The car does have a front differential.
Is this normal for only the rear wheels to brake and it's just something I have to get used to?
Thanks Rubio, I'll keep that in mind.
Old 01-11-2012, 04:55 AM   #2662
nikoskar's Avatar
front end must stopped to, less than rear. Are your belts ok?
www.rc-world.gr
Old 01-11-2012, 05:47 AM   #2663
MikaR's Avatar
It does not have a front diff out of the box. It has a oneway instead.
Are you sure about the front diff?
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 01-11-2012, 08:03 AM   #2664
Rubio's Avatar
As the other mates said, please check if you really have the front diff, 'cause your symptoms seem adressing to a front one-way, as I used to have too.
In any case:
- with front diff you can brake even starting the curve, because the braking effect is applied on all of the wheels, then you can release the throttle later and enter faster in the curves
- with front one-way your car is smoother but be aware to brake only on a straight line otherwise you'll gonna turn around, then you are forced to brake only before to start steering
My Baby:
Old 01-11-2012, 09:50 PM   #2665
Smile
Thanks guys.
Just checked the manual again and found it does have a one way.
Will try turning it around.
Old 01-11-2012, 10:30 PM   #2666
MikaR's Avatar
It won't work that way. Get a solid axle (=spool) or a diff, instead
Spool is only 1 part, diff requires many
Old 01-12-2012, 02:18 AM   #2667
Found a solid axel in one of the bags in the kit. Will change it over because the track I'll be running at is a little tight.
Thanks for all your advice and help.
Old 02-09-2012, 02:35 PM   #2668
GSPOT's Avatar
Trader Rating: 62 (100%+)
Send a message via AIM to GSPOT
anybody else deal with a slipping clutch? my car has a lack of power like the power is being lost....using a red clutch, original clutch setup.....any suggestions?
GSPOT is offline   Reply With Quote
Old 02-09-2012, 07:56 PM   #2669
DRRC's Avatar
What does a solid spool in the front do?
Compared to one way and diff
The one way is fast in corners with sweepers but bad on tIght tracks and break while going straight or else it would spin
Diffs are more forgiving but with the one way it wants to be on throttle
Team Wife
Mugen Seiki Racing
Mugenracing.com
Old 02-11-2012, 11:11 PM   #2670
RahjahDat's Avatar
Trader Rating: 101 (98%+)
Default Great info
thanks for the info guys!!!
RahjahDat is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
