Old 09-30-2011, 02:19 AM   #2641
nikoskar's Avatar
Lower rear diff oil.
Change Roll-center
Change shock position
Change camber
Change Toe
And check different body
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 09-30-2011, 02:22 AM   #2642
MikaR's Avatar
Originally Posted by jespadas View Post
Hi, im new to RRR settings and Im having problems with rear traction, when entering a curve the rear end spins, im using 32 shore fronts and 35 fronts rears, please help me on what I shoud check first
obviously your front traction is better than rear, right
try lifting the rear up a bit
more camber rear
rear shocks more vertical/front more upright
softer rear tire compound
tire dia front 62mm/rear 64mm (if I recall right)
something like this..maybe
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 09-30-2011, 05:09 AM   #2643
Location: Beneath a rock down by the river. Don't have money for van
Jespadas can you say what setup are you running?But first check for a smooth drivetrain and suspension.My suggestion is running the rear lower bushings on A or B down,I run on A down and 3 hole from the bottom for shock position,standard camber link position.Hope this helps.
( ͡ ͜ʖ ͡) https://www.facebook.com/becomeasetupguru/
30Tooth is offline   Reply With Quote
Old 09-30-2011, 08:35 AM   #2644
jespadas's Avatar
thanks for the info I did the following
Diff oil lowered
changed rear shocks position
changed rear camber
Will try it on weekend and post results
Do you have any setting for this track??
this track have low-mid traction
jespadas is offline   Reply With Quote
Old 09-30-2011, 01:12 PM   #2645
Where is that track Jespadas?Looks familiar to me,it's in Spain?
Old 09-30-2011, 01:33 PM   #2646
jespadas's Avatar
This is in Merida, Yucatan, Mexico
Regards
Old 10-03-2011, 11:19 AM   #2647
jespadas's Avatar
Diff oil lowered
changed rear camber
Any setting idea for a track like this one?? Thanks for your help
Old 10-03-2011, 01:59 PM   #2648
Jespadas can you practice in the track before the race?Start with the base setup from the manual then report what you want the car to do better so we can have a starting point to help you,it's hard to give a setup without being there.Gracias.
Old 10-27-2011, 07:46 AM   #2649
Can anyone give me a TIP for tire setting? Toe in and toe out camber frnt and rear.
I use you play mg RRR in a circuit..im a bigginer when it comes to rc nitro world.
What tire setting would you suggest..im i dont use anytool like Hudy Setup station.im on to caliper for for measuring
Can anyone post some pic of tire seting of your V one rrr.Thanks,.,
My Kit is more to drift movement when it comes in cornering..i want to correct it
I use Front Oneway,can i remove it..so that it help me for better handling...our circuit here in not likely as those big..
Would any one suggest about correct setting?
joiner2 is offline   Reply With Quote
Old 10-27-2011, 05:25 PM   #2650
doen08's Avatar
Trader Rating: 38 (100%+)
Send a message via Yahoo to doen08
i can help you set it up. dun ka post sa thread natin. ahihihi.
doen08 is offline   Reply With Quote
Old 10-28-2011, 04:03 AM   #2651
tikab ak wagilan otid RRR OT, lawab IPH otid ahihihihi
Old 11-10-2011, 05:23 PM   #2652
At last,the inserts/bushings/adapters so R4 diffs fit the RRR are in my possession.Check this post http://www.rctech.net/forum/9892698-post566.html.
And one more question,what is the lowest weight ever attained on the RRR ready to race?
Old 11-14-2011, 11:34 AM   #2653
Trader Rating: 65 (100%+)
So where do I get these adapters? Can you send me a link? Or did you get them custom made?
goose510 is offline   Reply With Quote
Old 11-14-2011, 01:08 PM   #2654
Custom made,they're aluminum but nylon is advisable.
Next thing I'll try is making hollow mid and main shaft.
Old 11-16-2011, 05:13 PM   #2655
has anyone tried to do brushless conversion on the vone rrr?
TIA,
Ron
syrss is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
