Old 03-31-2011, 05:01 AM   #2611
Location: Beneath a rock down by the river. Don't have money for van
Good idea Gregory,i'm thinking about upgrade my RRR and just wait for the R4 evo.I too was thinking about doing some spacers in nylon so i can fit R4 diff at front those had to be 10x12x4 if I want to use the RRR big bearing or 15x18x4 if I want to use BRG014 bearings right?I'm eager to know if the R4 main shaft is compatible with the RRR.
Oh about my testing,I could notice the front hooks a little better with the front upper bumper assembly unscrewed from the bulkhead.
Thank you Gregory and B.C.
All RRR evo2 including Shimo Edition use 0 offset wheels all around,the evo1 and RRR use 0 front 2 back stock.
( ͡ ͜ʖ ͡) https://www.facebook.com/becomeasetupguru/
30Tooth is offline   Reply With Quote
Old 03-31-2011, 06:32 AM   #2612
GREGORY!'s Avatar
Originally Posted by B.C.Ninja View Post
just had my mate turn me up some flanged spacers since yes the price for a 10x18x4 bearing is exspensive, its a 10x12x4 spacer with a flange so that it will fit the R4 diffs but slip inside the RRR bearings, and has a slight flange on one end so they dont come out. Now all I have to do is wait till my country gets the spares available and I'm away laughing.
there is room for this little flange?i don;t think so.if you find that you can put it in just glue them in.
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 03-31-2011, 06:41 AM   #2613
GREGORY!'s Avatar
buddy,great idea.just use the stock rrr bearings and make these spacers.
now,for the main shaft.the only thing that i know is that it sit in the same bearings
Old 03-31-2011, 01:16 PM   #2614
The flange is only slight, but the inserts sit very very tight in the bearings, there is room on the diff side of the bearing just. But now with how tight they sit inside the bearing I'll be flipping them round to be facing to the outside. I seated the bearings in the tension rings last night and the flange was flush with that so there is no dramas either way, the flange was only about .5mm and tbh the tolerences I found weren't too stringent there is room either way round.
B.C.Ninja is offline   Reply With Quote
Old 04-01-2011, 03:12 AM   #2615
Should have the spacers in a couple of days!About the main shaft the R4 one looks like the Evo shaft with a cut for the set screw of the outer pulley holder,I start to believe it's almost the same as the RRR.If without these mods the RRR was collecting fastest laps at races I just can dream what's coming
Old 04-01-2011, 09:12 PM   #2616
The only thing to check is the length of the shaft, from what I have checked comparing the two manuals, rrr, R4 to do the conversion you would need the entire assembly, including 1st/2nd spurs and 2 speed clutch assembly as well as all pulleys and brake holder just to be sure, the diameter is the same but the 2spd attactches via a pin not a grubscrew and its the opposite for the side pully, not a biggie, I have asked on the R4 thread for shaftlength so will post here with results.
Old 04-03-2011, 08:40 AM   #2617
B.C.
Changing to the new style 2 speed and pulleys is a must actually.So if everything still lines up as the old style there's a big improvement using all the new bits.
Old 04-20-2011, 12:11 PM   #2618
mckrooz's Avatar
Send a message via AIM to mckrooz
Selling my car. Anyone interested? PM me.
http://www.rctech.net/forum/r-c-item...-evo-2-wc.html
Kyosho RRR Evo2
mckrooz is offline   Reply With Quote
Old 04-25-2011, 07:28 AM   #2619
Default Pinion suggestion for 50 meter straight
Hey guys what gearing do you suggest for a 50 meter straight as the stock ratio is to close for this track.
speed6 is offline   Reply With Quote
Old 05-25-2011, 09:41 AM   #2620
RC-ProSpeed's Avatar
Can someone post a setup for a medium traction track / long sweeper and with a technical infield.
Or a link where I can find various setups/ Is been a while since I ran this car and would like to get a good starting point again. the setup I had was a large open high traction track
G.
RCRNV (www.rcrnv.com) / *Keep On-Road alive!*
- Nitro Touring - Kyosho EVO 2 WC
- Electric - TC6 (Out of the Box! No upgrades needed)
- F1 - F103RM (Out of the Box! No upgrades needed)
RC-ProSpeed is offline   Reply With Quote
Old 05-25-2011, 11:49 AM   #2621
MikaR's Avatar
Not sure if this is any help but I pretty much copied the settings from the setup sheet that came with the manual, run 16/21 and 61/55 gears, front diff 60K rear diff 30K
I run lipo and HV servos, Ti pillow balls, Ti screws, transponder, DNA body, tires 37/40 front/rear 62mm/64mm dia, RX box/cover
weight ~1640gr
My 1st race this season on the coming Sunday ;-)
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 05-25-2011, 06:25 PM   #2622
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default set up
G.
if I were you start with the stock set up, except run rear camber 4.5 degree 3.5 rear toe in 35's all the way around 2degree camber front if you have a solid for the front try it
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 05-26-2011, 04:33 AM   #2623
When I need a setup that isn't around this thread I go to http://kyosho.com/eng/support/settin...one_index.html
At Kyosho America there isn't any setups for onroad.
Old 05-26-2011, 05:15 AM   #2624
MikaR's Avatar
I might, thanks
I noticed I have caster clips all the way back.
Old 05-26-2011, 06:21 AM   #2625
Trader Rating: 22 (100%+)
Default shimo
I'm selling my shimo edition with wasp.12 and pipe a ton of extras ti pivot balls and screws and turnbuckles maybe 20 tanks of fuel run. 300 shipped pm me for pics
D-Bizzle is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
