Old 10-27-2010, 05:10 PM   #2491
Originally Posted by DJ_Shakespear View Post
If the car is understeering on AND off-power, try using softer settings in the front ONLY if the rear is planting nicely. If the rear feels TOO planted, try using harder springs, or less toe, or moving the shocks to a more upright position. Maybe use more toe-out in the front, but yes, try the 35s in the front.
Thats exactly my plan, i though of reducing the front shock oil, at the moment i am running 35 allround with the medium springs now i will pop the soft infront what do you guys suggest as per oil or shall i use larger holes in the pistons?
Than will go for less toe in, in the rear.
Once i really managed to get more steering by setting the lower rear hing pin in the 2nd highest hole and turned a lot better but the rear was way to loose. Before it was set as default 2nd lowest.
Thanks once again
Ramon
speed6 is offline   Reply With Quote
Old 10-27-2010, 05:27 PM   #2492
Hmm, by raising that lower hinge pin to the 2nd highest hole you did raise the roll center, which would reduce traction. Too bad you found it too loose. Default settings is the 2nd lowest hole.
Where did you have the inner camber link position? Maybe you need the lower hinge in the 2nd highest position, but try and lower the roll center a little via the inner camber link. Did you also make the shocks flatter?
I think you may have been very close!
If you are using 35wt all round maybe go 30f/40r or just 40 in the back.
If the car feels good at a fairly slow speed, but one end seems to react/absorb bumps badly, then change the oils. I went softer in the rear (from 40 to 30) to help it drop easier under power and go better over bumpy sections, and it definitely worked.
Can you give me your current setup, Ill take a look at it and see what you could do to make it feel better. You can either send it via here, or through eMail: [email protected]
Car-less (Velox V10 or 733) // RB T10.5"+" (JB Modified) // Bluebird BMS-990DMG (St) & BMS-631 (T/B) // ATS 16% // Capricorn Wheels // Protoform
"70% of the time, it works ALL the time"
DJ_Shakespear is offline   Reply With Quote
Old 10-30-2010, 02:17 PM   #2493
Ok so today great day car became a lot better.
Recipe
went to 35 front and 40 rear
Shock oil up front 20 and rear 30
Spring front Kyosho soft, rear Kyosho medium
Roll center as stock setup
Rear upper rollcenter on B
diffs Front 50,000 Rear 10,000
Rear Toe 2 degree
Front To 2 degree
Now i need to fine tune a bit more the rear as its a bit way too loose.
Shall i try softer springs in the rear or a softer sway wire or shall i play with the rear upper roll center?
Also i thought the fronts 35 aren't going to survive but actually they are hanging well as much as when i used front 37 how come??
By the way i know there are some cheap belts that you can buy anyone recommends any?
Thanks guys will try and post a vid next week.
Old 10-30-2010, 07:10 PM   #2494
Well, I dont know of any other manufacturers that have belts compatible with the RRR, maybe somebody else can fill you in on that. I find mine last quite a long time anyway - I still have the middle belt from when I bought it!!
I would go 37s in the front, and raise the rear camber link to position 3. If that works well or you need a bit more grip, go to 2. I guess it depends on how the rear wheels cone or if you are chunking the tires. The way I combat tire chunking is just increasing the camber - on one track I was at, I think I had the rear set at 5 or 6 degrees!! The front was at 3-5 degrees as well!
If you find the front to have too much traction all round, try making the shocks stand up more/be more vertical. From what I know, front sway bar affects low speed grip and some high speed, the rear affects some low speed and more high-speed grip. More toe-in in the rear will stabilize the rear end on and off-power.
Old 10-31-2010, 09:49 PM   #2495
kai888's Avatar
Trader Rating: 17 (100%+)
where do you guys mount your transponder?
i mounted mine on the front ontop of the foam bumper, will it get damaged easily there?
kai888 is offline   Reply With Quote
Old 11-01-2010, 12:51 AM   #2496
No, that should be fine. I used to have mine there, but Ive since moved to to where the switch is above the steering servo. That's actually where it should be.
Old 11-01-2010, 01:01 AM   #2497
kai888's Avatar
hey mate, do you have a photo of where you mounted it?
cause i had to switch out my graphite bumper plate for a plastic one because it had the two holes for me to mount the transponder and i don't feel safe having it at the front.
Old 11-01-2010, 01:46 AM   #2498
Sure thing. I have the MyLaps RC4 PT, but im sure others will fit too.
Uploaded with ImageShack.us
Old 11-01-2010, 02:30 AM   #2499
kai888's Avatar
thanks DJ, i have the same transponder, i didn't know i could mount it underneath, originally i was going to mount it at same place as urs but on the top of that plastic piece but the onoff switch was there so it was a tight fit.
thanks man.
Old 11-01-2010, 03:00 AM   #2500
u need to clean up the wiring on that thing lol.
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 11-01-2010, 03:33 AM   #2501
Hehehe, yeah, I should, but it all holds there very well and doesn't move or get in the way of anything! I might have a look and see if there is any better a place I can put it all.
Old 11-01-2010, 04:04 AM   #2502
kai888's Avatar
since we're pointing out stuff on his car...... you need a enclosed receiver box, your receiver is exposed to the elements
Old 11-01-2010, 04:34 AM   #2503
[[john]]'s Avatar
Trader Rating: 24 (100%+)
  • Remove bottom of servo's.
  • De-Solder wire's.
  • Plug un-soldered wire into Receiver.
  • Temporarily place servo into position.
  • Route wire directly to servo and cut excess.
  • Re-solder.
  • Close servo.
  • Repeat on other servo.
As for the transponder you can't get inside, so I just cut the wire and re-joined once I had removed the excess.
I do the above on all my cars usually, I even sometimes open the ESC's so I can shorten the RX/Signal wire and remove the switch
[[john]] is offline   Reply With Quote
Old 11-01-2010, 04:35 AM   #2504
[[john]]'s Avatar
When are we going to see you racing at Keilor ?
Old 11-01-2010, 05:55 AM   #2505
I)arkness's Avatar
easier to just buy a bunch of new servo terminal plugs, as getting the wire back through the servos circuit board is a pain in the ass.
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
