Old 08-31-2008, 03:46 PM   #226
GMartinez's Avatar
Trader Rating: 85 (100%+)
Originally Posted by Novarossi View Post
Anyone recommend an aftermarket/spare screw kit for the EVO2?
Tony Screws?
RC Screwz?
FastEddy?
Thanks.
I use tony screws just under the chasis due to weight other than that titanium all around
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 08-31-2008, 05:16 PM   #227
CraigM's Avatar
Trader Rating: 34 (100%+)
Tony Screws?
RC Screwz?
FastEddy?
Thanks.
I cant remember if it's RC Screwz or Tony Screwz but one of them are not perfectly metric so strip easy with your 2mm driver. I've heard you can get an imperial driver in fine but I don't have one
Has anyone used the KM Racing carbon backed brake pads? I'm interested to know how they compare to the APP ones as they look to be a similar material
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 08-31-2008, 08:11 PM   #228
Arahawak's Avatar
Trader Rating: 32 (100%+)
Anybody had issues of the car understeering on one side than the other?
I have shaved the steering servo horn to have maximum clearance already so that it does not hit the tank and battery but I am still having understeer on the left.
Steering servo is new, length of steering rod is equal on both sides. Wheels are toed out 1 deg, I am having 100% steering EPA and 100% dual rate on my tx. I cant really figure out why.
The only thing i can think of is get a thinner servo horn.
Any ideas?
Support Bacteria - its the only culture some people have!
Arahawak is offline   Reply With Quote
Old 08-31-2008, 08:13 PM   #229
Arahawak's Avatar
I am also wondering if it is worth the bucks to get them or the APP ones.
They come glued... with springs.
Old 08-31-2008, 09:21 PM   #230
CraigM's Avatar
Any ideas?
Is the servo horn actually hitting anything? if not (sounds like you've dremeled the hell out of it) then that's not the problem. Have you checked the steering throw to each side on a setup station? Even with all the same settings left and right on the electronics that doesnt mean it'll be the same. If you've done that already then your car is tweaked, so check your shock lengths are all equal left to right, droop, roll bars, spring preload, etc. If you still have issues you'll need to stick it on a tweak station to get the preload spot on
Old 08-31-2008, 09:47 PM   #231
Arahawak's Avatar
the servo horn now looks really like a horn off a goat (literally)
It doesnt seems like its hitting anything.
I have checked everything as you mentioned before. I will change another servo just in case. I just realise my steering servo is making weird noises and it shaking by itself.
Old 08-31-2008, 09:47 PM   #232
GMartinez's Avatar
for those lookinf for the Evo2 I trhink brooklyn hobbies still has some instock
Old 09-01-2008, 06:42 AM   #233
The other option is the offroad ST-R brake pads, IFW324. I have been using these for years and they provide the best resistance to fading. I'm looking forward to getting the capricorn disc with the internal venting as well instead of the steel one I use today.
I believe they are the same possibly asbestos type material, no springs though but they are $35 too..
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 09-01-2008, 02:22 PM   #234
GMartinez's Avatar
I just got my capricorn brake disc thru murnanmodified.com looks sweet
Old 09-01-2008, 03:10 PM   #235
I see the euro affects the price of capricorn gear as badly here as it does through their own website. I may have to wait on that stuff until the economy gets a little worse on the euro side.
Old 09-01-2008, 07:38 PM   #236
barg's Avatar
Send a message via Yahoo to barg
Where have you mounted the ball on the steering servo arm? I cant remember the exact measurement but I had mine wrong when I first built it. I think I had it at 19mm instead of 17mm. I had to change servo horn to one that lined it up at the correct distance. It hit the top deck otherwise.
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 09-01-2008, 07:55 PM   #237
CraigM's Avatar
your servo horn should also be mounted on the spline so there is a perpendicular angle with the steering rod. A lot of people mount theirs straight on the servo and this makes the steering throw uneven
Old 09-01-2008, 08:05 PM   #238
Arahawak's Avatar
Expensive for a brake disc aint it?
Old 09-01-2008, 08:08 PM   #239
Arahawak's Avatar
CraigM, I mounted exactly as you had mentioned.
barg, does mounting the ball on the different sides of the steering servo make a diff? I had my link shorten abit more than what it mentioned on the manual. This for me to align the front wheels without touching much the trim on my TX.
Old 09-02-2008, 12:32 AM   #240
jeff1's Avatar
just a newbie doubt
I am bulding the front knuckle arm, mounting the blue cap ball of pillow ball. How tight you let it? In manual says to ensure smooth non-binding movement of pillow ball. I always worry about this. For example I can let the pillow ball free but with a small play and I also can set it for a almost 0 play but the pillow ball movements more rough but not draging .. it also moves free without bind. When assembly on suspension arm the, 2 ways moves free up down left right. What are you opnions?
That can sound gay but I'm trying to assembly as possible as I can lol
jeff1 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
