Old 08-02-2010, 03:47 PM   #2356
GMartinez's Avatar
Trader Rating: 85 (100%+)
1g or 0g is considered as gain automatically when moving locations on hole position placement
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 08-02-2010, 03:57 PM   #2357
Maddin21's Avatar
Can someone help me understand what does 0G or 1G means when setting camber angle.
You can adjust camber at 1G, so with the car standing on the setup board with wheels or setup system mounted...or at 0G with the car lifted with the setup blocks you normally use to adjust droop.
1G adjusts resulting camber when the car is on the track
0G adjusts min. camber...the resulting camber on the track is given by the ride height.
--- MARTIN ---
Maddin21 is offline   Reply With Quote
Old 08-02-2010, 05:17 PM   #2358
afm
afm's Avatar
--- MARTIN ---
Thanks Martin,
I found a "how to read data sheet" from Kyosho in which it states under Camber Angle the following:
Front: Value of standard chassis height is 0G, and the value of lowered chassis hight is 1G. 0G range = 0 to 1, 1G range = 1 to 2
Rear: Value of standard chassis height is 0G, and the value of lowered chassis hight is 1G. 0G range = 0 to 2, 1G range = 1.5 to 4
Still confusing to me, how do you interpret does numbers??
AFM
afm is offline   Reply With Quote
Old 08-02-2010, 07:35 PM   #2359
kai888's Avatar
Trader Rating: 17 (100%+)
Hey guys, can anyone tell me what colour is the softer spring?
kai888 is offline   Reply With Quote
Old 08-02-2010, 07:48 PM   #2360
el salvador's Avatar
Light Blue
ARC R8 X2/ Max RP9 or O.S. R2101 ,Capricorn LAB C02-TOP Elite R, ARC R11....
"Every Cemetery in Chicago Votes Democrat!"
el salvador is offline   Reply With Quote
Old 08-03-2010, 04:56 AM   #2361
rear end of the RRR with Capricorn diff and Xray belt!
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 08-14-2010, 10:56 AM   #2362
Hi I recently bought the new C spec spur gears, and the Evolva 2 speed shoes, and it seems to drag really badly when fitted.
The two speed shoes are clamped as tightly closed as they can get, so its not an adjustment issue.
Smacks of poor quality to me..
Is it ok to run?
Would the 2 speed free up after a few short runs?
rcrossco_1 is offline   Reply With Quote
Old 08-14-2010, 12:25 PM   #2363
Maddin21's Avatar
Is it ok to run?
Better to trim it with sandpaper or so as your 2-speed will shift very bad if you leave it as ist is.
Also do not forget to remove the material around the small set screws that adjust the 2-speed shoes distance.
Regards...MARTIN
Old 08-14-2010, 12:45 PM   #2364
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Is it ok to run?
You did change the 2-speed adapter as well didnt you? The RRR and the M3 adapter are not the same shape.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 08-15-2010, 11:55 AM   #2365
MikaR's Avatar
Happy with Evo 2
Qualis 9th, finishing 13/24
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 08-15-2010, 03:54 PM   #2366
Well the Evolva M3 shoes look identical to the standard RRR-WC shoes, apart from the fact they seemed to bind even more!
So in the end I went with the original 2 speed shoes that came with the original car, and they still bind a little bit.
What exactly is the difference between the 2 Speed adaptors then ?
They look identical to me!
The thing is that I am using a titanium 2 speed adaptor, and would rather stick with that than use the heavier Evolva one...
I shall run a bit of sand paper over the parts.
Oh one other thing.. I noticed that the springs on the Evolva 2 speed seemed to be much stiffer that the standard RRR-WC 2 speed springs... Which is another reason I went back to the older 2 speed shoes.
I hope you guys can shed some light on the differences between these parts.
Many thanks.
Old 08-15-2010, 08:56 PM   #2367
The internal area is shaped differently. I used a titanium adapter until I switched over to the M3 2sp as well.
I have compared them side by side and the adapters are different.
Old 08-23-2010, 07:53 AM   #2368
hi,
what would be the difference in having the roll center at A, B, or C? they would still be at the same angel wouldnt it? just would be a different camber setting?
Old 08-23-2010, 08:04 AM   #2369
Originally Posted by LiL_JaSoN View Post
hi,
the end result should be the same camber setting because you set it back to say 4 degrees, the shorter the link the more camber gain you get.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 08-23-2010, 08:29 AM   #2370
ah ok, so same roll centre, different camber gain.
what setting does everyone use? furthest out? middle? or furthest in.
edit; so what iv been reading, the more camber gain the more grip.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
