Old 07-03-2010, 12:17 PM   #2281
Originally Posted by GREGORY! View Post
Brian?
how about the weight for the front diffs?
47g front kyosho, titanium pins
27g front capricorn, plastic gears, alum pins (stock)
14g ybslow aluminum spool
25g kyosho oneway
as you can see, vs kyosho, the capricorn is at least 36g lighter in overall drivetrain mass. one time back in the day i took everything that spun besides belts, clutch and bearings (cvds, hexes, shafts, diffs, gears, everything) and compared xray vs kyosho. the kyosho evo wc at the time with titanium pins, titanium screws on the gears, basically all i could do.. was about 230g. Xray with all of their available lightweight parts (in dec 2008) was around 190g.
So I played with the #'s again since the 41t thing bothered me some and it's still raining.
lets say you are running the rrr stock, 23/55 and 16/60 gears 23t front pulley and 60/58mm tires.
0.87% more front drive
In contrast, lets say you run the 24t front pulley
3.33% more rear drive, you need 60/60 tires to be equal.
Lets say you run the 41t diff, same setup
1.53% more front drive with the 41t diff
0.85% more drive if you run less split, 60mm rears and 58.4mm fronts.
So really, true your fronts slightly bigger than the usual 2mm split and you are perfect. on my track we get massive rear tire wear so I will still cut 2mm and the car will just get better, and then worse later that it usually would in a 10 minute qualifier if I can go as small as 60 in the rear, might have to start at 61 or 62.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 07-04-2010, 02:34 AM   #2282
true front smaller or bigger? since there is more rotation in the rear now.
brian, are you coverting the front aswell?
or only rear?
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 07-04-2010, 02:41 AM   #2283
or only rear?
i wonder how much my drive chain weighs now.
Old 07-04-2010, 02:48 AM   #2284
or only rear?
What Brain was explaining if i understood him well and i believe he was really smart about it, is that in order to run the rear diff with one less tooth which obviosly it will shorten the rear drive ratio you will have to find another way to high up the front drive ratio by swapping the 23 spool with the 24th side belt gear which is normally used for rubber tires or equal sized tyres.
As i was reading the post our track also really give the rear tyres a beating would you consider try using the 24 teeth. I almost run 1.5 sets of rear with a trued fronts so by the end of the race the car ends up like a speed boat.
speed6 is offline   Reply With Quote
Old 07-04-2010, 02:54 AM   #2285
yes, i have discussed this earlier before starting the conversion.
1t wouldnt of mattered so much, and that we could use the stock 2mm split ratio rather then the 0mm ratio..
Old 07-04-2010, 06:47 AM   #2286
the 24 would make it worse, I like a car that is slightly forward driving but mostly neutral which is what the 24 does with no split (say 60mm tires front/rear). the 23 with a 2mm split is equal. using this 41t rear diff with 23 side pulley, you need to run larger fronts (1.1mm split) to allow the fronts to be bigger. like you said with the 1.5:1 rear/front wear ratio, you probably want to still cut at 2mm and the car will come in through practice and 2-3 minutes into the qualifier and be neutral at some point and then wear past where your car will go into more front drive.
I tried changing the 21t brake pulley, the 18t side/front pulleys and I couldn't come up with any ratios that make the car right except changing the rear side to a 19, and the front to a 24 which would make your tires 58.23mm and 60.00mm for equal ratios. Not really worth it to me.
I am using both front and rear capricorn diffs at the moment, gaining only 11g to go from a spool to a diff is well worth it in my book because of two corners on the worlds track. the real reason I've always run a spool was because it was 47g vs 14g and then I just got used to it and never gave the diff a second chance until IFMAR came up with that non-spool rule that got thrown out.
I'm going to clean my bearings if I can get some practice in next weekend, I can weigh everything then but I run the hollow steel shafts and evolva 2nd holder (heavy steel) so its not as light as it could be. I am guessing I should be in the 200g area though, maybe with the use of aluminum rear dogbones or something. I have aluminum axles for my cvds that I will probably qualify with as well since I will be running the lightweight version of the new Contact tire anyway. tire selection is probably one of the most important here, the pro-light version of twisters were good for up to 20g per pair depending what you used before.
Old 07-04-2010, 07:17 AM   #2287
leave it as stock .
as said earlier
1.95:1 (41t)
2.0 (42t)
0.05 is not going to make a massive difference with the rear tyre wear.
Old 07-04-2010, 12:43 PM   #2288
kyosho_ken's Avatar
Smile
front diff - is a direct fit, just need some shims (10x12) to make it wider or else it would be too loose.. front diff will also require you to run the rear cvds at the front. (lucky i had some spare)... otherwise if you run a spool, you can just do the rear diff...
rear diff - needed some dremeling as its too wide. i dremeled the bulkheads as you rarly change the bulkheads, and i can change rear diffs easier, rather than modifying 2-3 diffs to fit the bulkheads.
the rear diff is also 1tooth/1mm smaller, so you need to make new holes to make the belt tighter.
run capricorn diffs, and you will save 20-30g per diff (40-60g rotational weight). xray diffs will save you about 10-15g per diff.
cant wait to test this out.. titanium main/mid shaft, titanium 2sp holder, lightweight brake holder, capricorn clutch, capricorn diffs... thats going to be one light drive-chain.. i havent ran my car since iv changed the entire drive-chain..
my car looks like a nt1 now :S, only thing giving it away are the shocks.. which are soon going to prob be nt1 ones aswell.
just buy an xray or lab co1. the cap is a great car except tossollini shattering the rear diffs.
kyosho_ken is offline   Reply With Quote
Old 07-05-2010, 05:04 AM   #2289
maybe when im done with the kyosho.
Old 07-05-2010, 08:58 AM   #2290
ok front and rear diff is in and car is back together..
crap the rear diff was a effort to fit.. did'nt know it required so much work.. but in the end, i got it in.. hopefully take it to the track soon
Old 07-05-2010, 03:56 PM   #2291
Can't wait to hear some reviews about this drive train mod
Old 07-05-2010, 07:58 PM   #2292
wasnt happy with how the rear was spinning..
so i took everything apart and did some more dremeling..
now its smooth cant feel no friction and it will roll down anything.... all you can hear is just the bearings.
smoothest iv ever had my car actually.
also, 100k at the front, felt lighter than 50k which i had in the stock diff..
60k rear, felt around the same as the 20k i had.
Old 07-05-2010, 09:15 PM   #2293
front diff
rear diff
side view.
Old 07-06-2010, 05:24 AM   #2294
front diff
rear diff
side view.
I saw that your upper rear link is on the outside how come?
Also it seems you are running an xray tank with a modified upper tray, is it KM's?
Old 07-06-2010, 05:44 AM   #2295
huh? upper rear link on outside? im confused.
the xray top-deck is capricorn, which they sent to me for free.. the xray tank is more longer and flat. i also lowered it by a extra 5mm.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
