Old 07-01-2010, 10:26 AM   #2266
rowveg36's Avatar
Trader Rating: 21 (100%+)
did you do a lot of modification to get those xray nt1 diffs fit? would you mind explaining it... thank you.
rowveg36 is offline   Reply With Quote
Old 07-01-2010, 03:16 PM   #2267
they are almost direct fit. you just need to find 10x18mm bearings which is rather hard.
once you get the rear diff, you will see how you have to grind down the edges slightly because it is too wide (by 1mm or so) and I suggest you take the most length off the right side and then the rest from the left to help center the belt.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 07-01-2010, 03:42 PM   #2268
where do you find the bearings?
SebO is offline   Reply With Quote
Old 07-01-2010, 06:41 PM   #2269
front diff - is a direct fit, just need some shims (10x12) to make it wider or else it would be too loose.. front diff will also require you to run the rear cvds at the front. (lucky i had some spare)... otherwise if you run a spool, you can just do the rear diff...
rear diff - needed some dremeling as its too wide. i dremeled the bulkheads as you rarly change the bulkheads, and i can change rear diffs easier, rather than modifying 2-3 diffs to fit the bulkheads.
the rear diff is also 1tooth/1mm smaller, so you need to make new holes to make the belt tighter.
run capricorn diffs, and you will save 20-30g per diff (40-60g rotational weight). xray diffs will save you about 10-15g per diff.
cant wait to test this out.. titanium main/mid shaft, titanium 2sp holder, lightweight brake holder, capricorn clutch, capricorn diffs... thats going to be one light drive-chain.. i havent ran my car since iv changed the entire drive-chain..
my car looks like a nt1 now :S, only thing giving it away are the shocks.. which are soon going to prob be nt1 ones aswell.
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 07-01-2010, 07:18 PM   #2270
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Having built both, that would be a backward step. Kyosho shocks are renowned as the best in the business...
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 07-01-2010, 07:55 PM   #2271
i was being sarcastic there ..
thats why i kept the kyosho shocks.
Old 07-01-2010, 08:37 PM   #2272
occ
Trader Rating: 15 (100%+)
Maybe you should have purchased a NT-1 or Capricorn to start with.
occ is offline   Reply With Quote
Old 07-03-2010, 03:33 AM   #2273
iv had my RRR for a while and didnt want to change... it already had all the upgrades on it.
i received the capricorn top-plate and etc for free from capricorn.
only thing i did was 'upgrade' the diffs because i wanted to make the car better..
and i guess because its more unique no one has the same car.
Old 07-03-2010, 08:24 AM   #2274
So capricorn diffs are a direct swap for the kyosho evo 2?
Any part numbers please? and a good place to buy them
speed6 is offline   Reply With Quote
Old 07-03-2010, 08:53 AM   #2275
no, capricorn diffs are same as xray, just lighter, and it has plastic carbon gears and lighter cups.
to fit xray/capricorn diff, you will require to do abit of dremeling and shimming...
also you will need 10x18 bearings - these are very hard to find, unless you know someone who has them, these bearings are going to cost you atleast $10-15 each. you will need 4 if covering front and rear.
if you convert the front, you will also need to run the rear cvds as the standard front will be too short...
i spent hours working out different ways to fit the diffs
lucky i saved on abit of parts. if you were to do a full conversion it would cost
bearings - ~$10ea x4 = $40
diffs - xray ~ $49 x2 = $98 (according to amain), capricorn would prob cost more.
rear cvd - $38 (according to amain)
shims etc - $10
$186+ - not including postage and whatever extra it cost for capricorn diff.
if you run spool and do the rear diff only, it will cost you half of that minus the rear cvd's ($38)
Old 07-03-2010, 09:19 AM   #2276
vxb.com sells 10x18x4 bearings that you need at $5/each and you have to buy 10, you might want to pick up 10x12 shims as well to center the diff.
Old 07-03-2010, 09:30 AM   #2277
you can buy capricorn from team epic (trinity) in america at a cost of about $45 per diff complete.
here are some weights for the rear diffs
41g RRR diff, titanium shafts and drilled drive cups
35g Xray EC diff, drilled drive cups, not sure on the shafts, metal gears
25g Capricorn stock, drilled drive cups, plastic gears and aluminum shafts.
one note, I usually run 30k in my RRR diff. To get that same feeling I had to use 60k in the capricorn diff. The xray mold looks extremely similar to the capricorn mold, even the small molding dots are in the same place.
Unfortunately it's been raining non stop here in Houston so I have not been able to test anything other than it spins so the 1mm / 1 tooth size difference is unknown. the wheels rotates fewer rotations if you just spin the rear wheels and wait for the drivetrain to stop. I imagine this is the flywheel effect, being lighter it has less mass to continue its momentum.
Old 07-03-2010, 09:36 AM   #2278
ill be testing mine next weekend.. got 60k rear, 100k front (heaviest i had)
will also post pics of the set up next wk.
Old 07-03-2010, 09:51 AM   #2279
GREGORY!'s Avatar
Brian?
how about the weight for the front diffs?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 07-03-2010, 11:05 AM   #2280
The Capricorn rear diff has a tooth less aswell?
This mod is quite expensive, is it really that worth it?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
