Old 06-18-2010, 12:22 PM   #2221
Originally Posted by GREGORY! View Post
i thought that this had something to do with the level of compression the shock work.to explain if u have built the shock with 75% rebound the a short rod and will be that which work in the the area that go from α under pressured or neutral condition to a pressured oil condition.
from the other side,when you have build a shock with 30-40% rebound then a medium rod will be the "right" one.
i don't know if you can understand my english.
Your english reads well enough, just in my opinion I don't believe the car handles any different other than the shocks seem to last longer and be more consistent with the piston in the middle of the oil. I don't really adjust rebound much, I use almost dead shocks and rely purely on the viscosity of the oil to control the spring.
You are often at the bottom of the shocks travel (depending on droop and shock length) in a corner on the inside wheels, more often then you are at the top of the shocks travel since the springs carry the car after the load has been transferred in a corner. Only a bump would change this.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 06-18-2010, 12:32 PM   #2222
GREGORY!'s Avatar
nice Brian!
one more question,which model shock are u using?the rrr,evo or shimo?and how u compare them?i use the old rrr ones.(there is any thing that can do to improve them?the one bushing conversion set for the seals from capricorn maybe?i have notice that they have a little slop in the piston,a smaller diameter that the shock body with result a move right-left movement when the suspension is working,especial when i use the shocks in laydown location.
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 06-18-2010, 01:20 PM   #2223
nice Brian!
Unfortunately I can't really compare them, I am using the shimo shocks but my evo shocks were so old that even new pistons required that I used +50wt oil (which isn't the same as changing piston holes)
Due to our lack of piston choices (which changes the initial speed of the pistons movement) a set of older shock bodies would have some blowby on the sides of the piston changing a 1.1mm hole to 1.5mm or more (in feel)
If you can get some cheap shock bodies, start there with some new pistons otherwise the Shimo shocks are very nice and the coating will last longer than the bare aluminum from the past.
Old 06-18-2010, 01:40 PM   #2224
GREGORY!'s Avatar
because i don't have them near me at this moment,are 13mm all of them?
Old 06-18-2010, 03:34 PM   #2225
I believe so, the evo shocks are just from the evolva. all of the pistons fit the rrr/evo/shimo shocks
Old 06-18-2010, 04:01 PM   #2226
GREGORY!'s Avatar
thank u Brian!
Old 06-18-2010, 06:53 PM   #2227
what do you guys mean by difference length rods?
also if your planning on upgrading your old shocks to evo/evo2
you will need
-shock bodies (the outer diameter of the new one if thinner and is also longer... inner diameter is the same, therefore you can use the same internals)
-shock collars (as i said, it is thinner)
-plastic shock cups. (that sit at the bottom of the shaft to hold the spring in)
-and obviously new springs.
for this price, you might aswell buy the shimo shocks for a lil bit more. then you will get the velvet coated shock bodies, which they think is alot smoother, titanium coated shock shafts, and new o-rings, end cups.. etc
another alternative, you can upgrade your existing shocks
-buy the new springs
-reverse the shock collar (as one end has the wide groove for the shocks to fit in, as the new springs are not as big in diameter they wont fit, so you want to use the reverse side)
-and shock cups (old ones are again too big in diameter)..
you can also change the pistons they are only a few dollars.. the old piston holes are smaller. i think front is 1x 1.3piston, rear is 1.1. while the newer one runs 2x 1.2 fron and rear... but i have also seen some drive using the 1 piston at front etc.
i run the OLD rrr shocks at the front, and im waiting for places to get the shimo back in, so i can run shimo shocks in the rear only.. everyone is out of stock at the moment for shimo shocks.
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 06-18-2010, 07:12 PM   #2228
GREGORY!'s Avatar
when u will assemble the shimo shocks.the rear ones use the medium rod ends in length (if i am not wrong).
now about the replace of the shocks,since i already have the coating rods,and they whole shocks are in very good condition,the only think that i need to do is to find some pistons,maybe from another company to be more accurate in diameter,since these now move inside the body,
i will check the pistons from my serpent.
if i can't do something for that i will sell them an buy the trf shocks.they are cheap and very smooth.
Old 06-18-2010, 11:11 PM   #2229
i understand now, using the longer ends will push the piston up into the middle rather than it being at the bottom.. to be honest, i could NEVER get the same rebound on both shocks..
yeah pretty much the only difference is the shock bodies on the newer shocks.. the outter diameter is smaller..
if you want, you can also upgrade the springs to the blue ones.
i havent had a problem with the kyosho pistons?.. but i have had the 1hole piston crack as the hole is very close to the outside.
Old 06-19-2010, 01:31 AM   #2230
MikaR's Avatar
mika?which crf do you have?pipe?clutch set up?
Hi, have pretty much the latest model I think, bought it last year. Not sure if there are newer revisions of it.
RB pipe is this http://www.rc-cars24.com/index.php?c...t=E1751-198403
Clutch is the Evo 2 clutch (2D).
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 06-19-2010, 02:01 AM   #2231
i have decided to use the old laydown servo topplate, which i modified so the throttle servo sits in a extra 7mm, and steering servo a extra 2mm.
also shaved the side of the plate by atleast 8mm on the left, and 4mm on right.
fuel tank also lowered 2mm.
Old 06-19-2010, 03:22 AM   #2232
GREGORY!'s Avatar
Lil Jason post some pics!
nice mika!if it's the picco based i don't think that this pipe work well.if it's the old crf made in japan then this pipe must be very good!
Old 06-19-2010, 05:10 AM   #2233
MikaR's Avatar
Ok - have also the Orion pipe from last year, might try it out too
Old 06-21-2010, 02:04 AM   #2234
MikaR's Avatar
Just bought the APP02 brakes set for RRR. Carolinas R/C has a Kyosho blow out sale, this set costs only $20 bucks.. There's also plenty of Kyosho GT stuff available.. I bought some
Old 06-21-2010, 04:48 AM   #2235
RRR Xray Edition begins!...
got 1 problem already.. how the hell do i mount a receiver or any type of receiver box, etc.. as you can see, the side which is servo is mount (which is ussually where the receiver box fits).. has no lip, holes or anything to mount a receiver box.... i thinking just double siding tape the receiever to the side of the servo.
Pic of the car with the topplate and brake hub installed -
comparsion of the top plate a big difference!..
comparion of the RRR clutchbell compared to capricorn clutch.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
