Old 06-07-2010, 08:49 PM   #2161
Originally Posted by LiL_JaSoN View Post
still works.
i am still running the old 2sp clutch shoes and clutch shoe holder.
Thanks for the quick reply...just to confirm,,
Are you using the old clutch shoe and holder with the new 2nd spur gear (version C)?
Would you say that the shifting is just as smooth, worse, better? different adjustments?
Thanks!!
MH
mhavlena is offline   Reply With Quote
Old 06-07-2010, 09:39 PM   #2162
edit;
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 06-08-2010, 12:33 AM   #2163
is there a big difference over the shimo shocks?
i know there is a big difference in smoothness compared to the first generation RRR shocks vs the EVO/EVO2... i'v tried getting the old RRR shocks as smooth as the EVO/EVO2 but just cannot do it..
dont know why as the other difference between them is that the newer
-outside diameter is thinner.. but inside diameter is the same.
-shock body is slightly longer
-everything else is the same.
Old 06-11-2010, 07:59 AM   #2164
can someone tell me the difference between the FM622 and FM361 2nd speed shoe holder?
can you use the OLD FM361 with the new shoes?.. in the pics, they look like they are the same shape.. just a different part number.
Old 06-11-2010, 10:03 AM   #2165
the fm622 is from the evolva and matches with the C spur gears with the black looking inside
the fm361 matches the B spur gears with the aluminum looking inside.
i have used B and C gears on the fm622 on occasion and they felt the same. I used B and C gears on the fm361 and it seemed the same as well.
They are a different material so they have different adjustment points, the fm622 feels more like cheap plastic but seems to wear the same.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 06-11-2010, 10:21 AM   #2166
MikaR's Avatar
hi there, just received the atomic RX box with a cover from ebay seller, it is pretty nice, it adds protection well
now I'll just have to wait until skies are blu again and water has gone away from the track..
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 06-12-2010, 06:58 AM   #2167
Will the 2 speed shoe fit with both FM622 and FM361 shoe holder?..
i installed the old plastic pulley/brake puller on my car to lower the rotation mass.. i wonder how long the plastic brake pulley will last..
at the moment my car is weighing between 1640g-1660g
i added;
YBSLOW batt plate = 42g - existing plate (9g) = 33g
30g lead weight on left side of car to balance out with right side. = 30g
Old 06-12-2010, 07:40 AM   #2168
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
i added;
The shoe holders are different and you should match the shoes to the proper holder
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 06-12-2010, 08:47 AM   #2169
did you notice a big difference between the two 2sp shoes holder/shoes
they say that the newer one has a smoother engagment.. but alot of people said they cannot tell a difference.
3racing has a titanium Shoe Holder that looks intresting... but i believe its the old version
Old 06-12-2010, 09:35 AM   #2170
I didn't notice much of a difference. The 3racing titanium one is for the older shoes.
Old 06-12-2010, 02:12 PM   #2171
unfortunately its another one of those parts that doesn't last very long, i've tried a few in the past.
Old 06-12-2010, 02:35 PM   #2172
I used mine for two years
Old 06-12-2010, 06:03 PM   #2173
i added;
My experience:
The plastic 21Tooth pulley has never lasted me more than one 30 min heat. The teeth don't fail, but rather the pin (inside) breaks through the plastic from the first hole to the second hole, but generally, the second hole holds...not sure for how long because I would change it after every heat.
Old 06-12-2010, 08:55 PM   #2174
Originally Posted by mhavlena View Post
My experience:
You are talking about the 21t brake pulley I assume? I ran those for months at a time without ever having a failure.
Old 06-12-2010, 11:46 PM   #2175
This is one of the few parts I'll agree on the wear with you, you seem to get much more life than I do out of every other part though.
the plastic brake pulley gear is good for ages for me, I don't really even check them.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
