Old 04-29-2010, 08:50 AM   #2041
DS Motorsport's Avatar
Originally Posted by Brian Bosley View Post
Supposedly the composite gears are good for a day or two, I wouldn't trust them in a longer main but I am sure there are some out there that have had them for 5 years already and no problems. they don't weigh as much as the fluid..
The Capricorn gears last a lot longer as the 2 days you are saying.
I've had them in my car for 1200 laps now and not a single sign of wear.
I'm really impressed by the quality, thumbs up to Capricorn.
Other companies (Shepherd, Serpent) are testing them as well but they are experiencing a lot of failures.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 04-29-2010, 09:13 AM   #2042
MikaR's Avatar
Originally Posted by kyosho_ken View Post
Are the Tatanium pivot balls worth getting? I would assume that they are heavier than stock. I wouldn't doubt they are stronger.
They aren't necessarily stronger but lighter...
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 04-29-2010, 11:24 AM   #2043
YmeBP's Avatar
Trader Rating: 32 (100%+)
You save between 16 and 20 grams over the stock steel pillow balls.
Not sure about the stronger part.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 04-29-2010, 12:34 PM   #2044
kyosho_ken's Avatar
Smile KOOL!!
Lighter Is Better
I replaced the stock steel bb's with the acer ceramics and love the smoothness.. Kyosho Rocks.
kyosho_ken is offline   Reply With Quote
Old 04-29-2010, 12:50 PM   #2045
To date I have just lumped all plastic gears in the same category, apparently your month of testing them is positive.
now, any idea if they fit the huge kyosho diffs? capricorn and redrc seem to indicate the nt1 specifically and only.
capricorn does have some cool ultralite dogbones for the rear, thats probably worth more than these gears alone.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 04-29-2010, 02:09 PM   #2046
Don't have a clue if the gears will fit, you don't want to put small gears in a big diff housing because then you will need a lot thicker oil's to create any diff action at all.
The ultralite dogbones do break.
I snapped one last year when I was leading the race, so no more aluminum driveshafts for me.
But the diff gears will make a bigger contribution, you save about the same amount of weight but the momentum created by the diffs is much higher as that of the driveshafts. You can really notice it on braking, at my home track you need to brake very hard at the end of the straight, almost to a standstill while the car is going 105 KM/H, and now with the capricorn diffs and brakepad's I'm able to out brake pretty much everyone by a couple of car lengths, even the Shepherd car which is amazing under braking.
P1-RC.com
Old 04-29-2010, 02:17 PM   #2047
YmeBP's Avatar
I have some for sale in my shop and they are too small for the Kyosho diffs. I am working on something with Flying Fox for the Kyosho though ;-D. May be a minute but i'm working on it!
Old 04-30-2010, 06:36 AM   #2048
the capricorn drive cups looks good aswell..
wonder how much lighter they weigh?
LiL_JaSoN is offline   Reply With Quote
Old 05-01-2010, 06:10 AM   #2049
MikaR's Avatar
Interesting..
..but seriously, if you are in one tenths of seconds in each lap, I would start wondering about hip-hop parts.. otherwise just drive
I also noticed that with standard servos, nimh pack and untrued tires my car weights 1700 grams which is the minimum weight over here.. so a lipo pack and high voltage servos are really not a necessity...
Ti screws, Ti pillow balls, Evo 2 parts and a front spool will get you there..
Old 05-03-2010, 08:48 AM   #2050
Originally Posted by MikaR View Post
Interesting..
yeah thats about right, i run a 58g battery tray and nimh but small servos to balance the car since it is light on the pipe side. still get into the 1670 range so I use a lot of weight to get to 1725.
Old 05-03-2010, 09:10 AM   #2051
MikaR's Avatar
That's a good tip re the brass battery tray and lightweight servo's.. thanks.
Old 05-05-2010, 05:28 PM   #2052
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default clutch
is the shimo clutch a swing weight clutch like the sirio
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 05-05-2010, 05:33 PM   #2053
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Yep... works pretty well.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 05-05-2010, 06:04 PM   #2054
Default clutch
what shoe comes with it and is it good with the three d i always used the grey with no issues
Old 05-05-2010, 06:24 PM   #2055
Default clutch
whats the part number and also are the new shocks a notable difference
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
