Old 04-26-2010, 02:59 AM   #2026
Originally Posted by MikaR View Post
great... what did you change? (other than the spool)
try softer tire compound, 35 shore maybe?
will defently need softer compound, i was running 40/42. Will goto 35/37. Also going to change down top to -3 (is at -4 atm).
Would probley benefit if i had a heavier car aswell,.
changed
front;
diff - one way to spool
toe in - 1 out
camber - 1 in
rear;
camber - 3deg in
toe - 2 deg in
LiL_JaSoN is offline   Reply With Quote
Old 04-26-2010, 08:53 AM   #2027
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default rear toe and camber
changed
front;
toe in - 1 out
camber - 1 in
rear;
camber - 3deg in
toe - 2 deg in
Toso always ran 3.5 degree toe in and 4 to 5 camber and that was with very good traction if you have medium traction you definitely need this type of set up
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 04-26-2010, 06:52 PM   #2028
what do you recommend at the front?
Old 04-26-2010, 09:26 PM   #2029
Default front
2 degree camber middle shock position remember if you have on power push running softer rear tires can cause that
Old 04-27-2010, 02:31 AM   #2030
MikaR's Avatar
My Evo 2 ready for the season..
More photos here
Ti screws, shafts, pillow balls... lipo RX, Hitec HV servos, RB V12 Rody, RB 2659 pipe...
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 04-27-2010, 03:04 PM   #2031
Chickentrader's Avatar
More photos here
This car needs an airfilter!
Kindest regards,
Lars.
P.S. Do you race in the winter in Sweden, and do you race under wet conditions?
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 04-27-2010, 05:51 PM   #2032
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Default Wire arrangement
Not sure if it matters to you, but u can get a nicer look if you route all ur wires behind the thrt servo between tht and the battery, with zip ties and after u plug them in pub a small zip on em to keep em all together, nice n neat! Just a suggestion........
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 04-27-2010, 06:27 PM   #2033
More photos here
What type of Lipo did you use, and where can I get some?
Kindest regards,
Lars.
Old 04-27-2010, 10:14 PM   #2034
MikaR's Avatar
Thank you! I will check this out..
Lipo is from A-main.
Air filter (novarossi ins-box) is off just for the photos
Racing only short course and ep sedan in winter time...
Old 04-28-2010, 04:05 PM   #2035
RC MARKET's Avatar
Nice photo , but heatsink some bigger !
RC MARKET is offline   Reply With Quote
Old 04-29-2010, 12:07 AM   #2036
Originally Posted by jiggamacdaddy View Post
Does anyone know if the composite diff gears from the capricorn will work in the evo 2?
also wanted to know this.. the xray compsoit diff gears.
i need a new top deck.. wondering i should use the evo2 one or get a nt1 tank one.
Old 04-29-2010, 05:38 AM   #2037
Default tank
do you want to run a kyosho or an xray?
Old 04-29-2010, 05:40 AM   #2038
a kyosho of course.. but just wanted to know about the gears as im going to build a front diff and want to make it light.
as for the top plate, i need a new top plate as mine is worn out, so deciding what to replace it with.
Old 04-29-2010, 08:29 AM   #2039
Supposedly the composite gears are good for a day or two, I wouldn't trust them in a longer main but I am sure there are some out there that have had them for 5 years already and no problems. they don't weigh as much as the fluid..
the km top deck is pretty nice (so is the capricorn if you can get it at a reasonable price) since the nt1 (especially the newest one) tank is just better than the kyosho tank. it seals better and you dont have to replace the seals plus it fits lower in the car.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 04-29-2010, 08:44 AM   #2040
kyosho_ken's Avatar
Smile Titanium Pillow balls
Are the Tatanium pivot balls worth getting? I would assume that they are heavier than stock. I wouldn't doubt they are stronger.
kyosho_ken is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
