Old 04-16-2010, 11:01 PM   #1996
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default pop out
Originally Posted by Goldenspec1 View Post
I own a Os vzr2 21. It starts up fine idle great, however two problem im having, when i increase the speed it it cuts off. Also the throttle body pope up from the engine block do to increased compression . I tried tighting it but it's still loose. Do i need a new throttle body,washer or maybe silcone part or new engine. It reacts to the needle adjustments just fine, im lost please reply
do you mean the whole carburator pops up out of the engine? usually if the motor cuts off when throttled its too lean on the high end needle but if your carburator is loose, you have to fix that first
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 04-18-2010, 06:38 AM   #1997
is it me or is the front belt alot tighter than the rear belt?
the rear somes to roll freely and smoothly while the front belt seems very tight.
LiL_JaSoN is offline   Reply With Quote
Old 04-18-2010, 07:13 AM   #1998
Default front belt
when you put in the front ecentric hubs let them turn all the way forward against the bulkhead, this will give you a loser fit but still plenty tight,
Old 04-18-2010, 10:07 AM   #1999
i fixxed it, i installed a new belt.. my old belt must of shrank some how :|.
either that or my middle shaft bulkhead was buckled cos i installed a new one of that too.
Old 04-19-2010, 08:03 AM   #2000
YmeBP's Avatar
Trader Rating: 32 (100%+)
Blew out 4 second gears yesterday for some reason, changed to a new pinion, check bearings, checked shaft, checked chassis tweak, checked rear stiffener, checked for rocks, checked air gap .... it works great for about 3 laps then BOOOOM WHEEEEEEEE no second .
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 04-19-2010, 08:26 AM   #2001
blount's Avatar
Did this start to happening after a hard hit? When you say checked did you you replace? If not, you might want to start one piece at a time. I've never had this problem in the two years I've had the kit. Someone else might want to chime in. But, I would look real hard at replacing the chassis and, or the motor mount first.
Serpent America
Desoto Racing
Runner Time Fuel
Matrix Tires
SRC
blount is offline   Reply With Quote
Old 04-19-2010, 08:34 AM   #2002
whats everyone running in the front? diff, one way, spool?
im currently running a one way.. wanna switch to a spool.
Old 04-19-2010, 09:06 AM   #2003
blount's Avatar
What's your track conditions?
Serpent America
Desoto Racing
Runner Time Fuel
Matrix Tires
SRC
Old 04-19-2010, 09:15 AM   #2004
YmeBP's Avatar
Now that you mention it, I did take a hit, not a particularly hard hit, just tucked my body didn't think anything of it. I'll pull the car down tonight and check. I have to change engines anyway.
Old 04-19-2010, 11:37 AM   #2005
blount's Avatar
The best way to check the chassis is remove everything from it. Then lay it on your set-up board servo side down. That's the unscratched part of the chassis. If it has a hop, it's tweaked.
Serpent America
Desoto Racing
Runner Time Fuel
Matrix Tires
SRC
Old 04-19-2010, 12:38 PM   #2006
racer301's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to racer301
Default Try changing the 2speed hub
racer301 is offline   Reply With Quote
Old 04-19-2010, 12:41 PM   #2007
racer301's Avatar
both front and rear tention should be loose
Old 04-19-2010, 12:48 PM   #2008
YmeBP's Avatar
2 speed hub meaning the black 2 piece shoe part?
Old 04-19-2010, 01:30 PM   #2009
racer301's Avatar
No that's the 2 speed shoes but replace that too (install a brand new one) I think it's the same one as m3 evo shoes
2speed metal hub is the piece where you attach the spur gear with 3 screws.
I had the exact same problem with my mugen mtx4r and that was why I switched to rrr. I have not blew a 2 speed ever since. I mean not once.
Kyosho tranny is so much smoother/better then mugen.
Old 04-19-2010, 02:13 PM   #2010
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
And as Chay mentioned, make sure to look at your engine mount. Every once in a while they will break and that can cause your gear stripping problem. This car just doesn't do that for no obvious reason.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
