Old 03-22-2010, 08:10 PM   #1981
YmeBP's Avatar
Trader Rating: 32 (100%+)
Question about shock oil:
How do I use the shock oil to tune the performance of the Evo 2? Right now i have lots and lots of traction and i was thinking of going up in weight to slow the speed of the rolling of the car. Is this the right direction?
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 04-07-2010, 09:21 PM   #1982
Does anyone know if the composite diff gears from the capricorn will work in the evo 2?
jiggamacdaddy is offline   Reply With Quote
Old 04-07-2010, 09:24 PM   #1983
you can try that but usually i would mess with the roll centers as that has a dramatic effect on the rotation of the car.
Old 04-08-2010, 11:38 AM   #1984
YmeBP's Avatar
I have some in stock and they look too small i'll have to measure to be sure. The lightweight diff fits well though, and is very similar in design to the sirio/shimo clutch.
Old 04-08-2010, 11:50 AM   #1985
so the whole capricorn diff will fit? also does anyone know where i could find shimo parts? Im having no luck....
Old 04-08-2010, 02:11 PM   #1986
YmeBP's Avatar
the diff is the same as the nt1 and i don't think it will fit without major work. Shimo parts are out of stock all over including kyosho themselves. I should have more parts in stock in a few weeks when they replenish.
Old 04-08-2010, 06:21 PM   #1987
lil-bump's Avatar
Trader Rating: 83 (100%+)
Shock oil tuning is for subtle changes. I would first look at tire selection; try a harder shore
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 04-09-2010, 02:55 PM   #1988
okay then well let me know when you get the parts in as i would like to convert my car to the shimo.
Old 04-10-2010, 04:35 AM   #1989
anyone have a spare evo2 topplate???
LiL_JaSoN is offline   Reply With Quote
Old 04-10-2010, 09:45 AM   #1990
kyosho_ken's Avatar
Default shimo 4 sale
Kyosho V one rrr evo .2 shimo edit. For sale. New chassis plate. I have the old one it isn't tweaked, I just hate scratches. All the options Frp batt. plate, frp middle plate, much more. $300 in spare parts in the bag. $550.00 rolling chassis. Includes Oneway and oil gear diff/solid.
kyosho_ken is offline   Reply With Quote
Old 04-14-2010, 08:36 AM   #1991
Hi I hope someone can be so kind as to answer a question I have.
Are the new EVO2 spur and pinion gears backwards compatible with the V1RRR WC edition ?
I know that the 2 speed shoes changed to the evolva ones, does this mean I have to purchase the evolva 2 speed, or is it pretty much the same as the 2 speed in the RRR WC edition?
Thanks!
rcrossco_1 is offline   Reply With Quote
Old 04-14-2010, 08:42 AM   #1992
nikoskar's Avatar
Thanks!
You can use them.
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 04-15-2010, 07:23 AM   #1993
Ok thanks, much appreciated.
Just one other thing... you know the rear adjustable sway bar, that rubbed on the rear belt, did Kyosho ever resolve this and make a new one that didnt have this problem?
Cheers.
Old 04-15-2010, 09:40 PM   #1994
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default dremel
Cheers.
you can just dremel the bottom flat so it does not rub the belt, you do have to take alot off but it doesn't hurt with the performace of the sway bar have never had a rear belt failure
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 04-15-2010, 10:33 PM   #1995
Unhappy Problem with Os vzr2 engine
I own a Os vzr2 21. It starts up fine idle great, however two problem im having, when i increase the speed it it cuts off. Also the throttle body pope up from the engine block do to increased compression . I tried tighting it but it's still loose. Do i need a new throttle body,washer or maybe silcone part or new engine. It reacts to the needle adjustments just fine, im lost please reply
Goldenspec1 is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
