Old 03-05-2010, 08:50 PM   #1951
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Chickentrader View Post
The Shimo is the same car, but with the components you would probably upgrade to in the original build. One thing is different however; Kyosho has come up with new new designed shockies, and this would hopefully fix the matter of all the leaking shockies that is usually a feature of Kyosho. The Shimo also has universal rear driveshafts; something that I wouldn't have upgraded to if I had built a standard RRR, but there are probably different opinions about this. I would stay with the old dogbones at the rear though.
All in all; the Shimo is just an upgraded RRR.
Kindest regards,
Lars.
I have an evo 2 wc it has universals in the rear. I've never had one of my shocks leak on my evo or evo 2
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 03-05-2010, 09:31 PM   #1952
Chickentrader's Avatar
Originally Posted by Novarossi View Post
Lars or others...
Does the Shimo come standard with the softest springs (light blue) or the middle blue?
On the exploded diagram of the Shimo it shows the light blue code, but in the manual it shows the medium blue.
Our Shimo came with 1.6 mm light blue springs; identical to MTX4 standard springs. But you're right; the parts list in the manual show blue 1.7 mm springs.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 03-05-2010, 09:51 PM   #1953
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Kindest regards,
Lars.
My shocks never leak.
Novarossi: I actually checked.. My Shimo came with Lt Blue springs
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-08-2010, 09:36 AM   #1954
jjmudd's Avatar
Default Great Deal
Look here for a great deal....
http://www.rctech.net/forum/r-c-item...s-o-penty.html
email, [email protected] or contact through pm
jjmudd is offline   Reply With Quote
Old 03-08-2010, 09:43 AM   #1955
Carlos's Avatar
Default Leaky Shocks
A few years back I had the first gen RRR wc edition and my shocks never leaked either . Too bad it was stolen or I'd still be running it!
Carlos Marcano a.k.a Sponge Bob
R.M.I. Racing
Xray NT-1
Spec-R R1
Carlos is offline   Reply With Quote
Old 03-08-2010, 10:48 AM   #1956
mbrasilracing's Avatar
Send a message via MSN to mbrasilracing
I apreciated a lot EVO2
SANDRO MARTINES
www.m-brasilracing.blogspot.com
www.twitter.com/sandro_martines
mbrasilracing is offline   Reply With Quote
Old 03-09-2010, 05:27 PM   #1957
jjmudd's Avatar
Complete parts list with package:
3 Racing Parts:
1. V3R-014 Front Graphite Upper bumper
2. V3R-014A Front Graphite Upper bumper (silver)
3. V3R 023 Rear graphite Shock Tower
4. V3R-010 Titanium Turnbuckle Set
5. V3R-030 Side Stiffener
6. V3R-027 Graphite Battery Base Holder
7. V3R 020 Rear Bulkhead Cover (aluminum)
8. V3R-035 Titanium Suspension Pin Set
9. V1E-012A Titanium Front Bulkhead Shaft
10. V3R-013 Front Graphite Shock Stay
11. V3R-007 Front bulkhead Cover (aluminum)
12. V3R-009 Titanium Flange Ball 5.8 (8 piece set)
13. V3R-026 Radio Tray Middle Mount (aluminum)
14. V3R-025 Aluminum Pulley (23 teeth)
15. V3R-011 Delrin Screw Cap 10mm (8 piece set)
16. V3R-036 Titanium Flange Ball 6.8mm (4 piece set)
17. V3R-008 Titanium Ball stud 4.8mm (9 piece set)
19. KV-016 One Way Supr Gear Hub
Kyosho Parts List
1. VZ222-600 frt lwr suspension shaft X 2
2. VS031-300 linkage set
3. FM360-800 2nd shoe set X 2
4. VZ084S-1300 Front stabilizer set (soft)
5. W0143-450 Aluminum Coller X 2
6. FmW11-1700 Clutch Shoe Red
7. VZ234-700 Drive Belt 180 X 3
8. VZ233-900 Drive Belt 384
9. VZ232-700 Drive Belt 189
10. VZ237-1000 Drive Belt 387 (for 24 tooth pulley)
11. VZ114-56-750 2nd Spur Gear 56T
12. VZ115-20-500 1st gear 20T
13. VZ217-1.4-300 Rear stabilizer bar (1.4mm)
14. VZ012-900 Diff gear set (aluminum)
15. VZ221-400 5mm post (2 piece set)
16. Z210-700 Rear suspension arm set X 3
17. VZ201-600 Front knuckle arm X 2
18. VZ209-600 Rear Bulkhead X 3
19. VZ220-300 Brake disk X 2
20. W5106-450 Shock equalizer parts X 2
21. 92985-400 Hard brake pads X 2
22. VZ217-2.0-300 Rear stabilizer bar (2.0mm)
23. FMW10-1200 clutch shoe grey
24. VZ214-17-500 1st gear 17T
25. BS107-550 Bevel shaft
26. VZ116-28 2nd gear 28T
27. W6007-400 Shock diaphragm (white/8 pcs)
28. VZ217-1.8-300 Rear stabilizer bar 1.8mm
29. FM359-1300 1st housing (aluminimum with one-way bearing)
30. VZ113-60-400 1st spur gear 60T
31. LA43-300 5.8mm Ball End
32. VZ206-600 Front suspension arm set X 3
33. W0142-450 Aluminum coller (2mm)
34. VZ095-600 3D clutch disk
36. VZ201-1-600 Front knuckle arms 1 deg kingpin X 2
37. VZ201-2-600 Front knuckle arms 2 deg kingpin X 2
38. W5107 o-ring set (shocks) X 3
39. VZ091-1200 3D Clutch weights
40. VZ205-600 Front bulkhead X 2
41. VZ213-800 small part set
42. VZ202-600 rear hubs X 2
43. w6006-400 hc diaphragm (black/8 pcs)
44. VZ29-300 Brake shaft set (aluminum) X 2
45. 92696-300 brake pad set X 2
46. VZW052-1500 Carbon Front shock stay
47. FM328-2-600 Washers (M3X12mm)
48. VZ114-55-750 2nd spur gear 55T
49. VZ079-600 front cup joint (for one-way)
50. VZ087-300 muffler stays
51. VZ113-59-400 1st spur gear 59T X 2
52. 920150-01-300 sponge packing for fuel tank
53. VZ213-1200 light weight clutch bell
54. VZ217-2.3-300 rear stabilizer bar 2.3mm
55. V-One front urethane foam bumper
Open Parts Bags / Misc. Items
1. Adjustable blade front sway bar
2. used drive shaft rear X 2 (one broken but drive shaft ok)
3. complete light weight 3D clutch assembly gears mounted for quick change
4. misc. screws/bit/ bolts
5. misc. pulleys (plastic and aluminum)
6. standard clutch bell
7. used fuel tank
Anything with a "X 2" or "X 3" behind the item means there are either 2 or 3 bags. Plus you are getting the RTR V1RRR that is race proven with servos and a CRF WASP engine as well as an X5 back up engine and RD logix pipe. All in all.....one hell of a deal.
Old 03-10-2010, 08:49 PM   #1958
relly nice car
rusty4768 is offline   Reply With Quote
Old 03-11-2010, 02:02 AM   #1959
MikaR's Avatar
Guys,
how important do you consider a tire truer ? So far have been running with tires out of the box, but I know it's not optimal. A truer is a must for the best performance ?
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 03-11-2010, 02:55 AM   #1960
rmdhawaii's Avatar
Originally Posted by MikaR View Post
Guys,
Ideally, yes. Ever notice that your rears wear faster than your fronts? You really don't want your rears smaller than your fronts for a number of reasons. Overdrive, rollout and split are three terms you want to become very familiar with.
Here are some threads on the subject:
http://www.rctech.net/forum/nitro-ro...main-runs.html
http://www.rctech.net/forum/nitro-ro...it-theory.html
http://www.rctech.net/forum/nitro-ro...ive-split.html
http://www.rctech.net/forum/nitro-ro...es-1-10-a.html
http://www.rctech.net/forum/nitro-ro...re-truing.html
And here is a great article on how to true tires:
http://www.rc411.com/pages/howto.php?howto=25&page=4
Here is a gear ratio calculator that you'll need as well, but you need to modify the numbers for the RRR, as this is for a 720:
http://nitrokb.netne.net/720/front%2...rive%20720.xls
I'm sure you'll have more questions. The above is just a start.
Hope this helps.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 03-11-2010, 05:23 AM   #1961
MikaR's Avatar
Allright, thank you very much. I just bought a truer (3Racing).
Will learn this stuff.
Many thanks again!!
Old 03-11-2010, 12:10 PM   #1962
Many thanks again!!
Good choice; you bought yourself a great tire truer. The automatic 3Racing tire truer even allows you to cone the tires if you should want to.
Kindest regards,
Lars.
Old 03-11-2010, 12:51 PM   #1963
Kindest regards,
Lars.
1 degree all around is a great starting point if your setup already puts camber in them, it sort of pre-cambers the tire for the race.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 03-11-2010, 02:42 PM   #1964
Hope this helps.
This will probably confuse the issue, but the Shimo actually has a lower front rollout than rear according to my calculations. All other belt driven cars that I have done this to has a higher front rollout; both 1/8th and 1/10th scale. The calculator that I use can be downloaded from http://chickentrading.com/viewtopic....593&p=765#p765 .
It is unfortunately a requirement to register before it can be accessed; sorry about that.
Kindest regards,
Lars.
Old 03-11-2010, 02:50 PM   #1965
RC MARKET's Avatar
This moment still is easy to drive & fast GP car !
RC MARKET is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
