Old 03-02-2010, 05:44 AM   #1936
MikaR's Avatar
Shimo in my opinion. New parts and a front diff out of the box.
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 03-02-2010, 05:52 AM   #1937
Send a message via ICQ to CivicTuning
Thanks MikaR !
CivicTuning is offline   Reply With Quote
Old 03-02-2010, 05:53 AM   #1938
And build quality and overall quality ok ?
I am very strict in that area Everything must fit perfectly.
Greetz,
Christoph
Old 03-02-2010, 07:07 AM   #1939
MikaR's Avatar
Yes! Kyosho is known for that on their high-end products, like the RRR shimo. (I haven't build one myself but I'm pretty sure it's top quality)
Old 03-02-2010, 07:16 AM   #1940
You have built an RRR evo 2, no ?
Greetz,
Christoph
Old 03-02-2010, 08:11 AM   #1941
MikaR's Avatar
Yes, I have. And many many other Kyosho cars
Old 03-02-2010, 08:18 AM   #1942
Good to know
Greetz,
Christoph
Old 03-02-2010, 08:42 AM   #1943
YmeBP's Avatar
Trader Rating: 32 (100%+)
Originally Posted by Scott Fisher View Post
I used the K-factory pads for the first time and had quite the opposite experience. The worst brake fade I have ever experienced. Over the course of a 20 minute main I turned up the brakes 25% and still had virtually no brakes. I am going back to my Kyosho APP pads. In 3 years of running the APP pads I never had the kind of fade that the K-factory pads had today.
I'm also using a Kfactory slotted vented rotor along w/ the pads. Do you have a part number on the kyosho pads? and do you run a spring in between your calipers?
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 03-02-2010, 12:19 PM   #1944
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I ran the Shimo brake rotor. I did use the springs that came with the K-factory pads.
The kyosho pads are: APP02-2
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 03-05-2010, 10:19 AM   #1945
SQC049's Avatar
Trader Rating: 16 (100%+)
Hey guys, I'm new to nitro touring cars and I have a RRR WC. Does anyone know where I can find a good starting setup?
Thanks.
Andrew Parente
| Serpent America | Picco | AKA | LRP America | Desoto Racing | PT Racing Oils | TQ Wire |
SQC049 is offline   Reply With Quote
Old 03-05-2010, 10:35 AM   #1946
blount's Avatar
Thanks.
Use the stock set-up in the manual. Then make your adjustments according to the track conditions.
Serpent America
Desoto Racing
Runner Time Fuel
Matrix Tires
SRC
blount is offline   Reply With Quote
Old 03-05-2010, 01:27 PM   #1947
mosaics12's Avatar
i was thinkin of getting a use RRR WC now the question is can i convert it to shimo edition or can i use the parts from shimo. im not goin to convert it now just incase i break a parts.
kyosho inferno GT2 pro.. kyosho ultima sc.. HPI savage X.. tamiya m-05 pr
mosaics12 is offline   Reply With Quote
Old 03-05-2010, 02:29 PM   #1948
Chickentrader's Avatar
The Shimo is the same car, but with the components you would probably upgrade to in the original build. One thing is different however; Kyosho has come up with new new designed shockies, and this would hopefully fix the matter of all the leaking shockies that is usually a feature of Kyosho. The Shimo also has universal rear driveshafts; something that I wouldn't have upgraded to if I had built a standard RRR, but there are probably different opinions about this. I would stay with the old dogbones at the rear though.
All in all; the Shimo is just an upgraded RRR.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 03-05-2010, 02:40 PM   #1949
Thanks.
Ask your club members, standard setups are usually a good starting point. Standard setups may not work well on bumpy tracks that don't have good traction sometimes however. Loosen the rear up if the track is bumpy; disconnect the rear sway bar to make the rear suspension independent, increase rear droop and set up the rear shockies for maximum up and down travel of the arms. Make sure that you only make one change at the time, never more before you try it out. You will not know which one works, and which one doesn't otherwise.
Kindest regards,
Lars.
Old 03-05-2010, 02:48 PM   #1950
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Lars or others...
Does the Shimo come standard with the softest springs (light blue) or the middle blue?
On the exploded diagram of the Shimo it shows the light blue code, but in the manual it shows the medium blue.
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
