Old 12-24-2009, 02:07 PM   #1846
rmdhawaii's Avatar
I just plowed through the first 67 pages of this thread and it's just amazing...
... the drama!!!
... the confusion!!!
... the questions!!!
I'll have to read through the rest of this later...
Kyosho seems to be squeezing all of the mileage it can out of this puppy and these incremental changes seem to make sense, but... is anyone actually faster in this car than their previous RRR? If so, exactly what is making the difference around the track?
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 12-24-2009, 05:11 PM   #1847
YmeBP's Avatar
Trader Rating: 32 (100%+)
... the drama!!!
The irony here is that i have an evo wc and an evo 2 wc and i found that i'm not good enough to handle all the steering i have in the evo2! I am much more consistent with the older car BUT a buddy of mine is about 1 second/lap faster with the new car than with the older car.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 12-26-2009, 05:50 AM   #1848
Default rear diff joint wobble
Has anyone had any trouble with the rear diff joint not being straight? (r/h side).
built a 2nd diff and its not straight either
Any ideas???
Keanas is offline   Reply With Quote
Old 12-26-2009, 08:05 PM   #1849
amyana3RWC's Avatar
ok tq
amyana3RWC is offline   Reply With Quote
Old 12-27-2009, 03:18 AM   #1850
MikaR's Avatar
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 12-29-2009, 10:40 PM   #1851
racer301's Avatar
Trader Rating: 18 (100%+)
Send a message via AIM to racer301
Default it depends
you know expert drivers drills a bigger whole into it to make the weight lighter? the whole point is to make the clutch hit hard on a high bite track...
and vise versa
Originally Posted by Chaya View Post
Hi Guyz,
Would there be any difference on the clutch performance if 4 pcs of FM429 weight will be installed. As per manual, the pix shows only 2 pcs.
I just bought the weights & it has 4 pcs in it. im planning just to put it all.
Thanks in advance,
George
racer301 is offline   Reply With Quote
Old 01-01-2010, 01:24 PM   #1852
rmdhawaii's Avatar
I had a chance to go through the rest of the thread today and I'm wondering, for those of us that have the original RRR WC, what the Evo2 will do for us in terms of the performance on the track.
Hands down, the Evolva shocks are an improvement and that came with the Evo. That's a definite upgrade.
The chassis changes seem to be another improvement - which the skilled owner can do himself with a dremel. But, is it possible to just work on the setup and get the same results? Are the chassis changes just a crutch for someone that isn't quite up to the nuances of setup changes? BTW... Does anyone know if you can just buy a Evo2 chassis and just drop the original parts on it??
We can't just drop on the top deck of course - that requires just too many parts.
Zero offset wheels - Some of us switched over to zero offset years ago.
And the clutch parts and spur gears... hmmm... I think you fall in either one of two situations:
(1) Your lap times are super consistent and you need to shave off a few tenths of a second.
(2) Your lap times are not very consistent so what's a few tenths of a second anyway.
So I'm thinking the original RRR WC (with Evolva shocks and maybe the chassis changes) is still good to go for the average club racer until his lap times are consistent, but that's just my opinion of course. What this also means is that a used original RRR WC is still a good buy for anyone.
Anyone else have any thoughts on this?
BTW.. I own and two fully track ready original RRR WCs, each with various types of upgrades
Old 01-01-2010, 02:47 PM   #1853
YmeBP's Avatar
So far I've found the difference in the two cars being the amount of steering they have. The evo2 has quite a bit more steering both on and off power no matter how crappy your setup is than the evo1 wc.
I've run them both back to back on the same track.
Old 01-02-2010, 07:28 PM   #1854
Does anyone have the part # for the rear stabilizer? I just need the blades not the hole thing.
Thanks for the info,
Joe
Joe Maxey is online now   Reply With Quote
Old 01-02-2010, 07:38 PM   #1855
Maddin21's Avatar
VZW-204-01 (blades only)
--- MARTIN ---
Maddin21 is offline   Reply With Quote
Old 01-03-2010, 10:37 PM   #1856
anyone got the part number for the evo2 chassis.
jiggamacdaddy is offline   Reply With Quote
Old 01-03-2010, 10:41 PM   #1857
racer301's Avatar
Default vz252
its VZ252
they are the same. the evo 2 chasis is just a bit narrower.I don't see any difference other then that.. basically it is the same as other v one rrr
Old 01-04-2010, 01:56 PM   #1858
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
what is the part number for the next softer rear springs than the ones that come stock with the evo 2 wce
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 01-04-2010, 02:02 PM   #1859
jca2000au's Avatar
Trader Rating: 9 (91%+)
Front Light Blue VZ242-4516 (soft)
Front Med Blue VZ242-4517 (medium, stock)
Front Dark Blue VZ242-4518 (hard)
Rear Light Blue VZ243-4516 (soft)
Rear Med Blue VZ243-5017 (medium, stock)
Rear Dark Blue VZ243-5518 (hard)
jca2000au is offline   Reply With Quote
Old 01-04-2010, 02:49 PM   #1860
TIX
TIX's Avatar
cheers
Alan Nankervis.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
