Old 12-11-2009, 03:29 AM   #1801
I)arkness's Avatar
can anyone tell me if there is a way to tell if my car is running 2mm offset or 0mm in the rear
As i can't tell just by measuring it due to being able to change pivot ball lengths.
B.Portelli
Hyper RC - RAB Hobbies - Wild Turbo Fans
Race Opt - Team Powers
I)arkness is offline   Reply With Quote
Old 12-11-2009, 07:25 AM   #1802
the 2mm offset wheels have a lip, it is noticeable if you are running kyosho or Twister/ATS tires. Compare with your front tires, you will see an obvious difference
If you are running Jaco prisms, or many others you are running 0mm already.
The dogbones are different too, the normal one has a ridge around it that is maybe 3mm wide in the middle. the other bone is just longer in general but the ridged bone will not fit if the pivot balls are out far enough and the flat bone won't fit if they are in for 2mm.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 12-11-2009, 07:26 AM   #1803
Originally Posted by otinane86 View Post
Hi there i am new around here so i don't know if this is the right thread for my question. My car is the rrr wc. From photos on the web i saw that the evo 2 has socket head screws everywhere so i wonder if there is or will be a conversion set of these screws for my car. Or a way to get some of these screws seperatly. Sorry for bad english. Thanks in advance!
rcscrewz has a really nice set, but you should also look to 3racing or one of the asian shops for a titanium kit as well. I would get the steel screws first, and then the titanium's because you can only use them in about half of the car.
Old 12-11-2009, 11:54 AM   #1804
Thank you guys for your answers. rcscrewz seems to be a good solution to my problem. As for 3racing i'm not a big fan so that will be my last choice. I was wondering if i could find the kyosho's screws. For example when you break a part and replace it with a new one and you might need some extra screws so why not the whole kit! But if that's not possible i'll stick to your answers.
Thanks again!
otinane86 is offline   Reply With Quote
Old 12-11-2009, 03:01 PM   #1805
YmeBP's Avatar
Trader Rating: 32 (100%+)
Thanks again!
The rc screws kit comes w/ a couple extras of each type.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 12-11-2009, 07:10 PM   #1806
I)arkness's Avatar
thanks Brian
um do you know the length of the rear dog bones? as i have both rigid and standard in same lengths. so just by seeing the rig doesn't help...
B.Portelli
Old 12-11-2009, 08:17 PM   #1807
Default front diff
Just read in a previous post that you need the (19) diff joint not the (12) diff joint. Is this true? What else do you need to convert to front diff. Do you use the pully off the one way?
Keanas is offline   Reply With Quote
Old 12-12-2009, 12:43 AM   #1808
MikaR's Avatar
Yes, same pully.
I bought this screw set http://cgi.ebay.com/KYOSHO-V-ONE-RRR...item414b1ecc77
But I needed a few additional screws for the Evo 2.
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 12-12-2009, 07:00 AM   #1809
YmeBP's Avatar
Yes, i had to buy the longer diff joints for the front diff, (http://cgi.ebay.com/ws/eBayISAPI.dll...=263602_263622) I haven't seen a pully specifically for the one way. I used the pulley in this package http://www.google.com/products?q=vz2...N&hl=en&tab=wf same one that is on the oneway as the diff.
Old 12-12-2009, 08:36 AM   #1810
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
You use the same front pulley on the diff as well as the one-way. If you are actually removing it from a one-way, be sure to pull off the plastic ring you glued on. If you don't remove the plastic ring, the pulley will be too wide and not fit between the bulkheads.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 12-12-2009, 09:59 AM   #1811
amyana3RWC's Avatar
Originally Posted by MikaR View Post
Yes, same pully.
OK TQ
amyana3RWC is offline   Reply With Quote
Old 12-12-2009, 10:48 AM   #1812
amyana3RWC's Avatar
Originally Posted by silverM3 View Post
yes, get the LiFe battery:
http://www.rc-toro.com/product_info....oducts_id/1666
If a charge can charge Lipo, you can use it to charge LiFe
OK TQ
Old 12-12-2009, 01:33 PM   #1813
jca2000au's Avatar
Trader Rating: 9 (91%+)
92051 - 2x11mm Pin
BS107 - Bevel Shaft
VZ204 - Differential Pulley Set
ORG05 - O-Ring (P5)
VZ012 - Differential Gear Set
VZ218 - Differential Joint (19)
VZW020-01 - Differential Case Seal
Transfer front pulley from your one-way or locker.
I am running 40,000 front and 20,000 rear, tried thicker front but dont like it.
jca2000au is offline   Reply With Quote
Old 12-12-2009, 07:30 PM   #1814
thanks Brian
the "evo" bones with the rings in the middle are 58.75mm
the "evo2" bones are 60.75mm
Old 12-13-2009, 12:37 AM   #1815
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
Hey Guys
I have just started racing onroad coming accross from offroad
I have read through the last 6 pages of this thread. man it took some time!
I just picked up a Evo 2 WCE and im wondering if there are any tips you can give me when it comes to building the car?
Are there any tricks or problems i should know about?
Cheers
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
