Old 11-29-2009, 10:04 PM   #1786
Originally Posted by Novarossi View Post
Brian,
I got a direct email from KO Propo USA that the 2413 was NOT suited for nitro use, and would not be covered by warranty (after blowing one on my throttle).
They suggest that this is only an electric car servo (no heatsink, low torque, etc).
Weird, I have used them for literally years and Robert/KO recommended their use in a round about way because I should run a regulator with 2413's and that I would not have to if I ran 2367's or 2368's so he obviously knew it was for nitro because we were talking about lipo directly to the receiver but he probably gets a lot of calls. I think the ICS technology allows them to last because they don't take impacts under stress. Sedan only obviously.
Other news on those Orions, apparently they have a futaba spline but they are not and said to be Taiwanese. I felt some of the blue ones today, they're pretty nice.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 11-29-2009, 10:37 PM   #1787
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Yep, Robert was kind enough to replace it this time only, but suggested not using it for nitro - I still have a copy of the email.
We only recommend using servos with a heat sink for nitro due to the excessive heat build up
The throttle servo completed seized, only about 3 heats old - It was an electronic fault
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 12-07-2009, 06:55 AM   #1788
MikaR's Avatar
Hi, just wondering if anyone is using Futaba 2.4gHz receiver with High Voltage servos and a lipo RX pack without a regulator?
So, in other words - Can the Futaba RX handle 7.4 volts for a prolonged time ? I've been table testing and it all looks good, but what about in real driving conditions?
Any experiences there? Appreciated, thanks.
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 12-07-2009, 07:17 AM   #1789
Hi!
I think it is not a good idea ...
I have problem with bec system in futaba RX (fired up), chassis was
RRR with asso xp 1015 for steering (14kg/0.10sec/6V) and low profile
kopropo for gas/break. 7.4V is under load but fresh charged lipo has a little over 8V!
My spektrum pro 3001 handle this setup without problems, a little
warm from RX.
IMHO better is use voltage regulator ...
I think better solution is use LIFE 6.6V RX pack, they are available for
GP's and should fit to RRR without problems.
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 12-07-2009, 08:37 AM   #1790
None of the manufacturers "recommend" 7.4v to the receiver and servos. Some will support it, and the warranty period is so short that they don't really have to worry about it. but it does cause your servos to fail earlier supposedly.
Old 12-07-2009, 11:13 AM   #1791
MikaR's Avatar
Thanks for your responses -
servos are lipo ready high voltage Hi-Tec servos, I'm really only concerned of the RX. May need to change to Spectrum which can handle 9,6 volts.
Servos http://www.hitecrcd.com/servos/show?name=HS-7940TH
Old 12-07-2009, 03:49 PM   #1792
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
JR also makes a few servos that are lipo ready.
9100HV servos. I think there are two servos in the HV line. Torque and Speek
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 12-07-2009, 05:41 PM   #1793
YmeBP's Avatar
Trader Rating: 32 (100%+)
I match 2/3a (receiver cells) for 1/18th micro cars, the cells that don't make the cut for racing I use for nitro receiver packs. I also have done quite a bit of work with lipos for micro racing (same size and voltages as receiver packs) along with LiFe packs and I've found that no matter what the manufactures say about their gear current generation electronics do NOT like 7.4 volts. It creates quite a bit of heat and especially w/ the standard brushed motored servos; it kills them quickly, it also puts allot of strain on the gears in the servos and the receiver electronics as well if you try to run it w/o a regulator.
Regulators work, but they are not all created equal. Xceed's regulator I've found to be more consistent and more reliable than most of the others on the market. The issue is when the regulators go, they take your servos with them and personally, I don't think it's worth the risk of blowing 2 100$+ servos. I've seen a guy blow two JR 9000's in the same day behind a crappy regulator.
LiFe and good, graded, matched NiMH packs are your best bet for today's electronics. Life have 6.6 volts so you don't need anything special to run them. Only down side is you have to have a charger capable of charging Life packs. My favorite for gas racers are Hyperion 606I ac/dc http://www.skyrocketbatteries.com/pr...products_id=99I plan to carry Turnigy (a cheaper Chinese alternative) in the future but the old adage applies ... you get what you pay for. There are some others that do a good job but I've found the Hyperion chargers to be very reliable for a reasonable price.
Nimh are still a viable alternative and to prove a point when I race my gas car I only charge my packs once (twice if i bump up). I ran the whole day Sunday through practice, quals and 1 30 minute main on one charge and still had plenty of juice left in the pack.
My graded matched assembled 5 cell receiver packs are 20$. Being an electric guy I cringe when I see people risk a 500+ kit, 400+ motor, and 300+ in misc stuff to a 15$ bargain bin receiver pack that hasn't been through any sort of process to weed out bad cells or gauge their run time. My biggest competitor, Team Scream, also has great receiver packs and puts his cells through a similar rigorous grading and matching process. Leave non-matched packs for the bashers even if you don't get them from me .
Anyway this is turning into a book and I think I promised once in the past not to do it again . I am always glad to help, and you should be seeing Skyrocket at more nitro events like the US Open Fuel Champs, and the Winter Nats, so please stop and ask when you see someone with our shirt on.
Originally Posted by M.Abramowicz View Post
Hi!
warm from RX.
Regards!
m.
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 12-08-2009, 02:26 PM   #1794
yes, get the LiFe battery:
http://www.rc-toro.com/product_info....oducts_id/1666
If a charge can charge Lipo, you can use it to charge LiFe
silverM3 is offline   Reply With Quote
Old 12-08-2009, 02:43 PM   #1795
Exclamation
Wrong!
http://www.rctech.net/forum/nitro-ro...-new-post.html
LIPO 1 cell is max to 4.2V and LiFe 1 cell is max to 3.6V.
So 2 cell LIPO is max charged to 8.4V and LiFe 7.2V by CC/CV method (constant voltage
or something constant bla bla, special program for charging).
Small difference and you can broke LiFe pack when charge it on LIPO program.
You should look for charger with LiFe program.
Regards!
m.
Michal Abramowicz
Old 12-08-2009, 03:37 PM   #1796
Ok to get us off the battery topic..
Has anybody tried the new offset rear hubs? I've seen them for sale over seas but never through shopkyosho so I haven't had a chance to get any yet.
Supposedly changes the rear geometry even more than the evo2 (by changing the wheel offset using the pivot balls) without changing anything else.
Old 12-09-2009, 04:58 AM   #1797
Team-RTR's Avatar
Any pics? Whatelse would I need to change on a original RRR rear end to get them working properly?
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 12-09-2009, 09:20 PM   #1798
Originally Posted by RC MARKET View Post
New rear hub for RRR Evo 2
9mm ball moved 2mm outside
I have no real idea what this means, nobody seems to have ever ordered it.
the part # is vz262
Old 12-10-2009, 04:01 PM   #1799
Hi there i am new around here so i don't know if this is the right thread for my question. My car is the rrr wc. From photos on the web i saw that the evo 2 has socket head screws everywhere so i wonder if there is or will be a conversion set of these screws for my car. Or a way to get some of these screws seperatly. Sorry for bad english. Thanks in advance!
otinane86 is offline   Reply With Quote
Old 12-10-2009, 04:07 PM   #1800
Dru Garcia's Avatar
Send a message via Yahoo to Dru Garcia
try this site...
http://www.rcscrewz.com/index2.php/s...ts/cPath/1_313
Desoto Racing
Dru Garcia is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
