Old 11-20-2009, 07:46 PM   #1741
Default How do I tell?
Originally Posted by Scott Fisher View Post
Chassis, radio tray, and the servo saver/ackerman. Also, the 2-speed and the 2nd gear itself, the rear offset on the new car is zero so you would have to buy new rear CVD/dogbones.
You can upgrade by buying the parts.
I just bought the Vone RRR, on ebay,new, but I don't know whether it is a version one or two, how do I tell by looking at the car. If its a one where do I get the parts that were listed above?
authorjim is offline   Reply With Quote
Old 11-20-2009, 07:58 PM   #1742
Default NovaRossi?
One other question, how would the NovaRossi 12-5sct .12 5 port work in this the VOne RRR. I know it's a general question, but would it be better or on par with the SirioXXX and or the Picco engines?
Jim
Old 11-20-2009, 09:21 PM   #1743
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
If you purchased the kit new, what is the part number on the box? Should be a 5 digit number starting with 312. If you cant find that, post a picture of the chassis.
Any of the engines you listed will work fine in the car. If you are doing any organized racing, the 5 port Novarossi engine may not be legal.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 11-20-2009, 09:46 PM   #1744
the evo2 has no brace in the front cut out of the chassis
the evo does. there is a () shape in the front, or a (-) type of shape between the front bulkheads.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 11-20-2009, 09:55 PM   #1745
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
hope this helps
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 11-21-2009, 05:46 AM   #1746
Default Thanks for the help.
Originally Posted by rcpaintinpete View Post
hope this helps
I guess I got an EVO. Still a great deal, purchased it on Ebay basically all built, with a Sirio EVO4 engine, brand new, including the pipe. I will use that engine on my Team Magic car. It was built nice and clean and the whole deal including the engine was $450, complete chassis kit, engine, pipe and servos, though I will put better ones in, when I finish it. I need to build the Throttle/ brake linkage and put the clutch gears and clutch on the engine.
Before I do I was trying to decide on the engine.
Why would the Nova be illegal? Can I find the rules someplace? Sorry but I'm new at this.
Jim
Old 11-21-2009, 06:05 AM   #1747
corney_01's Avatar
Jim[/QUOTE]
Because its a 5port engine most rules only allow the use of 3port engines
Comen back with..XRAY-KO PROPO- NOVAROSSI
corney_01 is offline   Reply With Quote
Old 11-21-2009, 06:12 AM   #1748
GMartinez's Avatar
Trader Rating: 85 (100%+)
Jim
Because its a 5port engine most rules only allow the use of 3port engines[/QUOTE]
www.roarracing.com & download the rule book these rules apply to tracks that are roar registered tracks or tracks that follow roar rules
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 11-21-2009, 06:41 AM   #1749
Jim
thankfully most 5 ports suck, so no club will really give you a problem for running it. like mentioned above, most rules only allow a 3 port so all of the racing development goes into the 3 port engines so they are usually faster. ports does not equal speed although size can but the .15's that are available also suck compared to race ready 12's from all of the brands.
that sirio evo 4 is no joke, thats a good engine. you don't need to spend over $200 to have a fast car today.
Old 11-21-2009, 06:42 PM   #1750
that sirio evo 4 is no joke, thats a good engine. you don't need to spend over $200 to have a fast car today.[/QUOTE]
You guys have really helped. I will keep the Sirio Evo4 and the current car without upgrading it to the EVO2. I am new at this and the car is probably much better than I am. When I can drive this to the limit and set it up to the optimum, then I will worry about the next step.
Thanks again
Jim
Old 11-22-2009, 12:08 AM   #1751
how do you guys set the braking?
do you guys lock the brakes up? or only so that it slips and the car slows?
LiL_JaSoN is offline   Reply With Quote
Old 11-22-2009, 08:32 AM   #1752
I run a front spool, and set my brakes to barely lock on the slower corners but I have one high speed straight that I need fairly heavy brake (for me) going into but I trail the brake 1/4 through that sweeper.
Basically entering pit lane, my car has almost no brakes and my pit man has to catch it. I've run my 8th scale without brake pads even in the car on the same track (the pads actually broke off the screws) so the turn should be used as much as possible to scrub speed.
Hope this helps, you also need to learn brake modulation just as well as throttle. I'd suggest running electric for a while to really get the feel of the radio down.
Old 11-22-2009, 09:50 AM   #1753
Default Front diff + TCD Gears
Hi guys a couple of months ago i asked for what parts i need in order to run a front diff setup. They gave me some product codes ordered them but couldn't fit it for more a couple of problems. So i assume they gave me the wrong part numbers. I will try and search for the product codes they gave me, in the mean time can some one that did run a front diff on an Evo 2 be so kind and advise what parts i need. Also i thought of trying a TCD diff on the front as i once used this setup on my front STRR diff and helped me a lot in tight tracks. By the way our onroad track where we race is very tight. What do you suggest?
speed6 is offline   Reply With Quote
Old 11-22-2009, 03:19 PM   #1754
I myself had the wrong part #'s from this thread one time and could have repeated them but I didn't have a diff at the time to know if they were right or not. I wish I knew what parts made the front diff, I was able to make one out of everything I had but I have no idea how to do it again. I looked in the v-one-r manual which had the wrong #'s, apparently they changed the pulleys somewhere in the middle. Take a look at all the manuals and you will be able to find the one that has a top deck and front bulkheads that fit the rrr evo and it will be that diff.
Some drivers like diffs, some like spools and some like oneways on every track they ever run on. I built the diff and hated it so I still only run a spool on every track.
Old 11-22-2009, 03:30 PM   #1755
Valeryvob's Avatar
Default Who knows where to download XRumer 5.0 Palla
Who knows where to download XRumer 5.0 Palladium?
Help, please. All recommend this program to effectively advertise on the Internet, this is the best program!
[i][b]love,sex,emotions..............[/b][/i]
DrettyVettegegaild
Valeryvob is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
