Old 11-06-2009, 10:12 PM   #1711
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by impalabob64 View Post
Run 196mm frt 199mm rear the dogbones in the rear help free up the rear.With 0 offsets.Whats up Scott you coming my way for the US open right.Its Bobby Watson.
I don't think so Bobby.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 11-06-2009, 10:14 PM   #1712
Originally Posted by Speedypeterb View Post
hey Scott, when you run the four weights, what spring do you use and whats your setting for it Thanks Peter
Hey Peter: Obviously it depends a little on the engine and the level of traction, but here is where I start:
I use the stock clutch spring FM432.
I set my gap at .4mm Endplay is minimal.
I tighten the spring down to show 1.1mm of thread. I use the grey clutch shoe.
Old 11-07-2009, 06:09 AM   #1713
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default 2d clutch
thanks Scott, will try it , I don't like thefeel of two shoes
Team Kyosho, Team Epic, IDM Engines, J-Tech racing fuels, Airtronics, Superiorhobbies.com
Speedypeterb is offline   Reply With Quote
Old 11-07-2009, 01:25 PM   #1714
MikaR's Avatar
so do you prefer the 3D clutch then ? is that what you mean?
(asking because I'm thinking of getting the 2D clutch)
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 11-07-2009, 01:52 PM   #1715
No, I prefer the 2d with 4 weights (which I think is just a 4d clutch)
Old 11-08-2009, 01:06 AM   #1716
awins's Avatar
Default 2d or 4d
well down in australia i use a siro power clutch with no probs on any tracks best thing ever
awins is offline   Reply With Quote
Old 11-08-2009, 01:31 AM   #1717
Ive used the sirio power clutch. Its a good clutch, but they had some bad machine work on some of the clutch bells which I have one and the bottom line is the Kyosho clutch is very good. Sirio parts are tough to get here and I like the Kyosho clutch.
Old 11-08-2009, 04:32 PM   #1718
Default 2d clutch
I do like the three shoe better then the 4d with two weights, but i have a ton of clutch shoes for the 4d so i would like to try 4 weights before i get rid of the shoes. I have run the kyosho clutch 3d for two years with no problems or performance issues. just trying something different. if its not better for me then i will run what has worked.
Old 11-08-2009, 06:20 PM   #1719
shiston's Avatar
what's the difference between the red and grey 2d/4d clutch shoes?
shiston is offline   Reply With Quote
Old 11-09-2009, 01:50 PM   #1720
Big Jeff BBQ's Avatar
Peter : or any body else ! Jeff E. here with a question ?
We have a new car that has been fine,we switched the top deck to a lay down servo and ever since we did this the car now is stripping gears ?
Is there anything as far as parts or measurments or anything that could bind this car up to cause the gear stripping?
are the upperdeck supports the same height as the W/C !
are there anyparts that should be diffrent because of w/c verses EVO in the laydown servo exchange ?
Call me if you need to
404-886-8120
Thanks for the help in advance
Jeff Epperson
Blowin' Smoke BBQ
Special Thanks To:
Steve Pitts
Kevin Hutchinson
Big Jeff BBQ is offline   Reply With Quote
Old 11-09-2009, 07:04 PM   #1721
I prefer the way the grey shoe engages. It seems a bit smoother which to me means it slips a touch more.
Old 11-09-2009, 09:03 PM   #1722
shiston's Avatar
Cheers thanks
Old 11-09-2009, 09:34 PM   #1723
blount's Avatar
Default Kissimmee Raceway set-up
Front-
-1 droop
5 ride height
camber left 2.0
camber right 2.0
40 shore - twister tires 58mm
3.5 toe
199.5 width
stock blue springs
middle position
600 wt
2 hole piston
spool
front sway bar-slat
Roll center pins all the way up
Rear-
6 droop
6 ride height
4 left camber
4 right camber
42 shore - twister tires 60mm
2.5 toe
200mm width
stock blue springs
shocks-layed down
600wt
2 hole piston
20wt diff oil
2.5 sway bar
Roll center pins all the way down
Motor and clutch info:
NOVAROSSI 353 murnan mod
2630 pipe with long header (6 ring)
sirio clutch with .7 gap
.4 end play
I used red(serpeant shoe).
gearing is 17/23 and 60/55
This was a medium bite track. Very flowing and high speed. There will be a few things that I will change for the US OPen next month.
1. A lighter rear sway bar.
2. dark blue springs
The car felt and handled pretty good. If you plan on coming to the US Open this set-up will be a good base to start with.
Serpent America
Desoto Racing
Runner Time Fuel
Matrix Tires
SRC
blount is offline   Reply With Quote
Old 11-09-2009, 09:52 PM   #1724
Default gears
there should not be anything different to cause the strippinp of gears but i will be there wednesday and will gladly take a look with you Also put me down for 2 racks of ribs thanks Jeff
Old 11-10-2009, 03:50 AM   #1725
anyone evo owners who have converted to evo.2 and has a spare evo top-plate they dont need :P
im still running the rrr wce with the laydown servo, wouldnt mind the topplate so i can run a stand up.
LiL_JaSoN is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
