Old 10-15-2009, 11:46 PM   #1636
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by Brian Bosley View Post
I think they have a heavier tray, my car with the heaviest tray from YBSlow (58g maybe?) plus NIMH and 1.5oz of weight and I was coming in at 1726-1730 at nationals. Don't under estimate light servos and titanium screws.
He does make a heavier brass tray if needed.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 10-16-2009, 01:00 AM   #1637
MikaR's Avatar
Thanks guys for your replies and sharing your experience, sounds like I'm on the right track here.
The new 7940 servos are slightly heavier (15gr together if I'm correct) than my current futaba brushless servos so a little increase there.
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 10-16-2009, 01:26 AM   #1638
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Originally Posted by Scott Fisher View Post
Don't think so. Are you coming to the Paris race?
I can't get friday off from work, but will try my best to be there saturday morning.
Walter Diaz
wad is offline   Reply With Quote
Old 10-16-2009, 02:08 AM   #1639
I go 1.1mm of thread showing past the spring retainer. .4 gap with minimum endplay.
Wouldn't 1.1mm of thread give the clutch to much punch? or the extra .1 in the gap would smooth it?
speed6 is offline   Reply With Quote
Old 10-16-2009, 10:45 AM   #1640
It really depends on the engine and the grip level on the track.
For me, .3 would bog the engine way too much and not let my car come out of the hole the way I would want.
Old 10-17-2009, 01:04 PM   #1641
Guess i will need to try different settings
By the way my first and second alum gears are getting chewed quite fast whaever the mesh tight - loose.
Is this a normal issue, shall i use steel gears? or maybe their is a hop up which can whitstand more abuse
Old 10-17-2009, 01:13 PM   #1642
Trader Rating: 18 (100%+)
Default Kyosho RRR
They do not make a steel spur gear for the RRR.
If the mesh is correct, you spur gears will last quite a long time.
Check your spur/pinion mesh, check your rear lay shaft for wear, bearings for the rear lay shaft,clutch bearings,pinion gears for wear for starts.
There are many reasons why you are going through spur gear so quickly, and it could be the mesh is too loose, too tight, of parts have worn to where there is play between the spur/pinion gears
I have had my spur gears on my RRR for well over a year, and they still look great.
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 10-17-2009, 01:35 PM   #1643
actually the plastic spur gears are quite fine its the aluminium gears that are getting chewed.
I tried a tight mesh with obviosly a bit of play and i tried a mesh typical buggy / truggy.
The two of them didn't work.
I heard that you really have to tighten them, do i have to tighten them as if they are binding?
Old 10-17-2009, 01:49 PM   #1644
Default RRR
It sounds like your pinion gears may be worn out. If the very outside tip of the pinions are very sharp and to a point, then they are worn out.
Try new pinion gears and when you set the mesh, rotate the gears very slowly until you find the tightest mesh between the pinion/spur gears. Back the mesh just a touch, and then tighten the down the engine support bolts.
There is always a loose/tight spot bewteen the spur gears and pinion gears.
nearest barstool
Old 10-17-2009, 04:27 PM   #1645
use steel pinion gears they last alot longer then the aluminium gears that should solve your problem
ARC R10/2015 - HOBBYWING - PROAMPS - ORCA
BRCCC
elche_83 is offline   Reply With Quote
Old 10-18-2009, 03:27 AM   #1646
The aluminum pinions do wear a bit fast. The first gear pinion will wear faster than the 2nd gear pinion. You can run steel pinions and pretty much they will last forever, or at least run a steel first gear pinion.
Old 10-18-2009, 04:19 AM   #1647
True the first get chewed quite fast. I think i will try the 1st in steel, any part numbers or brands
Thanks guys
Old 10-18-2009, 12:36 PM   #1648
Thanks guys
Kyosho is the brand. I listed both 1st and 2nd gear pinions
VZW215-15
VZW215-16
VZW215-17
VZW066-20
VZW066-21
VZW066-22
VZW066-23
Old 10-18-2009, 02:47 PM   #1649
Thanks Scott
Old 10-19-2009, 07:04 AM   #1650
I'm using the stock bearings, and I found out that one of the bearing, the one nearest to the hex hub. It was gritty when i tried to spin it. seems like there's dirt in it. any help to removing it?
AdrianOngs is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
