Old 10-05-2009, 06:29 PM   #1621
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Originally Posted by Arushmen View Post
Hi Scott
Which set up will give more rear traction, 2mm off set or 0 mm off set?
Thanks in advance
Honestly I really don't know. I asked a friend that I trust and what he said was the 2mm offset should yield a bit more rear grip. It has to with the slightly different geometry and the effect that the different offsets have on the roll center. It actually would make sense since I know the Evo car ran the 2mm offset and the Evo2 runs the zero offset. I know that a big thing with the Evo2 was to get the car to turn a bit better so it would make sense that they might change something to loosen up the rear of the car.
I changed over my car from 2mm to the zero offset when the Evo2 was released. I couldn't really tell any difference, but I made the change so my car would be like the new car and could share setups with people.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 10-06-2009, 01:43 AM   #1622
Originally Posted by speed6 View Post
Hi guys, so did some different setup how you suggested and the car did handle way much better BUT.........
Yesterday i found out the following
1. Excessive tyre wear next to others. I am running 37 Fronts with 40 Rear are giving me around 7 min run time next to others that are running 15min easily with the tyres still in a good shape.
2. Front left wheel ( the one that has the most traction and beating as we turn mostly right hand side ended up as if i had lots of positive camber event though i am running 3 degree neg camber.
suggestions pleazzzzzzzzzz
Thanks guys
bumb
speed6 is offline   Reply With Quote
Old 10-06-2009, 08:39 AM   #1623
bumb
change your camber to make the tires wear near flat and the fronts with a slight angle (1-2 degrees). all 4 of my tires have different camber rates because of the wear the tire has.
if everybody else is using an equal 37/40 combo, then you are just driving too hard. nothing would make you wear tires at a 2x rate that has to do with setup that would leave you with more than 2mm of wear on almost any surface in 7 minutes.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 10-12-2009, 04:50 PM   #1624
is the evo 2 wc car out in the states
8lackflagracing is offline   Reply With Quote
Old 10-12-2009, 06:21 PM   #1625
blount's Avatar
Yes, for at least nine months now!
Serpent America
Desoto Racing
Runner Time Fuel
Matrix Tires
SRC
blount is offline   Reply With Quote
Old 10-12-2009, 07:26 PM   #1626
The WC version has been available for that long now? Man I gotta keep up on this stuff.
Old 10-15-2009, 04:03 AM   #1627
Default Evo 2 - Clutch setting
Hi guys, i have installed extra weights ( 4 D )
What setting gap / spring do you recommend?
I am running .30 on spring and .30 gap
Old 10-15-2009, 09:36 AM   #1628
YmeBP's Avatar
Trader Rating: 32 (100%+)
I got mine back in march .
www.skyrocketracing.com quality RC gear!
http://www.rctech.net/forum/racing-forum/555071-2011-skyrocket-invitational-blue-diamond-raceway-october-15-16-a.html <- Great race!
YmeBP is offline   Reply With Quote
Old 10-15-2009, 10:17 AM   #1629
wad
wad's Avatar
Send a message via AIM to wad Send a message via MSN to wad
Hey Scott,
Are you coming for the KO race?
Walter Diaz
wad is offline   Reply With Quote
Old 10-15-2009, 11:05 AM   #1630
MikaR's Avatar
Hi, building my Evo for the next season and bought bunch of things, maybe you can comment -
Evo 2 chassis and carbon upper deck
Evo 2 rear axles/dogbones and wheel adapters (I didn't go for the uni's because I think you guys said dogbones are better) and A-arms
50 gram lipo receiver pack
2x Hitec's new high voltage lipo ready 7940 servos
Ti hex screw set from eBay
YBSlow brass 42g battery tray in case the car gets too light
Team Orion CRF .12 engine
What do you think?
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 10-15-2009, 11:40 AM   #1631
What do you think?
very Very nice! looks like you got it all ready to go!
LAM3SAUCE is offline   Reply With Quote
Old 10-15-2009, 06:10 PM   #1632
Originally Posted by wad View Post
Hey Scott,
Don't think so. Are you coming to the Paris race?
Old 10-15-2009, 06:18 PM   #1633
I go 1.1mm of thread showing past the spring retainer. .4 gap with minimum endplay.
Old 10-15-2009, 06:20 PM   #1634
What do you think?
Next time you look for Orion engines, try the Alpha ABI.
Old 10-15-2009, 11:35 PM   #1635
What do you think?
I think they have a heavier tray, my car with the heaviest tray from YBSlow (58g maybe?) plus NIMH and 1.5oz of weight and I was coming in at 1726-1730 at nationals. Don't under estimate light servos and titanium screws.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
