Old 09-21-2009, 08:05 AM   #1591
shanesva's Avatar
Default kyosho parts on line VONE RRR WC
Where online is everyone getting parts for the VOneRRR WC kit. I have been to kyosho site but they don't have the 55 or 56 spur for this kit.
shanesva is offline   Reply With Quote
Old 09-21-2009, 10:25 AM   #1592
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I just logged into Kyosho and it shows both gears in stock. Try calling them.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 09-21-2009, 11:32 AM   #1593
boy2rc's Avatar
V-ONE RRR“SHIMO”エディション
http://www.kyosho.com/jpn/products/r...duct_id=105760
boy2rc is offline   Reply With Quote
Old 09-27-2009, 11:45 AM   #1594
Guys, bought the rear thinnest rear sway bar, the one that is colured like brass / copper but as soon as i tested it it felt really good but it got bent with no crashes etc. I arranged it with a plier and it bent again fromt the same place. anybody had the same issue ??
speed6 is offline   Reply With Quote
Old 09-27-2009, 05:45 PM   #1595
Nope. I have run that thin bar several times. Still have it.
Old 09-28-2009, 03:33 PM   #1596
Guys what are the different handling caracterstics that will effect the Evo 2 if i replace the front drive ratio from the stock 23t pully to the 24t pully? Also if i replace the pully to a 24t will i have to replace the belt with a 387 belt? or can i sue the 384 belt?
Old 09-28-2009, 03:46 PM   #1597
blount's Avatar
As far as handling I didn't like it compared to the 23t. The 24t gave the overdrive feel, so it felt a little lazy when transition from turn t turn. Yes, I would run the correct belt.
Serpent America
Desoto Racing
Runner Time Fuel
Matrix Tires
SRC
blount is offline   Reply With Quote
Old 09-28-2009, 03:56 PM   #1598
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
Default pulleys
Here's my understanding of changing the pulley, I don't think it changes the handling of the car except for this reason. when you run the 23 tooth pulley you run a 2mm split between the front and rear tires the front tires smaller by 2 mm. usually the rear tires wear more then the front tires so in a long main the rears end up as small as the fronts now if you run the 24 tooth pulley you split is equal so if your rears end up to much smaler then the fronts then you deffinetely have handling issues and also smaller fronts usually mean better stearing. you can run harder rear tires to compensate for the extra wear in the rear. the best thing is to try and test it and you may find that it works for you. some other may have a little more to add to what i said
Speedypeterb is offline   Reply With Quote
Old 09-28-2009, 04:53 PM   #1599
so if i run the 24t pully i will need the 387 belt right? can't use it with a 384?
Old 09-28-2009, 06:06 PM   #1600
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
using 24 pulley ,car also looses a bit of rear grip, so i was using a big more droop in the front , compared to the rear and soft sway bar.but i think the whole point of running a 24 pulley is to run rubber tires.
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 09-28-2009, 06:11 PM   #1601
being so thin once the bar is bent it makes the bar weak.. if your bar is bending with out any hits your car is not tweaked . not balanced left to right. balancing it will remove that problem. i have bend a 2.1 bar . its not uncommon.
Old 09-29-2009, 04:25 AM   #1602
Default Where why and how to set Droop on the Evo 2
Hey guys can someone be so kind and explain why would you increase or decrease droop on an onraod car. Would it aid oversteer, understter bumbs etc...
Basically i want to get the outmost for a tight bumby track with not to much grip.
Also what about the upstop??
Thanks very much
Old 09-29-2009, 08:24 AM   #1603
Thanks very much
Bumpy tracks are relative to the individual, but lets say it is truly bumpy and you are running 6+mm of ride height to get around without burning a chassis per run.
More downtravel will allow the car to feel more controlled over the bumps because the tires will follow them instead of skip over them. Up stops are really just there to limit how hard the chassis hits so you can place them close to where the chassis bottoms out. You can adjust the shocks bottoming with the shock end lengths too (there are 3-4 plus different bottom shock retainers)
More rear downtravel will allow you to have more roll in the car and have the rear wheels still touching the ground, with less you have the risk of one raising and causing you to spin because the weight is toward the front of the car in most corners.
More front downtravel will allow the front suspension to work a bit under acceleration through the bumps and give you some steering while the weight is on the back of the car.
Front up travel can be limited to stop the amount of weight transferred to the back of the car during acceleration (think drag racing, front wheels off the ground puts 100% of the weight on the rear tires but no steering)
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 10-01-2009, 12:50 AM   #1604
Thanks very much
what is your current setup? . we can work from there.and explain how your car is handling , and what you would like to achieve to make your drive better .
droop plays different role with different setting. i tend to change few other things before i play with droop.
but majorly front droop affects how your rear end of car handle. and rear droop affects the front handling of the car.
Old 10-01-2009, 02:02 AM   #1605
Actually i am having a hard time measuring droop to the exact melemeter. Do you have some tricks of how to measure droop?
What i am sure of is that i adjusted the car to have around 3mm droop in the rear and around 1mm on the front. That would hopefully aid the steering in high speed turns since weight will be shifted upfront and also work out through the bumbs.
Update i do have a droop gauge and bars for underneath the car but not sure of what and where i have to measure with the gauge.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
