Old 07-19-2003, 03:48 AM   #1
super dave 45's Avatar
Default mt12
can some one help me
i just got a mt12 motor
what kind of washers go in back of the flywheel
and how many do i put there
and how many tanks of gas should i run to beake it in
i am trying real hard to get it going for sunday
thanks for the help
dave
PS i am putting it in my mtx2
super dave 45 is offline   Reply With Quote
Old 07-19-2003, 05:37 AM   #2
TAW
Trader Rating: 18 (100%+)
Send a message via AIM to TAW
Default Re: mt12
thanks for the help
dave
The shims behind the flywheel vary from model to model, I don't know about the mtx-2 but I don't have any behind the flywheel on my mtx-3. As for break-in you will get many different answers, what I do is heat cycle the first tank (run for about 3-5 mins to get up to temp and then shut off) make shure the piston is at BDC (bottom dead center) you can tell when you turn the flywheel by hand it will very very free at BDC. Second throught about fourth tank I run the car at very low speeds checking that the temp is low 200~210F. After that start leaning out in slow 1/8 turn increments. Again you will get many different opionions on how to do this.
Hope that helps some.
Troy
TAW is offline   Reply With Quote
Old 07-19-2003, 05:39 AM   #3
TAW
Opps forgot some details.... when heat cycling after each cycle I let the engine completely cool... maybe 30 to 45mins.
Old 07-19-2003, 06:04 AM   #4
so you are saying after each tank let it seat for 30 to 45 mins?
on the shims it calls for 2 but i just want to do this right
i am real tired of getting to the track to race and all day
the motor not making a race if you know what i mean
thanks for the help
Old 07-19-2003, 06:39 AM   #5
TAW
Well sort of...what I really meant was during the heat cycle phase (3~5 mins) on the first tank I let it cool completely. I also would let it cool completely between tanks as well.
1st Tank. Start rich, run for 3~5 mins stop, piston at BDC, cool...repeat,run3~5 mins,stop,BDC,cool....repeat. Do this until the first tank is done (probably around 4 or 5)
2nd -4th. Run at very low RPM keeping temp low.
5th tank start leaning in slow 1/8 turns.
Does that make more sense?
If the manual says 2 shims then thats what I would use.
Old 07-19-2003, 07:03 AM   #6
thanks
Old 07-19-2003, 09:57 PM   #7
rocketron's Avatar
Trader Rating: 16 (100%+)
thanks
- SchuurSpeed - 6X ROAR National Stock Champion
- Hobbywing North America Team Manager
rocketron is offline   Reply With Quote
Old 07-21-2003, 04:23 AM   #8
on my mt12 brake in i ran two tanks in it so far
at 190 198 not runing it to hard
still have to run more i know
had to stop
found out had and air leek in the gas tank
is that a good temp so far
Old 07-21-2003, 04:26 AM   #9
me43's Avatar
yeah, thats pretty good
me43 is offline   Reply With Quote
Old 07-21-2003, 04:38 AM   #10
how many more tanks should i run in it before
i can lean it out
would know where i can go to get a good setup for the car
i want to get it race ready for this weekend
we have a big race going on here
i got a mtx2 from a guy that i race with
it got to be better then the hpi3 i been racing
thanks
dave
Old 07-21-2003, 04:56 PM   #11
Old Skool's Avatar
had to stop
That temp is too low for an ABC engine. It should be around 205-210F or so.
Old Skool is offline   Reply With Quote
Old 07-22-2003, 01:46 AM   #12
Im2lazy's Avatar
I'm not going to say you're wrong, but I will say that I respectfully disagree with most everyone here (in some way... but that is how life goes, huh?).
190-195 may be good, but I wouldn't know because I am not running the engine in. Only then would I know the weather conditions, the engine performance and other intanglibles that cannot be measured quantitatively. Therefore, I tend to disagree when someone says (as you have) ... it should be around 205-210....
Don't get me wrong, it is very good advice, and that is a range during the first or second tank that I find is perfect when breaking in my engines. However, if the day is more humid... I would say also that 215 degrees would be acceptable because of the weather conditions.
Don't take offense I used your remark as an example, but it was the one closest to the reply button .
After that being said, I want to give this as well... You should really watch how the engines behaves on this next upcoming run, super dave. After having the problem of a leaking tank, the engine tuning may become a bit more important as you find how well it really runs with a proper fuel system. It should run differently and make sure no radical performance or temp changes occur in the next run. Since you have not had any major problems yet, I think you should be okay as it seems you are going along quite well.
Ahhhh.... breaking in a motor, the part of rc that is like art class for the scientist. .
Im2lazy is offline   Reply With Quote
Old 07-22-2003, 02:14 AM   #13
thanks for the help
i took all day and went through the hole car
to see if any more air leaks
i guess when you buy a use car you should check it out
real good
it looks like i am going out the try it again
i live here in MO. so 200 215 should be ok
the track is close this week so they can get it ready for the
HOA race we are going to put on this weeking
so i am in the front of my house doing the brake in
up and down the street
i am trying real hard to get it ready for the weeking
thank again
dave
OS TZ AND MT12 cmain R/C Items: For Sale/Trade 4 07-06-2007 07:45 AM
MT12 help! NitroNubee Onroad Nitro Engine Zone 12 04-27-2007 03:04 PM
MT12 and XXX-NT McCleary.11 R/C Items: For Sale/Trade 3 06-26-2006 10:39 AM
STS MT12 vs NOVA/MUGEN MT12 jscamry Nitro On-Road 17 04-03-2003 05:47 PM
MT12 and MT12 turbo on ebay (cheep)!!!! carpet_killa Nitro On-Road 0 02-23-2002 07:44 AM
