Nitro Sprintcar
Old 03-30-2008, 01:22 PM
RevXS's Avatar
Default Nitro Sprintcar
Well i've decided to build a totally new type of sprintcar,Rather than using Off road basied running gear i've gone with a Mugen MTX-3,Heres a few pictures of it so far
Now theres one problem i've now encountered,I've shortened the car 2cm to make it more to scale of a sprintcar,so of course now the side belt is 2cm too long,Does anyone have some ideas? I could setup a fancy pulley and tensioner setup but be alot easier if i could find something a little shorter than i only have to setup a tensioner
RevXS is offline
Old 03-30-2008, 01:59 PM
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
run it 2wd like a sprintcar
20 SMOKE is offline
Old 03-30-2008, 02:10 PM
RevXS's Avatar
2wd wouldnt work too well on a touring car of this scale,will end up just going in big circles
RevXS is offline
Old 03-30-2008, 02:46 PM
Pillbots's Avatar
What does it weigh?
Pillbots is offline
Old 03-30-2008, 04:18 PM
Looks great brillant!!! I guess you would have to use a larger diameter bearing on the belt tensoner.
nitrohead5300 is offline
Old 03-30-2008, 04:46 PM
RevXS's Avatar
Weights 2kg so far which is 4.4pounds? Sound right to you
Bigger bearing is an opinton but been thinking of running bigger pulleys for the side belt which will hopefully take some of that lack out,But may mess up the gearing slighty
RevXS is offline
Old 03-30-2008, 05:37 PM
Taylorm's Avatar
what tubing did you use???............Brake line tubing???......is it brazed or soldered?..................
Taylorm is offline
Old 03-30-2008, 05:45 PM
genesisG4's Avatar
now that is certainly cool....you have pm
genesisG4 is offline
Old 03-30-2008, 06:27 PM
RevXS's Avatar
genesis will keep ya updated,Just waiting on a new motor and a few other bits to turn up and i'll hit the dirt and get you some pictures and videos,Not tubing its solid High tensile rod which has been mig welded together,Tube would end up twisting too easy,Im not new to building RC's as i've been building RC stockcars which is a form of Dirt track contact racing here in New Zealand in which i've done quite well and thought i'd try have a go at building something that no one in NZ has done before
RevXS is offline
Old 03-30-2008, 07:08 PM
Jason Smith's Avatar
The BMS sprint car has been around for about 5 years and winning championships for about that long as well. This car is designed around an mtx 3 rear end, and trust me it works just fine as a 2wd
Jason Smith is offline
Old 03-30-2008, 07:24 PM
RevXS's Avatar
Interesting....Whats the wheelbase of your cars Jason,Im guessing your running on dirt i was building mine to run on slick concrete and being shortened in the wheelbase i didn't know how it was going to handle.... so i thought i'd make it 4wd and then try it 2wd since this is my 1st nitro sprint car i've built
RevXS is offline
Old 03-30-2008, 07:44 PM
I am not sure of the wheelbase but I could probably measure it and let you know tomorrow. I aslo have some pics, but I am not at home. I can post them later. The only thing I will say is it looks as if your car will actually push due to the fuel tank being in the rear. The BMS is almost a perfectly balanced car, and the oil diff gives it great adjustability. You can check out www.bmsrcracing.com and I also should be able to get some pics and dimensions up for you tomorrow.
Old 04-03-2008, 01:57 PM
RevXS's Avatar
My new STS motors for my sprintcar turned up,Picked up TWO for $50NZ brand new including spare conrods etc,Was a good score i thought and just happens to be the same blue as my alloy servo arms,Just waiting on exhaust to be tig welded back up as its been shortened and the clutch bell,oh and find a real cheap starter box(Unless anyone else has a makeshift idea to get it started)
Going to try finish up the fiberglass bonnet today and weld up all the mounts for it
RevXS is offline
Old 04-03-2008, 02:47 PM
Rapid Roy's Avatar
You can use one of these to start your car.
http://www.rctech.net/forum/newreply...te=1&p=4309250
just get this too
http://www3.towerhobbies.com/cgi-bin...?&I=LXL402&P=V
Rapid Roy is offline
Old 04-06-2008, 05:39 PM
RevXS's Avatar
New exhaust been shorten'd up and fitted to the car,Nearly ready to run the motor in
RevXS is offline
