Old 04-07-2008, 02:19 PM   #16
RevXS's Avatar
RevXS is offline   Reply With Quote
Old 04-07-2008, 02:49 PM   #17
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Originally Posted by RevXS View Post
2wd wouldnt work too well on a touring car of this scale...
2wd works perfectly fine for a nitro sprint car.
will end up just going in big circles
Isn't that the whole idea?
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 04-07-2008, 09:25 PM   #18
RevXS's Avatar
No as most tracks are ovals
Im meaning as in you put the power on and just gos in a loop and doesn't go straight,As this car has been shortened nearly a inch compared to the likes of a standard touring car....But im going to try it 2wd before i finsh up making the belt tensioner etc,Just waiting on the clutch bell so i can get her fired up and running
Also now got all the custom throttle/brake linkage setup...
Old 04-08-2008, 06:51 AM   #19
squarehead's Avatar
Thumbs up
Actually, it won't. Unless you don't have a diff in the rear. The car will work perfectly fine as a 2wd car if you do not have any of the front drive system installed.
American sprint cars are based on RC10GT or touring car rear diffs, so there is really no difference from what you're building, other than the double wishbone front suspension. And there are thousands of them racing here every weekend.
Keep up the good work!
doug
Everything depends.
Nothing is always.
Old 04-20-2008, 01:15 AM   #20
RevXS's Avatar
well abit of a update,found a frontbelt that fits better from a ta05...Just a standard belt at the moment but will get the Kawada Kevlar Belt which "should" hold up alright fingers crossed!
Old 04-20-2008, 08:20 AM   #21
cdelong's Avatar
nice looking layout. if you are going to run it 2wd take the front belt off. that will totally mess up your handling in the turns..... its like applying front brakes with the extra drag of the belt on there.
some good help on dirt oval cars can be found here.... www.dirtoval.com
and here..... http://www.customworksrc.com/index2.php
Tony Stewart bought out CustomWorks in 2003 and moved them to NC from CA.
KYOSHO EVOLVA
35PLUS21
FUTABA 3PKS/KO PROPO
BYRON'S FUEL/TWISTER TIRES
cdelong is offline   Reply With Quote
Old 04-20-2008, 02:36 PM   #22
RevXS's Avatar
Going to carry on making this car 4wd,done far too much work to just throw it away and start it again,New rims for it have turned up which make the car a little wider and a bit better look,Can also see the fuel lines are run with a protector over them
Body to have a go at making the body and wing out of very thin stainless steel,A mate has a tig welder and is going to help as i only have a mig...Heres hoping it turns out good
Old 04-20-2008, 04:01 PM   #23
genesisG4's Avatar
4wd should be awesome if you can work it out...keep on!
genesisG4 is offline   Reply With Quote
Old 04-20-2008, 04:27 PM   #24
Dude that's a very cool car. Have you driven it yet? If I were you I'd drive it as is, try both 4wd and taking out all the front drive train to try 2wd before doing the body. With all the changes you've made to suspension geometry you may find some quirks that require some chassis tweaks to make it fast. If you do the body first you may find yourself hacking it up later to make chassis changes.
Frank Connolly
Thugs Bunny is offline   Reply With Quote
Old 04-20-2008, 04:44 PM   #25
RevXS's Avatar
Havnt driven it yet,Still trying to find a "cheap" clutchbell for it,Far too costly to buy a brand new one...but other than that it still has to be run it
Old 04-20-2008, 06:38 PM   #26
Rapid Roy's Avatar
Why can't you use the Mugen clutchbell?
Rapid Roy is offline   Reply With Quote
Old 04-20-2008, 06:43 PM   #27
RevXS's Avatar
I would use it,One problem is....I didnt get one with the car!
Old 04-20-2008, 08:14 PM   #28
cdelong's Avatar
do you just need the clutchbell or an entire clutch set-up?
a clutchbell is only about $13?
cheapest full Mugen clutch set-up.... http://ashfordhobby.com/detail.aspx?ID=1537
KYOSHO EVOLVA
35PLUS21
Old 04-23-2008, 06:23 PM   #29
RevXS's Avatar
Yeah i need the whole thing,Good price too bad its out of stock...
Old 04-24-2008, 05:06 PM   #30
ShrekNZ's Avatar
Ahh I know now - that's Rocky's old Car right that he got from Fong........
You will need a full clutch setup including flywheel - try putting a want add up on rcracer.co.nz
The flywheel and clutch parts (except for the pinions and clutch bell) are the same as the MTX4
ShrekNZ is offline   Reply With Quote
NITRO SPRINTCAR/TRANSPONDER James Woodard R/C Items: For Sale/Trade 52 10-21-2008 06:48 PM
Losi XXXCR Sprintcar jts5555 R/C Items: For Sale/Trade 6 04-23-2008 02:19 AM
barts sprintcar jeremiahdenton R/C Items: For Sale/Trade 7 03-16-2007 08:42 PM
looking for a sprintcar body bobcat racing R/C Items: Wanted to Buy 1 10-12-2005 11:58 PM
CUSTOM WORKS SPRINTCAR 49er R/C Items: For Sale/Trade 22 07-17-2005 06:13 AM
