Old 03-31-2008, 12:01 PM   #16
dnitro's Avatar
Originally Posted by bosley View Post
Ash what power supply should i connect my starter box to then
If you do find a good power supply (good luck) you will be tied up to the outlet or to the wall instead of being able to carry your starter box at the track or anywhere else for that matter. You want a starter box that can be portable as can be.
TM G4S
IDM Evo3
dnitro is offline   Reply With Quote
Old 03-31-2008, 10:43 PM   #17
asw7576's Avatar
Okay i found another box of wires and found AC- DC adaptor with output of 12V and 800mA will it work better than the 500mA one?
800mA = 0.8 A ..... it's not going to cut it.
Why don't you buy 12V gel battery ? or double 7.2V NIMH ?
Old 08-12-2010, 01:31 PM   #18
sorry to pull up this old thread.
just wondering if anyone got it to work, using wall socket to use the starter box??
cheers.
garyten is offline   Reply With Quote
Old 08-12-2010, 01:44 PM   #19
wingracer's Avatar
Trader Rating: 24 (100%+)
cheers.
Sure you could if you have a good 75amp power supply or something but why bother with that?
No little wall wart supply is going to cut it.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-12-2010, 02:14 PM   #20
Roelof's Avatar
Send a message via ICQ to Roelof
hmmmmm choices.......
- 1 power supply 13.8v/40A +/- 170 bucks
or one of these 2 options:
- 2x 3000mAh NiMh or LiPo stickpacks and a charger +/-80 bucks
- 1x lead-acid 12v/7Ah battery and a cheap charger +/- 50 bucks
The last 2 options are more mobile as well......
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 08-13-2010, 03:35 AM   #21
hears a rough guide for you
lets go back to teh brushed motor times
a 27 turn stock motor running at 5 volts would draw between 5 and 14 amps depending how wel its tuned so your starter box is probly a 750 size motor it will be 12 volt and it will be drawing around 12 - 20 amps depending on how much load is on teh rotor
remember more volts comes with more amps V=ir Volts = amps X resistance
Daniel1234 is offline   Reply With Quote
Old 08-13-2010, 03:56 AM   #22
We use a 7Ah 12v gel cell in our starter box and its used for 4 differents cars during a meeting competing in 4 rounds of quali. plus a final each which equates to 20 starts. That's without quite a few starts during practice.
jonrg is offline   Reply With Quote
Old 08-13-2010, 04:07 AM   #23
chuakevs's Avatar
go for a 12v motorcycle battery..
it should work and it should fit the starter box..
[+] Sole Flyer of self-assembled RC Planes in Quezon Province [+]
chuakevs is offline   Reply With Quote
Old 08-14-2010, 07:37 AM   #24
avs
avs's Avatar
Tony Shimko
avs is offline   Reply With Quote
Transformer LKH Malaysian R/C Racers 51 12-24-2008 09:22 AM
Rechargeable Glow Plug Starter airsky Singapore R/C Racers 1 07-02-2007 07:27 PM
transformer Q" timmey Electric On-Road 9 08-04-2006 06:16 AM
WTB: Glow Plug Starter Teaken Singapore R/C Racers 0 02-24-2003 05:20 AM
WTB: V1R or V1RR with glow plug igniter, starter and fuel bottle, no electronics. Entropy Singapore R/C Racers 14 02-05-2003 10:51 PM
