Old 03-27-2008, 11:34 AM   #1
Zootcapri's Avatar
Default Supports on 1/8th scale body
Are there specific places on a 1/8th scale body (Frizbee) where you attach the supports? This is my first 1/8 body and I can't find any directions as to the locations... There are three for each side... one double wide and two single wide .... Does one go behind the rear wheel? Do I just evenly space the three supports on the side? Does it matter where the thick support goes?
I hope this question is entertaining for some... I just want to do it right.... knowing that this probably won't matter once I get the engine running and hit something.
Zootcapri is offline   Reply With Quote
Old 03-27-2008, 12:29 PM   #2
If it is the standard weight body you really only need one in the center of the body on each side. If it is the lightweight body you should put 2 on each side in the center and one in the rear on each side.
JASON MAC is offline   Reply With Quote
Old 03-27-2008, 12:41 PM   #3
Zootcapri's Avatar
It is the standard weight... Thanks for the answer..
Old 03-27-2008, 01:35 PM   #4
garen's Avatar
you going to run 1/8th in Vegas?
bpengines-usa.com fioroni-usa.com motonica-usa.com
Airtronics Avid RC Byron Fuels VOX Engines
VMR Tires - available at http://motonica.ipower.com/store
garen is offline   Reply With Quote
Old 03-27-2008, 02:12 PM   #5
Zootcapri's Avatar
I will run some laps on Wednesday, but I have had absolutely no time with this car (MRX-4R) and only plan on racing the IGT and 1/10th.
Old 09-10-2010, 11:13 AM   #6
LOW ET's Avatar
Trader Rating: 97 (100%+)
are there any pictures of the underside of a 1/8 onroad body with the supports installed? what's the best way to mount these? mounting procedure?
LOW ET is offline   Reply With Quote
Old 09-11-2010, 08:11 PM   #7
if someone doesn't post one by tomorrow night i will get a picture but you should have the idea already (avoid the pipe basically)
serpent makes some really good supports (buy 2-3 and keep reusing them)
the key one here is the wing support, it locks the wing to the side behind the wheel. the side supports and the rest are standard. part #1733 is just the wing supports.
http://www.serpent.com/product/1730
always mount with tape and rivets/screws.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 09-11-2010, 09:32 PM   #8
wingracer's Avatar
Trader Rating: 24 (100%+)
I make my own from sheet lexan and use 1/8th rivets and washers to attach them. Basically I'm copying the ones that Mike Queller used to include with his Speedline bodies. I'll see if I can get a pic or two tomorrow.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
12th scale gallery (Post your pics... body on and body off) akura2 Electric On-Road 560 03-27-2011 11:29 PM
matching recoil tc body and 1/10th scale alfa tc body twistedone R/C Items: For Sale/Trade 3 03-03-2008 06:48 AM
Ex1 Mars supports digital servo? bigbutstupid Radio and Electronics 2 12-05-2007 04:08 PM
F/S xbox 360 pro set with all supports and extras jmodd Other Items: For Sale/Trade or Wanted to Buy 14 06-22-2007 07:01 PM
2.2" truck tires and HPI NMT arm supports corvettecrazy R/C Items: For Sale/Trade 0 04-26-2004 08:50 PM
