Old 03-27-2008, 07:05 PM   #31
eclipser's Avatar
Send a message via MSN to eclipser
well like a used .18 then get a reall good new .18ss from hpi
eclipser is offline   Reply With Quote
Old 03-27-2008, 07:13 PM   #32
NTC3Crazy's Avatar
Don/t go used, check out this link http://www3.towerhobbies.com/cgi-bin...?&I=LXGEE4&P=7
#1 NTC3 RTR Modded w/JP Racing M12
#2 NTC3 Team Kit w/RB X12
#3 NTC3 FT Kit Ver.2 w/Rody RB V15 Turbo
Savage 4.6SS Kit
Jr XR3i
NTC3Crazy is offline   Reply With Quote
Old 03-27-2008, 07:16 PM   #33
eclipser's Avatar
whats the difference on the mufflers are all the same/
Old 03-27-2008, 07:18 PM   #34
NTC3Crazy's Avatar
Everything you have now should work, just change the engine.
Savage 4.6SS Kit
Jr XR3i
Old 03-27-2008, 07:20 PM   #35
eclipser's Avatar
but would all .18 stuff fit on any motor
Old 03-27-2008, 07:24 PM   #36
NTC3Crazy's Avatar
Do the research or ask your LHS, they should help.
Savage 4.6SS Kit
Jr XR3i
Old 03-27-2008, 07:28 PM   #37
eclipser's Avatar
yeah sorry if ive bin bugging with all the noob questions
but what is LHS
Old 03-27-2008, 07:34 PM   #38
NTC3Crazy's Avatar
You have not been bothering me at all, as I stated before I can only suggest.
LHS stands for local hobby shop
Savage 4.6SS Kit
Jr XR3i
Old 03-27-2008, 07:35 PM   #39
eclipser's Avatar
this any good?
http://cgi.ebay.com/Team-Infinity-18...QQcmdZViewItem
Old 03-27-2008, 07:45 PM   #40
NTC3Crazy's Avatar
Nevr heard of the brand
Savage 4.6SS Kit
Jr XR3i
Old 03-27-2008, 07:47 PM   #41
eclipser's Avatar
oh then i should stay away from it
Old 03-27-2008, 08:04 PM   #42
eclipser's Avatar
associated motors are good right?
look
http://cgi.ebay.com/Associated-RC-18...QQcmdZViewItem
Old 03-28-2008, 02:40 PM   #43
NTC3Crazy's Avatar
Yes they are good, in most cases they offer a good warranty.
Savage 4.6SS Kit
Jr XR3i
Old 03-28-2008, 03:48 PM   #44
Rapid Roy's Avatar
look
You said money isn't a problem. If that really true, just go get the OS .18TZ and be done with it. The OS isn't that expensive and its reputation for reliability and power output are great. Whatever engine you get, make sure you get one with a "Standard" crank shaft. You can tell the engine has this because the crank shaft has threads on it. Also, make sure you don't get an engine with a crank designed for a Tmaxx. The crank is threaded but too short for your car. Here is the correct one.
http://www3.towerhobbies.com/cgi-bin...?&I=LXHLV9&P=7
This will bolt directly into your car and work. The only thing I'm still not clear is what exhaust you have right now. The engine I showed you above has a "rear" exhaust on it. You will need an "outlaw" or "turbo" exhaust and header for a .12 block. Like this.
http://www.kamikazercracing.com/prod...r12plusexhaust
I'm thinking you have a side exhaust setup right now.
You'll also need an air filter and filter oil.
http://www.kamikazercracing.com/prod...?prod=skmotion
Rapid Roy is offline   Reply With Quote
Old 03-28-2008, 05:42 PM   #45
eclipser's Avatar
i have a rear exhaghst right now it comes out in the midle of the rear mounting pins
it looks like this
http://www.hpieurope.com/kit-info.ph...=fr&partNo=484
[B][COLOR="Black"][SIZE="5"]GO TECH ENGINES what are your opinons?[/SIZE][/COLOR][/B] Crazy Carl Nitro Off-Road 5 02-27-2008 02:58 PM
[SIZE=7]M11,M8,SPEKTRUM AND MORE[/SIZE][COLOR=Black] gonzo416 R/C Items: For Sale/Trade 0 10-12-2005 07:50 PM
XL & XXL Size Tmachine Other Items: For Sale/Trade or Wanted to Buy 0 03-04-2005 02:35 AM
