Ofna Tire Truer Question
NEVER MIND....I JUST FIGURED IT OUT...DUH!
I picked up a real nice used Ofna manual tire truer....wow, impressed so far! This is the first one I have ever used so I have nothing to compare it to or I could probably answer my own question as it is pretty simple I am sure. My question is...the cutter is in a horizontal position and it seems to me it would cut the tire surface cleaner and better if it was set at a slight angle. I can not see where there is any adjustment to rotate the cutter at all???? |
Not sure about the manual cutter. But the Ofna auto truer the blade is mounted at a 45 degree angle. If you look at the cutting arbor there should be a thumb screw on the top that drops down into a milled slot on the cutting arbor. This places the cutter at a 45 degree angle.
Race you later... |
Originally Posted by lil-bump
(Post 4280148)
Race you later... |
