Old 03-15-2008, 11:23 PM   #1
Default What are some good ways to remove this damn stripped hex screw !!
What are some good ways to remove this damn stripped hex screw !! I've tried to drill a hole in the middle and use one of those EZ out.. but it failed ! i don't have a dremel so thats out.. hmm... what other ways are there to get this damn stripped hex screw out.. !!
bosley is offline   Reply With Quote
Old 03-15-2008, 11:35 PM   #2
Rapid Roy's Avatar
There are 2 ways. One is to twist or turn the engine back and forth while holding a phillips screwdriver against the hex screw. Many times this will loosten the screw. The other way is to use a larger diameter drill bit and drill out the head until the head simply falls off. Then you remove the engine and grab the stump of the screw with plyers and loosten.
Rapid Roy is offline   Reply With Quote
Old 03-15-2008, 11:35 PM   #3
lil-bump's Avatar
Trader Rating: 83 (100%+)
I know you don't have one but you need a dremel. The best way is with a dremel with a thin cutting disk. You need to cut a slot across the screw and then use a flat tip screwdriver to remove. the only other way is to remove all of the other screws and hopefully you can rotate the engine mount to loosen the tension on the screw thats stripped. Also try and hit the screw with a little heat. Make sure your allen driver is not worn. A worn allen driver will tend to strip screw heads. once you get it out remember to coat your engine screws with a little never seize that will prevent this from happen in the future. hope this helps
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 03-16-2008, 12:51 AM   #4
kidsid99's Avatar
Trader Rating: 53 (100%+)
Sears has a screw extractor set that has a drill bit on one end and an extractor on the other. Just put it in your drill reverse the drill and it comes out. Part # 52155 comes with 4 sizes. And it won't damage your chassis like a dremel will.
kidsid99 is offline   Reply With Quote
Old 03-16-2008, 01:27 AM   #5
the screw extractors didn't work.. anyway if i drill it out... will i destroy/strip the things in the hex screw socket?
Old 03-16-2008, 01:29 AM   #6
V for Victory's Avatar
Send a message via AIM to V for Victory
Another way that works is to make a small cut on one part of the screw with whatever you have in your house. Then take a flathead screw driver, put it against the little slit you made, and hit it with a hammer at an angle to loosen it. I dont recomened this because i have damanged one of my motors doing this before, but it has only happened once. Could have been a defective motor.
SUN VALLEY SPEEDWAY
MUGEN MTX4R-NINJA
MRX4R-NINJA
RTS!
V for Victory is offline   Reply With Quote
Old 03-16-2008, 02:49 AM   #7
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
To remove the screw......first remove the engine from the car....it will leave 1 part of the engine mount on the chassis....if it is a 1 peice engine mount, thats fine.... Second, twist the engine mount back and forth...this may work for you, may not, but if it is seized up, the little twisting might be enough to break it free.....
If that doesn't work, and you have a drill....use a 3mm sized drill bit...it could be just a bit larger and drill the head off... that will leave you with a small threaded stub sticking out of the engine mount which you should be able to remove with a pair of pliers.
Or, you could use a small file to wear a grove in the top of the head to use a flat tip screw driver.
If all else fails, ask a neigbor if they have a dremel.
rcfoolz is offline   Reply With Quote
Old 03-16-2008, 02:52 AM   #8
grub's Avatar
i get my off with a pair of wire cutters
i just grap the middle and outer edge of the screw and give it currie
it usly is enough to loosin it
have you used locktite on it?
last resort if you havent used locktite drill it out be careful not to drill to much of the thread off
i use small 3mm to start and finish of with a 4 or 5 mm drill and just take the top off the screw leaving about 2 to 3 mm (thickness of the chassie) to grab on to and then grab the remaining thread with some plires the heat from the drill is enough to loosin the screw .
all the best
This is my xray nt1!
There are many other xray nt1's like it, but this one is mine!
Without my xray nt1,I am nothing!
Without me, my xray nt1 is nothing!
pop corn anyone or maybe some fairy floss
grub is offline   Reply With Quote
Old 03-16-2008, 02:53 AM   #9
rcfoolz's Avatar
almost forgot....NEVER USE STAINLESS STEEL SCREWS.....(or aluminum) on parts that of different types of metals.....if they get hot and cold when wet, they could do somthing that is called "cold weld" themselves together and that might be what happened to your 1/8 scale buggy.
Old 03-16-2008, 05:27 AM   #10
LOW ET's Avatar
Trader Rating: 97 (100%+)
i thought you were supposed to loctite everything on a nitro car?
LOW ET is offline   Reply With Quote
Old 03-16-2008, 07:30 AM   #11
lil-bump's Avatar
That may apply in offroad but not in onroad. I use a dab of never seize only on my engine mounts which are alluminum and the screws are steel this prevents
what you see in the picture. My engine mount screws would seize after one day of racing. Just make sure you tighten the Sh?t out them. But I never had one come loose
Elliott Hart
Serpent America
Desoto Racing Team
Old 03-16-2008, 07:56 AM   #12
Trader Rating: 93 (100%+)
Default Dremel
I have removed alot of them by using the dremel with a small thin wheel to cut a groove and then use a screwdriver. If that don't work maybe a blowtorch! lol
latemodel13 is offline   Reply With Quote
Old 03-16-2008, 08:20 AM   #13
Taylorm's Avatar
Get a drill bit that is the same diameter as the width of the head of the screw and drill the entire top of the screw off....then the shaft of the bolt that is still in the engine mount can be latched on to with a set of vise grips and removed...........
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 03-16-2008, 10:35 AM   #14
KyoshokiddT.D's Avatar
put a cutting wheel on a dremal tool and cut a slot in the screw then use a regular screw diver to twist it out
KyoshokiddT.D is offline   Reply With Quote
Old 03-16-2008, 12:25 PM   #15
anomaly's Avatar
I second the dremel cut/flathead method. I keep a cordless dremel with my track stuff -- it's saved my arse many times.
Be sure to bear down on the newly cut slot with your flathead when removing --
Good luck,
anomaly is offline   Reply With Quote
Urgent stripped screw help coons88 Electric On-Road 14 02-24-2007 04:46 AM
stripped pinion screw AZNracerx1989 Rookie Zone 3 08-02-2005 11:31 PM
Stripped Screw DIMO Electric On-Road 11 06-07-2005 03:57 PM
stripped screw ntc3freak Nitro On-Road 23 09-21-2004 05:35 AM
Stripped Screw RCDoon Electric On-Road 1 04-01-2003 09:11 AM
