Old 03-09-2008, 12:57 PM   #1
tony montana's Avatar
Trader Rating: 66 (100%+)
Default need help chosing tire truer
Im in the market for a tire trurer. I dont want to spent 450.00 on the hudy one. Anyone have any suggestions? I dont want a pos one but dont need the best either. If it matters Im running sedan
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 03-09-2008, 01:01 PM   #2
stefan's Avatar
Send a message via AIM to stefan
I got this one from Ofna in 1999 and it was already 2 years old. Used it heavily and it never let me down.
With the Hudy carbide cutting bit it's working awesome.
The motor is a mule and will cut anything you throw at it.
The same truer is available from Corally, but I suppose it's more expensive...
The Ofna is $ 239 at nitrohouse: http://www.nitrohouse.com/tire_truer_parts.htm
stefan is offline   Reply With Quote
Old 03-09-2008, 01:13 PM   #3
LOW ET's Avatar
Trader Rating: 97 (100%+)
buy this one. i was in the same boat as you, i wanted a hudy but i can't see spending that much money. after talking to numerous people this is the truer everyone said to get. buy from kamikaze and sam will hook you up.
http://www.kamikazercracing.com/prod...php?prod=20002
also like the above post, you can use the hudy carbide cutter.
LOW ET is offline   Reply With Quote
Old 03-09-2008, 02:47 PM   #4
charlesd's Avatar
I can vouch for the ofna manual tire truer. A very good truer.
charlesd is offline   Reply With Quote
Old 03-09-2008, 04:36 PM   #5
aussies1129's Avatar
Trader Rating: 74 (100%+)
I have this truer ofna manual and am extremley happy with it 10out10 got it from kamikaze Sam.
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 03-09-2008, 06:41 PM   #6
Trader Rating: 18 (100%+)
Default Tire Truer
I have both, the Ofna, and the Hudy. I have had the Ofna for about 3 years now, and it worked great. I did change out the motor, but that was only because of the on-going use. Then I got a great deal on the Hudy. The Hudy does cut quite a bit faster, and overall smoother operation, but the Ofna still works great. If I had to but my first one again, it would be the Ofna. Even though the Hudy does cut faster, and smoother, for the price difference, I would go Ofna
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 03-09-2008, 06:50 PM   #7
kidsid99's Avatar
Trader Rating: 53 (100%+)
The Ofna truer is a good truer. You could also get just the Hudy blade and it will cut just like a Hudy and you will still come out cheaper. Alot of the guys I race with have them and they work well. Integy makes a auto truer that is even less $$s than the Ofna but it is a good bit slower. I like the rest of the other posts, would recommend the Ofna if you don't want to spend the $$$s for the Hudy.
kidsid99 is offline   Reply With Quote
Old 03-09-2008, 08:10 PM   #8
kcrunchone's Avatar
The problem I had with the ofna truer was that the bit motors died on me. That also happened to a few other people that I know. I actually gave my truer to someone here on the site for the cost of shipping I was so pissed with it. Turned around picked up a hudy after my second ofna burned out and I have never looked back at the purchase.
Rick Hill
"Failure Is Not An Option"
kcrunchone is offline   Reply With Quote
Old 03-10-2008, 02:25 PM   #9
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
I also have the OFNA Manual true'r and would buy it again served me well all of last season never had any issue with it the cut was fine and with enough amps behind it it can cut just about any foam tire you can fit on the arbor. I mainly run it off a 7AH gel cell like you find in most starter boxes runs strong all day long.
regg151 is offline   Reply With Quote
Old 03-10-2008, 05:05 PM   #10
MugenDrew's Avatar
Trader Rating: 30 (100%+)
If you go Ofna manual or auto the Hudy carbide cutter is a must #10 2067. I would also recommend the Hudy arbor's. The cut is acceptable. I would replace all wiring that leads or feeds the spindle motor with the stuff that the electric guys use for batteries to esc? to motor. This will provide a significant increase in grunt especially when cutting 1/8th rears.
Hudy fully automatic, what can I say...Ferrari's are expensive for a reason(and so is what is usually in the passengers seat).
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 03-10-2008, 05:17 PM   #11
what about the team magic or hard trurer? How is that one
Old 03-10-2008, 05:20 PM   #12
another question, Im new to all of this, Does these trures, for example, say I want to cut the rears to 60mm, how do I know where 60mm will be at, is there a digital read out that I set to where I want to cut or do you have to use calipers
Old 03-11-2008, 11:05 AM   #13
MugenDrew's Avatar
The Ofna auto is marked on the tool holder in 2.5 mm increments. With the Hudy cutter it cuts 35 shore 1/8 tires 2.0 mm smaller than what the scale reads. I use the scale to get close(rough in the diameter) then from there use calipers to achieve my desired O.D.
The Hudy scale is Very acurate. If you want to be dead on you will still want to check with calipers(you will be checking alot less).
They are both scaled if you want to cut camber into the tires...
Old 03-11-2008, 01:02 PM   #14
almtx3's Avatar
Ofna Manual tire truer has got my vote. I got mine on ebay and its worked great! Blade on it was still new so no need to replace it. Ill be getting the Hudy Carbide blade once the one on there now wears out.
almtx3 is offline   Reply With Quote
Old 03-11-2008, 04:31 PM   #15
lil-bump's Avatar
Trader Rating: 83 (100%+)
I milled my tool arbor down by 2mm; now my Ofna auto truer cuts within .1 mm of the dial scale using a hudy bit. I also labeled my knob adjustment in .1mm increments. Mine is truly good as a hudy but not a real hudy!
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
MaxMod Tire Truer (large AC version w/adjustment for cutting camber into the tire) Danny-The-Dude R/C Items: For Sale/Trade 3 02-26-2007 03:10 PM
llooking for a hudy tire truer or an auto truer hpiaustin R/C Items: Wanted to Buy 2 12-09-2005 06:56 AM
Questions on Tire Truing and the Eagle Racing Tire Truer nitro_tacklebox Electric On-Road 5 04-21-2005 03:39 PM
Integy Tire truer, Arbors 1/10 and 1/12 plus carbide tire file evostyle R/C Items: For Sale/Trade 11 03-22-2005 11:58 PM
WTB Hudy Tire Truer Automatic or Other Tire Truer 993power R/C Items: Wanted to Buy 0 10-23-2003 05:47 PM
